Coil springs?????????
The Tick Doc
Dec 30, 2007
204
72
South east USA
I am working on an old German Bim Bam, and i need to replace the hammer return springs and the compresion springs on the fly. I know TS has an assortment, but I dought it will have what i need. Is there a retail supplier out there some where? I do have some brass spring wire, but even the smallest guage is to large. If push comes to shove I will try to make my own. The return springs are about the diamiter of newer clocks but are much longer and the springs on the fly are conical and very thin. Thanks in advance ............TTD
Mike Phelan
Dec 17, 2003
11,157
440
West Yorkshire, England
It might be easier to obtain steel wire instead of brass to make the springs? Why do they need replacing, and have you some pics?
Is the fly spring flat, as a bit of scrap watch mainspring might do.
The Tick Doc
Dec 30, 2007
204
72
South east USA
Hello Mike, The ckock was mis handled as it was being delivered to me and the hammer return springs were badley streched out ot perportion. I put some shorter springs from a scrap movement on it and this causes too much pull,, still working with that.. I have not seen any steel wire stock this thin,, thanks for the thought...........TTD
Jerry Kieffer
May 31, 2005
3,196
808
wisconsin
You can always Google what you need, but if you can`t find it, you can try the following
Spring wire is available down to .006" to wind your own from Small Parts Inc.
http://www.smallparts.com/?tag=smallpartsgoo-20&hvadid=13180864279&ref=pd_sl_9gv3pcruk_e
Just about any spring is available from Century Spring
http://centuryspring.aiprx.com/?teng=go&geng=br&aeng=1
Jerry Kieffer
Mike Phelan
Dec 17, 2003
11,157
440
If you're in the USA, TTD, then go for Jerry's suggestion. Here in the Old World, any model or music shop will have steel wire of all sizes; many internet shops supply boxes of assorted springs.
For me, anything I scrap, like a worn out printer, washing machine, whatever, I strip out any useful parts like screws, washers and springs. I call it my "spring collection" [sorry!].
Support the NAWCC
Forum Expense plus NAWCC
Goal
$1,000.00
Received
$360.00
36%
Host server
$250.00
Software support
$250.00
NAWCC operations
$500.00
Expenses
Staff online
181,321
1,582,114
54,769
Rod2
3,126
Top
