Comtoise chime off
Bucksctytt
Aug 5, 2019
20
USA - ITALY
This is my second Comtoise clock but first time tearing one down and back together.
Now that its cleaned up - It is keeping great time but the chime ( strikes on the hour and a second one minute to after as well as a single strick on the half hour ) is out of sync with the time. IE .. clock time is spot on but the chime ( accurate strikes) pops off a bit too late. Is there an adjustment I missed in putting this baby back together? Could it be the weights?
Thank you for the help getting me here.. lots of useful tips and encouragement for a newbie.
Thom
5,033
623
How much off is your strike? Just a minute or two or more? And is the deviation the same at the full hour and the half hour?
The weights are not the culprits for this behavior.
R&A
Oct 21, 2008
4,203
107
You have to match the hour pipe and the cannon pinion together They are out of sink
wow
Jun 24, 2008
4,789
446
75
Pineville, La. (central La.)
Buck, I do not understand from your explanation, what it is doing. Normally, they strike the hour on the hour and then again about two or three minutes after the hour. They also strike once on the half hour. Would you explain once again what it is doing on the hour?
Bucksctytt
Aug 5, 2019
20
USA - ITALY
Thanks... the strike is off exactly 3 minutes on both the full hour and the half hour.
Bucksctytt
Aug 5, 2019
20
USA - ITALY
Yes of course. The clock chimes about three minutes AFTER the hour - repeats 2 minutes later then again once on the half hour - but with the same three minute delay.
Bucksctytt
Aug 5, 2019
20
USA - ITALY
Thanks . that sounds like progress... I know which is the hour pipe... but not the cannon pinion. Could you explain or send a picture?
T
wow
Jun 24, 2008
4,789
446
75
T
It is the wheel next to the hour pipe. Remove the hour pipe far enough that it will turn without turning the cannon pinion. Then turn it counter clockwise one tooth and slide it back on.
Bucksctytt
Aug 5, 2019
20
USA - ITALY
I
moved the hour pipe.. perhaps a bit too much... I'm gonna let her run and see ( should have marked the darn wheel)
BTW .. I notice that the hour pipe - the cannon pinion and the smaller pinion are all scratched to mark a particular tooth - if they were all aligned would that be the way to go?presumably that would set the hands to 12 ?
5,033
623
I
If there are original marks on both wheels, yes, they should be aligned. However, it is possible that a later repair person marked them incorrectly, so don't be disappointed if the marks don't solve the problem. The advice given above is good. You may have to find the right spot by trial and error.
Staff online
163,467
1,420,407
84,873
michael.winstock@btintern
2,857
Aurora's 15 Ruby Jewel Movements by Greg Frauenhoff
Copyright © National Association of Watch and Clock Collectors Inc (A 501c3 non-profit corporation). All Rights Reserved.
