• Upcoming updates
Columbus King
John Pavlik
Dec 30, 2001
2,334
724
Green Bay, Wi
Another recent Columbus acqusition.. Is this a common model..would anyone speculate on the number produced as opposed to the higher jeweled versions.. and yes if anyone feels the need I will accept, with proper payment, a regulator spring and screw set..
Tom Huber
Dec 9, 2000
3,104
263
77
Indiana PA
Hi John, I have a 17J Columbus King like yours with a slightly higher SN. Yours has the original matching Col King dial. Mine does not. Oddly enough, I also had to obtain a regulator whip spring for mine.
I am unaware of what percentage of Columbus Kings were 17J.
Tom
Kent
Gibbs Literary Award
NAWCC Star Fellow
NAWCC Gold Member
Aug 26, 2000
18,747
2,686
Here are the 17-jewel Columbus King watches listed in our data base (which now includes John's watch). You can draw your own conclusions as to the size of the runs:
319,094 - OF
363,639 - HC
364,070 - OF
364,100 - OF
366,931 - OF
367,083 - OF
367,150 - OF
367,446 - HC
367,460 - HC
367,498 - HC
369,116 - OF
369,119 - OF
369,191 - OF
370,864 - OF
371,473 - OF
371,564 - HC
371,573 - HC
371,900 - OF - Last 2 Dgts Ukn
[colour=blue]371933 - OF - Railway King Grade[/colour]
[colour=blue]371984 - OF[/colour]
372,176 - Type not reported
372,267 - Type not reported
Tom, is your watch listed here? If not, would you please share the serial number and details?
The breakdown of the 500,000 series watches, which includes the higher jeweled Columbus Kings, appears on page 361 of the June 2003 Bulletin.
[colour=blue]Edited to add 371933 Railway King & 371984 Columbus King[/colour]
Thanks,
Reactions: Old rookie
Kent
NAWCC Star Fellow
NAWCC Gold Member
Aug 26, 2000
18,747
2,686
I came across a [colour=red]Private Label 17-Jewel Columbus King[/colour] that hadn't been recorded in the data base yet. The above list of these watches has been edited to add it and to show a Railway King that indicates that the 371901-372000 group of serial numbers isn't all Columbus King grade.
Keep in mind that these watches were being built just about the time that U.S. Patent Office awarded priority to Dueber-Hampden for the [colour=red]Use of the Word "Railway" on Watch Movements[/colour].
Kent
NAWCC Star Fellow
NAWCC Gold Member
Aug 26, 2000
18,747
2,686
Open-face or Hunting? How is the dial marked? Lever-set or pendant set?
Thanks,
Tom Huber
Dec 9, 2000
3,104
263
77
Indiana PA
Hi Kent, Mine is 367,056 and is open face and lever set. The top plate is exactly like John's watch as pictured above.
I got mine as a movement only without dial. Mine now has a DS roman dial with Columbus Watch Co in gothic script--not marked Columbus King.
Tom
John Pavlik
Dec 30, 2001
2,334
724
Green Bay, Wi
Thanks Kent..... great info... any watch companies that you do NOt keep a data base on..:thumb:
Past thru ebay recently.. # 313027 Railway King.. Tu-tone movement..17 Jewels... Open face, double sunk dial signed Columbus Railway King.. Lever set..
Danwatch
Aug 15, 2004
25
Thanks,
Kent:
Must pull the watch from the bank to check. I know it is open face, lever set. Will let you know when I retrieve it.
Kent
NAWCC Star Fellow
NAWCC Gold Member
Aug 26, 2000
18,747
2,686
Danwatch said:
Kent:
Thanks! No rush, but when you do, please check if it has tu-tone damaskeening on the top plate. Most of the Railway King movements in that serial number range are tu-tone.
It's probably marked "Adjusted" but is it marked "17 Jewels"? If not, it might very well be a 16-jewel movement. You'd have to pull the dial and check for the lower center jewel to be sure. A lot of Railway King movements are/were reported as being 17-jewel movements because of the upper center jewel, but the Railway King was produced as a 16-jewel movement for years. The 17-jewel Railway King didn't come out until later (i.e., higher serial number) and were marked as such on the top plate.
[colour=blue]P.S. John - Thanks, I did see 313027 on eBay. I recorded it as a 16-jewel watch (because of the above) with a note that the seller said that it was a 17-jewel watch. My experience with the vast majority of the American full plate movements is that if they aren't marked "17 Jewels" (or higher) than they aren't and if they have an upper center jewel, they're most likely 16-jewel movements. Yes, there are exceptions, but they are few and far inbetween.[/colour]
Thanks again,
Danwatch
Aug 15, 2004
25
Thanks,
Still looking...
Meanwhile, SN 371481, 17j Columbus King, identical to the picture John Pavlik posted above. OF, lever set, dial marked "Columbus King" "17 Jewels"
StanJS
Sep 20, 2006
864
599
93
North Andover, MA USA
I'm looking at a Columbus Railway King, 18s, 17J, with a blue choo-choo & "Columbus Railway King" on the dial. Do we have any estimate of how many of these were made? Are they (un)common?
Thanks,
Stan
Jon Hanson
Golden Circle
Aug 24, 2000
17,652
134
Boston, Ma.
www.americanhorologe.com
Th blue dials are much more scarce than the black ones.
Jerry Treiman
Golden Circle
Aug 25, 2000
7,405
5,448
Los Angeles, CA
Kent - if you are collecting "Railway King" numbers, I have 349,861. It is 18-size, open-face, lever-set, 16-jewel (unmarked) with two-tone damasceening, gilded plate screws and gilded whiplash. Dial is double-sunk with upright arabic numbers and red five-minute numerals; "Columbus" is in simplified Old English font in a straight line.
Kent
NAWCC Star Fellow
NAWCC Gold Member
Aug 26, 2000
18,747
2,686
Thanks Jerry!
I've added it to the data base.
StanJS
Sep 20, 2006
864
599
93
The above one is OF, S/N 364,568, Roman 12 hr with a black track and red 5 minute markers dial, Two Tone movement.
Cheers,
Stan
PS. Kent, you (and other researchers) may want to check out this website for research purposes:
http://www.worthpoint.com/
The Worthopedia collects auction prices from all over. Select "Prices" enter "columbus pocket watch" in the search field and you'll get about 200 watches. Many have serial numbers. Regrettably, many do not have movement pictures but there is often enough of a verbal description to fill in many database blanks.
Kent
NAWCC Star Fellow
NAWCC Gold Member
Aug 26, 2000
18,747
2,686
Thanks Stan:
I'll have to look further into this site when I get some time - right now I'm in the middle of poking through J&H's old auctions.
I wonder if this watch (S/N 364,568) is really 17-jewels. I think (but I may be wrong) that all of the 17-jewel Railway Kings are marked "17 Jewels" and are nickel damaskeened movements - no tu-tone gold.
StanJS
Sep 20, 2006
864
599
93
I wondered the same. However, it is smack between two 17J (364,100 & 364,756) watches in Sam Kirk's database. I decided to take the owner's word.
Also, did you see the Ruby (S/N 501,347) on eBay recently?
Cheers,
Stan
Kent
NAWCC Star Fellow
NAWCC Gold Member
Aug 26, 2000
18,747
2,686
I must have missed seeing S/N 501,347. If you have a link to it, or an eBay number, I'd appreciate it.
Regarding 364,100 & 364,756, just because somebody reported these as 17-jewel, that doesn't make them 17-jewel. I suspect that Sam got those numbers from the Columbus data that Ed and I gave to him a few years back (our report of 364,100 dates to 2000 and 364,756 dates to 1998) and we kept the original descriptions, not knowing any better at the time. Nowadays, we list these as 16-jewel with a note that 17-jewel was reported. However, Sam could have gotten them from the same sources as we did.
Anyway, "conventional" wisdom back then was that if an 18-size, full plate, American movement had an upper center jewel, it was a 17-jewel watch. Only a few people realized at that time that Columbus didn't catalog a 17-jewel Railway King until it became the New Columbus Watch Co. (around 1895 and with higher serial numbers and not having tu-tone damaskeening). Until 1895, all the Railway King movements in the catalogs and ads were described as being 16-jewel. Also, very few people pulled the dial and parts to check to see if it had a lower center jewel.
Greg Frauenhoff knows a bit about this, perhaps he'll add his thoughts.
StanJS
Sep 20, 2006
864
599
93
Here it is: 200260338077
It went around twice with different high starting prices. I was hoping it would sell so it would give me a value for mine. ;)
Understood about the 17J thing. That also crossed my mind.
Cheers,
Stan
Kent
NAWCC Star Fellow
NAWCC Gold Member
Aug 26, 2000
18,747
2,686
Got it - Thanks
Jerry Freedman
NAWCC Star Fellow
Sep 16, 2000
708
30
Re: Columbus King/Railway King
I am sitting here looking at Railway King #230309. It has the blue choo-choo dial and two toned damascening. It is my understanding that all of these which are unmarked as to jewels are 16J. Regardless of the jewel count they are really beautiful watches.
Jerry Freedman
Kent
NAWCC Star Fellow
NAWCC Gold Member
Aug 26, 2000
18,747
2,686
Hi Jerry:
Would that be a hunting (lever-set) or open-face (pendant-set) movement? Is the dial Arabic or Roman?
Thanks,
Kent
NAWCC Star Fellow
NAWCC Gold Member
Aug 26, 2000
18,747
2,686
Nice!
Thanks for posting it,
Greg Frauenhoff
Aug 25, 2000
5,313
3,817
Kent,
Just wondering if the runs in the encyclopedia page that you created for the 16j and 17j Railway King and 17j Columbus King mvts is current or not.
Greg
Greg Frauenhoff
Aug 25, 2000
5,313
3,817
Below are some recent sightings from the internet. I haven't checked to see if any are already on Kent and Ed's list.
Railway King-Htg-16j (unless marked "17 Jewels" all that were seen are assumed to be 16 jewels)
179894
191979
192057
194253, 194395
220314
221066, 221069
224214, 224300
230465, 230485, 230578
245905, 245999
249708
284617, 284631
309106
345088, 345279
354261
364592
Railway King-OF-16j
192245
204732
215378
230834
231154
312805
313004, 313054
344484, 344564
349617
350001
356259
364431
Railway King-OF-17j
366875
Columbus King-Htg-17j
363020, 363620, 363664
367419
371079, 371261
372009, 372190, 372269
Columbus King-OF-17j
368885
370937
RWK Special-Htg-15j
252468
317601, 317610
RWK Special-OF-15j
254130
282207
340457
RWK Special-Htg-16j
284899
Allan C. Purcell
Feb 9, 2013
3,778
2,039
Germany
A novice lover of Columbus pocket watches , would like to know if a watch is engraved "New Columbus watch company" and the number is in the 200000 range is it a new number, or has it been carried on from the old company?
Allan
Kent
NAWCC Star Fellow
NAWCC Gold Member
Aug 26, 2000
18,747
2,686
Kent,
Greg
If you check at the bottom of the Columbus Watch Co. Encyclopedia page, you'll see that it hasn't been updated in about 3-1/2 years.
Thanks for the serial numbers - about half were new to me.
Allan C. Purcell
Feb 9, 2013
3,778
2,039
Germany
Thank you, Kent, for the information on Columbus watches, I have read all three, though I must read them over and over, so I have printed them out.
Thanks again,
Allan.
Greg Frauenhoff
Aug 25, 2000
5,313
3,817
Allan
If it's marked "New Columbus" then it was finished after 1894 by the New company. Whether it was in process by the old company or started completely from scratch by the New one is an open question. Many makers started large blocks of mvts (as in assembling matching plates and bridges, jewelling them, etc., but without completing the engraving and damaskeening) which were set aside and finished as needed (for an example see the Bulletin article on Elgin's grade 274). It's possible that this is the case with your 200,000 range watch.
Allan C. Purcell
Feb 9, 2013
3,778
2,039
Germany
Hi Greg, you are quite right. Quote from "Part 2" "At first, the new company´s movements were a continuation of those made previously, some of which were described in Part 1". I will send you the details of the watch if I win the auction tomorrow. If I don´t I will send you a PM with the details.
If the above is correct, and I have no doubt it is, I would say it´s a King with 16 jewels.
Allan
Allan C. Purcell
Feb 9, 2013
3,778
2,039
Germany
The New Columbus Watch Company, watch I was looking at is sold. I did not buy it. S/N 283102 Adjusted, Safty Pinion, AWW-Co. coin silver case. No jewel numbers.
Allan.
Allan C. Purcell
Feb 9, 2013
3,778
2,039
Germany
After reading the above, and Kent's research, I bought a private label Columbus watch for John P. Mill, Toronto. On seeing the top plate, I must admit I was a little disappointed, all that was on there was the S/N 163287 and "Safty Pinion" (See below) So I bid on the starting price and got it. Of course, the postage and import duties double that, but what the hell, it´s a Columbus, and it runs. I have asked the seller about the photograph, but no reply. I can only guess at the jewel count, 15? the date would be 1891, so before they re-organised in 1894. The case is not coined silver, it´s one of those Ore-Silver things that hide the word, Nickle. Nice dial though. Not too keen on these screw on´s back and front, but know how to work them from my Hampden.
Allan.
thesnark17
Jul 11, 2020
250
289
Yes, between the Breguet hairspring, the whip regulator, and the screwed-in jewel settings, this is a 15 jewel Columbus, and a better grade at that. I really like that chain-pattern damascening.
Michael Post
Mar 20, 2018
13
Southern California
I have a Railway King, s18, 16j in a Michael Cronin 14k hunter case #9680 with both Crown and MHC monogram. Would that case have been supplied by the Columbus factory or is this an after market swap? Watch is an 1894 and it seems like the case was made much earlier. This is all new stuff for me.
Kent
NAWCC Star Fellow
NAWCC Gold Member
Aug 26, 2000
18,747
2,686
brg404
Feb 9, 2006
45
72
Railway King OF/16 jewels Two-Tone Gothic Script "Columbus Watch Co" double sunk dial. Pendant set movement.
230916
Reactions: Kent
179,913
1,569,442
54,316
edflaherty
911
3,090
