• Upcoming updates
Compound Slide setup
NewBernWatchmaker
Jun 1, 2018
31
39
New Bern, NC
what do y’all think? I know it isn’t ideal but I just can’t afford what people are asking for watchmaker size compound slides. I had the plate milled which indexes in the t-slot of the lathe and will put this bench lathe rest at a workable height.
8B4BCBE9-61B8-4A92-9E5C-302A45AEB3F7.jpeg 9F84FD00-FA8A-46D3-AEAE-1EF5C8898EAF.jpeg
karlmansson
Apr 20, 2013
3,105
362
Linköping, Sweden
Clever!
So long as the angle and level between lathe bed and compound can be kept solid it should work. The problem that I can spot however is how the plate would flex under load. The loads for watchmaking use will still be very small but the weight of that compound must be at least the weight of the lathe. So moving that mass around may be enough to cause some flex in the plates. I Think the best way to figure our if it's a problem would be to make some test Cuts and measure. Do different DOCs and different feed rates to test different loads on the plate.
Regards
Karl
Reactions: NewBernWatchmaker
Similar threads
C
Replies
Views
1K
cubehead
C
S
Replies
14
Views
6K
Niall
N
178,934
1,569,426
54,018
JBowers
909
3,087
Private Label Watch by Kent
