Looking at ordering bushing that will work with specific cutter/reamer sizes. For example a cutter/reamer size 1.97mm. There are 2 options for height 1.5mm and 3.0mm. and bore size 4 options? Does the height have to do with plate diameter and are you better off going with the 3.0mm as opposed to 1.5mm? and what about the bore size? Since the bore size is going to have to be drilled out to the size of the pivot, is it best to just buy the smaller bore size bushings?
Looking to get bushings For cutters/reamers: 1.97mm, 2.47mm, 2.97mm and 3.47mm
each option is $5.50 to $7.00 2.0mm OD examples:
options available: 10 piece pack of brass Bergeon bushings from Switzerland. Size #1. Combine with other sizes for quantity discounts. 2.0mm OD x 1.5mm height x 0.40mm bore.
10 piece pack of brass Bergeon bushings from Switzerland. Size #2. Combine with other sizes for quantity discounts. 2.0mm OD x 1.5mm height x 0.50mm bore.
10 piece pack of brass Bergeon bushings from Switzerland. Size #3. Combine with other sizes for quantity discounts. 2.0mm OD x 1.5mm height x 0.60mm bore.
10 piece pack of brass Bergeon bushings from Switzerland. Size #4. Combine with other sizes for quantity discounts. 2.0mm OD x 3.0mm height x 0.60mm bore.
10 piece pack of brass Bergeon bushings from Switzerland. Size #5. Combine with other sizes for quantity discounts. 2.0mm OD x 1.5mm height x 0.70mm bore.
10 piece pack of brass Bergeon bushings from Switzerland. Size #6. Combine with other sizes for quantity discounts. 2.0mm OD x 3.0mm height x 0.70mm bore.
