Columbus Pocket Watch (ca. 1880)
RexinMinn
Sep 10, 2022
33
13
65
Recently this watch was serviced. Within two months its minute hand began to slip. I retired the watch for a few weeks and upon rewinding it found it to be working correctly again. Regardless of that I returned to the horologist who checked it on an electronic beat reader and pronounced it fit for service. Now the problem is happening again. I will wind the watch fully. I will then watch as the second hand continues, but the minute hand does not move. In a few minutes the minute hand begins to move and the watch seems to run well. What could be the problem? Is there something I can do as an untrained person with some skill and a few tools. Please see photos.
Columbus Arabic 1.jpg Columbus Arabic 2.jpg Columbus Arabic 3.jpg Columbus Arabic No Case best.jpg
RexinMinn
Sep 10, 2022
33
13
65
I'm not an expert, but many will probably respond that the cannon pinion needs to be tightened.
More than likely this will require a trip back to the horologist who originally performed the work. Is this something that can be done while I wait for the watch? I appreciate the answer, at the very least it's a start. It gives me hope that something can be done about this. Thank you!
James Wrobel
Jan 17, 2020
177
125
62
As a further test, when setting the time, do the minute and hour hands stay in sync (pointing the right way)? If so, I think finiteguy is right, and the watch would have to be returned for further service. This would not be a while-you-wait procedure. There are several threads on this forum for slipping canon pinion, and various op-pinions as well.
RexinMinn
Sep 10, 2022
33
13
65
I will take a look at this. I believe they do, but I haven't done such a test.
I will also take a look at the topic of slipping canon pinions as well.
I appreciate your input!
pocketsrforwatches
Feb 13, 2008
309
36
Ticonderoga, NY
Visit site
Probably a loose canon pinion which USUALLY is a simple fix but not always. If there doesn't appear to be much friction while turning the crown to set the watch, that would be another indicator of a loose canon pinion. I would be concerned why the regulator is at an extreme position after servicing. It should be close to centered.
RexinMinn
Sep 10, 2022
33
13
65
I had the same thought regarding the regulator. When I took it back to the service person and they indicated it was running well (using the machine described above) I guess they thought it didn't warrant re-regulating, but that is something I will bring to their attention when I return the watch. Your suggestion is very helpful for giving me the confidence to approach them with these questions, and I greatly appreciate your input! Thank you!
Support the NAWCC
Forum Expense plus NAWCC
Goal
$1,000.00
Received
$360.00
36%
Host server
$250.00
Software support
$250.00
NAWCC operations
$500.00
Expenses
Latest posts
181,330
1,582,210
54,774
Jim Lampros
3,126
Top
