Cockoo Music cam
glandry
Dec 31, 2012
13
Halifax , Nova Scotia
Not sure how the cam mounts. Does anyone have a photo showing how it should look?
Is arm "B" suppose to ride the edge fo the cam "A" ( see attached )
MuensterMann
Mar 23, 2008
1,483
19
Seems that A and B are related due to their locations. Intuition says that the arm does ride the edge of the cam or the cam hits the arm at certain points. I will look in my pile to see if I have a clock that still has the lever/cam setup - and I will take a photo of it for you. MM
46,713
1,912
Yes, 'A' will slip into the slot on the cam to allow the music man to withdraw into the case when the music stops. You may have to alter the wire angle or cam position to be sure it functions correctly. This is the only option for putting a music man in a case now. The other kind of music box is discontinued.
glandry
Dec 31, 2012
13
Thanks.... Its now installed and seems to be working fine...
166,190
1,447,853
86,722
VinSer
2,882
