Comtoise Movements
Discussion in 'Your Newest Clock Acquisition' started by garyg, Mar 3, 2017.
  1. garyg
    garyg Registered User
    Feb 2, 2007
    65
    Hello
    Did comtoise make time only movements with short pendulums?
    Thanks in advance
  2. JTD
    JTD Registered User
    Sep 27, 2005
    3,943
    19
    Comtoise is not a maker, it refers rather to a style of clock made in the Jura area of France by lots of different makers. These are also sometimes called Morbier clocks.
    As far as I am aware they were always with long pendulums, one of the characteristics of a comtoise, sometimes with a wooden case, sometimes without.
    I have never seen a time-only comtoise.
    JTD
  3. ballistarius
    ballistarius Registered User
    Oct 26, 2009
    702
    Architect
    Bilbao, Basque Country
    Yes, there are time-only comtoises, they are rare and intended as regulators or for train stations. Mostly they use pin-wheel escapement and have center seconds hand. But all of them sport long and heavy pendulums, not short ones...
    Aitor
  4. JTD
    JTD Registered User
    Sep 27, 2005
    3,943
    19
    Thanks for that information - good to know.
    JTD
  5. ballistarius
    Oct 26, 2009
    702
    Architect
    My pleasure!:D
    For instance, this caseless movement (unfortunately, not mine...)
    [​IMG][​IMG][​IMG]
    Aitor
  6. garyg
    Feb 2, 2007
    65
    Comtoise style movement photos. Maybe when you see this movement.
    You will know why I ask the question. Please let me know if you recognize
    this clock or mov't. I have a long pendulum mobier. This mov't sure looks like it.
    Check out case pendulum door. I did not get a pendulum with clock.
    Thank you very much for your replies
  7. ballistarius
    Oct 26, 2009
    702
    Architect
    garig,
    'Comtoise' or 'Morbier' is associated with weight driven clocks produced in the Jura region of France. In that same region, they made spring driven movements too, sometimes referred as 'Morez'. They have short pendulums with small brass bobs and yours is one of them. Your kind of case is known as an oeil-de-boeuf one.
    For your clock, they used a standard cage intended for housing two trains, but only installed a going train with a single barrel in the middle. [​IMG]
    The left, caseless, one in the pic is also a Morez. While I find (no hurry...:whistle:) a suitable pendulum, I've just put an American clock bob hanging at the end of a wire of suitable length. It keeps the time perfectly. Yours is in far better condition, congrats!:cool:
    Aitor
      File size:
      87.4 KB
      171
  8. garyg
    Feb 2, 2007
    65
    Truly appreciated my friend. Thanks a million for your valuable time and information.
    gary
  9. ballistarius
    Oct 26, 2009
    702
    Architect
    I'm always glad of being of some help here at the MB:) It is the least thing I can do in exchange for all the help I've received from all the fantastic people here!:clap:
    Aitor
  10. laumeg
    laumeg Registered User
    Jan 22, 2011
    550
    Retired, health care
    Houston, Texas
    Hi, The above reply is correct, that late in the history of the comtoise clocks, they started making spring driven clocks with short pendulums to be used in hanging wall clocks. I attached 2 pictures, one showing the back and one the pendulum. Charlse
  11. garyg
    Feb 2, 2007
    65
    Hello again. What is approximate pendulum length your clock runs at. Approx Weight. Appears I may have to remove the movement again to get clock to run. No space for anything but very short pendulum.
    Thank You
  12. laumeg
    Jan 22, 2011
    550
    Houston, Texas
    Hi, There is no length to it. There is a rod through it for adjustment, but there is a hook af the end which is right at the edge of the bob. It is fairly heavy, but do not have it with me right now to be able to weigh it. You should not have to remove the clock because you should be able to see the the bottom edge of the suspension rod of the movement. It just has a small hole and you hook it on. For trial and error you might get a fairly heavy fishing weight and make a hook on the end and try that. It will be fairly equivalent to the bob I have. Charles
  13. Ray Dennis
    Ray Dennis Registered User
    Sep 2, 2010
    25
    Mississauga
    You might also try using/adapting a spare lead weighted, brass face convex bob from an old German mantel clock.
    As Laumeg said there is no real length to the bob assembly . A lot of those old mantel clock bobs were very similar. Just the bob with rod and screw adjustment. Aim for a larger size if possible to give you a bit of weight.
    You will also find that type of movement in the some French wall clocks, some times described as " Bakers Clocks" .Many have the black wooden frame surround with painted and some times inlaid area around the dial.
    I love them . They were built like tanks..!!
  14. paddy2042
    paddy2042 Registered User
    Feb 6, 2017
    84
    Aitor
    What is the clock on the right? I have never seen a clock like that with weights in that position.
    Patrick
  15. ballistarius
    Oct 26, 2009
    702
    Architect
    Patrick,
    It is an American woodworks movement, without its case. It's placed (permanently:whistle:) in a modern test stand. Pulleys for the weights are a constant in early American weight driven shelf clocks, as a means of increasing the going time up to the minimum of 30 hours.
    Aitor
  16. paddy2042
    Feb 6, 2017
    84
    Aitor
    Thank you for the reply. It looks fascinating. I must do some research.
    Thanks again
    Patrick
Similar Threads - Comtoise Movements Forum Date
Re-casing old movements Your Newest Clock Acquisition Apr 25, 2017
Comtoise Clock Find Your Newest Clock Acquisition Dec 21, 2014
Restored Comtoise. Your Newest Clock Acquisition Dec 15, 2014
comtoise tall case questions. Your Newest Clock Acquisition Jun 9, 2014
Early Comtoise case. But is it Normandy? Burgundy? Besancon? HELP! Your Newest Clock Acquisition Jul 10, 2013
