Connect Time recorder to mains
Discussion in 'Electric Horology' started by BobSeilh, Sep 24, 2020.
  1. BobSeilh
    BobSeilh Registered User
    Sep 24, 2020
    I hope someone can advise
    I’ve had this clocking machine for nearly 25 years and always wanted to connect to the mains
    Is it possible ?
    Do I need a transformer or current regulator or something ?
    would be great to have the clock working
  2. Toughtool
    Toughtool Registered User
    Aug 12, 2016
    139
    19
    Panama City, FL
    I have an IBM recorder that looks a lot like this unit. Mine has had the IBM electric conversion where they removed and replaced the two springs and wood stick pendulum with an AC 60Hz synchronous motor. This unit is not a conversion because there are no key holes in the clock's face which is where my mainsprings were wound.
    To me, the coils do not look like a motor, but maybe a solenoid for winding a mainspring. Is there a pendulum and mainspring? The long thin shaft looks like my drive shaft for driving the print mechanism's time and date wheels down below, and the day/night indicator seen through the hole of the wood panel. A couple of more photos may be helpful.
  3. BobSeilh
    Sep 24, 2020
    Hi
    Thanks for your response
    No pendulum it was connected to the electric in the office so I guess no need for of pendulum.
    I don’t have lent more photos but send these if it helps
    i would only like to know f I could connect directly to the mains or need a transformer regulator etc
  4. Oldbo
    Oldbo Registered User
    Jan 16, 2016
    Engineer
    Wales, UK
    Make sure it is not intended to be pulse driven from a master clock. You definitely don't want to connect it to the mains then!
  5. BobSeilh
    Sep 24, 2020
    This is my question in fact
    How can I tell ?
    And can it be adapted ?
  6. Oldbo
    Jan 16, 2016
    Engineer
    Wales, UK
    Where you have photographed the two solenoids, see if there is a movable bar at one end of the solenoids. If you can depress this and the hands move, it will be pulse driven.
    That is how my Gledhill Brook clocks work and very possibly how your clock works.
    That's a good starting point. Let us know what you find.
  7. BobSeilh
    Sep 24, 2020
    Hi there
    Yes I managed to moved something and the minute hand moved
  8. Oldbo
    Jan 16, 2016
    Engineer
    Wales, UK
    So you will need to drive the clocking machine with either a master clock or a pulse generator. I think National equipment generally runs at 6V DC.
    Try blipping a 6V DC power supply across the plug connector terminals to see that the clock moves. Probably in 30 second increments. This voltage is low, so you won't do any harm.
    If you don't want to go the master clock route then a pulse generator will be needed. They are available commercially or you can make your own.
  9. Toughtool
    Aug 12, 2016
    139
    19
    Panama City, FL
    #9 Toughtool, Oct 4, 2020
    Your photo shows a hint. Look and see what numbers are in front of the "0 v". That may be the operating voltage of the coil. I agree with Oldbo, I think this is a slave to a master.
    Also notice the rod with the loop at the bottom. This may be a manual advance. Joe
    click on photos to enlarge view.
  10. Toughtool
    Aug 12, 2016
    139
    19
    Panama City, FL
    Looking at a different photo, it looks like the coil operates on 20 volts DC.
  11. BobSeilh
    Sep 24, 2020
    Thank - you guys are great
    So what’s the easy solution ?
    20v battery ?
    Transformer ?
    Sorry I’m not a electric guru at all
    Better at mechanical topics
  12. Toughtool
    Aug 12, 2016
    139
    19
    Panama City, FL
    You either need a master clock or an electronic pulser unit with a minute impulse (or according to Oldbo, maybe a 30 second pulse) to run your clock.
    To test your clock locate a 20 volt Direct Current (DC) power adapter. If you have an 18 volt laptop computer adapter, that may verify the coil is working and if it will advance. Notice if the minute hand advances for each pulse. Connect one wire to the plus (the red wire out the top) and momentarily connect the other (black wire) to the negative and the solenoid should attract with a click. Disconnect and it armature should drop. If it moves one minute for each pulse then you need an accurate 1 minute pulse per minute driver to run your clock. I don't know the duration of the pulse needed but from .5 to 1 second ON, should be OK. Ken's clock clinic at: Model 1900W-UNV Modular Clock Winder - Ken's Clock Clinic also sells a couple of different pulsing units.
    If you want to DIY a pulser, you can build one like my master using the ESP8266-E12 NodeMCU, substituting the 24 volts power adapter with a 20 volt power adapter. Phil had included a 1 minute output in the latest software update. A second option is to experiment with my winder circuit and adjust the timing in software. I don't know how accurate the winder will be as I have not tested it but the ESP8266-E12 NodeMCU version uses the NTP network time servers to keep it on time. A connection to the WEB will be necessary. If you are interested in the ESP8266 I will draw a schematic for just the 1 minute output, requiring a single MOSFET transistor.
  13. BobSeilh
    Sep 24, 2020
    Hi again
    i actually had a 20v laptop lead and tried this
    success with a click yes advanced a minute
    so I will visit your link to buy a pulser
    Many thanks again
  14. Toughtool
    Aug 12, 2016
    139
    19
    Panama City, FL
    Great! Just to satisfy my curiosity, what happens when you put your finger in the wire loop on the left and pull down (see post #9, last photo). Does the clock advance? Joe
  15. BobSeilh
    Sep 24, 2020
    Hi Joe yes it moves by a minute with a resounding click
    thanks
