converted drill press to variable speed
Discussion in 'Horological Tools' started by brian fisher, Oct 17, 2019.
  1. brian fisher
    brian fisher Registered User
    Jan 20, 2017
    1,299
    276
    houston, tx
    this is a little project i've been working on for a few months. i finally finished it up today.
    i inherited this press from my granddad back in the late '90s. it came to me with a 1/2hp induction motor and the skinniest belt drive system i've ever seen in my life.
    i picked up this 2hp treadmill motor and variable speed dc controller off ebay. i have about 120.00 invested in both.
    my next problem was what to do for pulleys. i liked the idea of using ribbed serpentine belts, so i decided to convert a couple of water pump pulleys.
    here is the finished product.
    Jim_Miller likes this.
  2. Jim_Miller
    Jim_Miller Registered User
    Mar 6, 2001
    824
    Jackson, Michigan
    Pretty hevi-duty, nice job
  3. Jim DuBois
    Jim DuBois Registered User
    NAWCC Member Sponsor
    Jun 14, 2008
    2,558
    421
    Magnolia, TX
    Nice work Brian!
  4. David S
    David S Registered User
    Dec 18, 2011
    7,167
    232
    Brockville, On Canada
    Nice conversion Brian. How is the spindle / chuck runout?
    David
  5. brian fisher
    Jan 20, 2017
    1,299
    276
    houston, tx
    Thank you all for the kind comments.
    as to runout, i disassembled the spindle, cleaned everything, and replaced the bearings. I have not measured it since I put it back together, but I assume it’s probably similar to any standard u.s. made machine from the ‘60’s.
    I like the fact that the chuck is attached with a taper so whenever I do get around to measuring, I can play around with the way the chuck is indexed on the shaft.
  6. measuretwice
    measuretwice Registered User
    Jul 28, 2019
    26
    11
    Toronto
    You've sure demonstrated making the most of a small machine - nice work!
  7. David S
    Dec 18, 2011
    7,167
    232
    Some tread mill motors have an external fan. Does yours have one internal?
    Also just noticed that you are using a Unimat lathe / mill. Nice to see those still being used.
    David
  8. brian fisher
    Jan 20, 2017
    1,299
    276
    houston, tx
    it has an external fan. its plastic, but somehow it arrived in the mail undamaged. needless to say, i am using it for this application. you can actually see a side view if it in the video i posted above. it is the black thing on the bottom of the motor.
    that little lathe.... i just got it about 6 months ago. i literally have no idea how i have gotten along this far without it. it seems like i find a use for the silly thing almost every day. i am constantly buying accessories for it in ebay. i probably should have just invested in a sherline.....
