Clock Stand
bbodnyk
Aug 14, 2009
491
Harrisburg, PA
I thought I'd share my new clock stand. A few years ago I sold all my wood working equipment to my sister who has become an accomplished woodworker. Needing a stand to work on weight driven movements I gave Ann some general specs for what I was looking for and the attached pictures show the result.
The stand is made of white oak. The top frame uses finger joints and the vertical supports are mortised into the top and bottom. I was looking for a clock stand that would look good in my living room, what I got was a piece of furniture that I can use as a clock stand!
Bruce
wow
Jun 24, 2008
7,749
1,768
78
Pineville, La. (central La.)
Beautiful! Looks more like a piece of furniture than a clock stand. One like that would not fit the décor of my shop.
Will
Kevin W.
23,758
807
65
You have a great sister, i like the stand looks very well built and will last many years.
bbodnyk
Aug 14, 2009
491
Harrisburg, PA
The inside opening is 16"x12" which should hold the largest weight movement short of a tower clock and it would probably hold a small one of them. More practically the size allows several movements to be mounted on it at the same time. Each of the legs has levelers so the stand is very secure and easy to set up to be level. It's about 48" from the floor to the top.
I will share your comments with her! I told her she should sell them.
Bruce
bangster
20,022
620
Did you put oil on the movement to make it shiny like that? :whistle:
bbodnyk
Aug 14, 2009
491
Harrisburg, PA
The movement was one of two that went thru a fire and were pretty blackened. The plates are lacquered. The brass parts were warmed in the oven and wiped/polished with bees wax. I wanted the first movement I used the stand for to match it in quality! LOL
caddwg
Jul 4, 2012
234
Costa Mesa, Ca
Bruce: Beautiful job! You and your sister should definitely be complimented and proud; You for the design and your sister for the great effort. Good luck and use it with pride. Larry
183,937
1,606,551
55,953
J.P.T.S
3,190
Watch case by Kent
Top Bottom
