Coned arbor pivots
Vernon
Dec 9, 2006
835
90
Fellow repairers,
I'm working on an Asian clock that has coned ends on the winding arbors. Is this normal? The arbor bearing surface covers the plate thickness only. The end shake on one is such that when I bush the front plate, I'll need to allow it to be proud on the inside of the plate. Does this seem like a good repair method?
moe1942
Oct 25, 2010
1,648
17
Alexandria, La
As long as the arbor is supported by the full thickness of the plate that is fine. Can't recall seeing arbor ends tapered like that but don't see a problem..What amount of end play do you have now? And why do you think it is too much??
David S
Dec 18, 2011
7,205
248
Brockville, On Canada
Vernon, I have a 31 day Korean movement apart now, so your thread got me interested. While the great wheels are not coned, most of the others are. Smooth taper ending in sort of a small ball tip. I wonder if this is to aid assembly? Easier to find the bush and guide it in.
Vernon
Dec 9, 2006
835
90
It's too much in that it causes the coned area to fall within the bearing area, then you see daylight through the hole! What is interesting is that there is that beefed up bushing and it is not being used.
44,263
1,346
I wonder if the coned arbor is the Asian answer to the oil sink? It would direct oil to the bearing surfaces.
David S
Dec 18, 2011
7,205
248
Well the one I am working on definitely has oil sinks. INteresting that they are on the front and back of the plates for most of them.
R&A
Oct 21, 2008
4,203
107
If your end shake is to drastic. You can make a metal sleeve to slide over the pivot to make the arbor longer. This will reduce your end shake. I don't work on many Asian clocks because of the unpolished pivots and the craftsman ship is very poor. I have worked on many clocks where the pivot has broken off, and an extended bushing was installed to take up the lack of there of. The cones maybe for the end of the arbor to not dig into the side wall of the bushing. I see that you bushings are a pit high. I would clean those smooth where the cone meets the arbor. This will cause a power loss after time. Smooth it would dig in as much and it will have a smooth edge to ride on when it starts to tilt.
H/C
Topic related ad experiment
160,738
1,394,841
82,828
iandb
1,099
2,778
