Clock Project
Discussion in 'Tower, Monumental & Street Clocks' started by le arsi, Apr 20, 2014.
  1. le arsi
    le arsi Registered User
    Jul 7, 2008
    461
    Watchmaker,tower clockmaker, watch repair teacher/
    Philippines
  2. Kevin W.
    Kevin W. Registered User
    21,688
    220
    Where is the main spring.:eek:
  3. le arsi
    Jul 7, 2008
    461
    Philippines
    It uses weights, see the cable going under the platform?
  4. David S
    David S Registered User
    Dec 18, 2011
    7,169
    233
    Brockville, On Canada
    Weight driven see the spool with blue wire / cable on the top left.
  5. Kevin W.
    21,688
    220
    I missed that, not awake yet, Le Arsi did you make this.
  6. bptanguay
    bptanguay Registered User
    Apr 5, 2012
    198
    12
    Watchmaker
    Massachusetts
    The weights are hooked up to the wrong wheel. the pulley should be on the bottom wheel, not the escape.
    But then again, who knows, it just might work. Looks like a weekend project. Where did it come from.?
  7. gvasale
    gvasale Registered User
    Mar 30, 2005
    1,194
    webster, Ma
    There's no grass around it...looks like "lawn art" to me.:cuckoo:
  8. shimmystep
    shimmystep Registered User
    Mar 5, 2012
    4,085
    75
    Cambridge, UK
    Escapement wheel is not an escapement wheel. Verge has no proper impulse faces. Pendulum directly attached to verge arbor....................................................
  9. David S
    Dec 18, 2011
    7,169
    233
    I tried to focus in on that Shimmy, but couldn't determine that. How did you figure that out.... or are you just BSing us? :)
  10. shimmystep
    Mar 5, 2012
    4,085
    75
    Cambridge, UK
    lol, no BSing, moi?!
    I enlarged the pic. The EW is a normal toothed wheel, not an EW The verge is a strip of metal with the ends bent over
  11. leeinv66
    leeinv66 Moderator
    Mar 31, 2005
    9,556
    127
    Industry Specialist
    Launceston Tasmania
    I don't think it is a clock movement! I think it is a clockwork rotisserie
  12. le arsi
    Jul 7, 2008
    461
    Philippines
    No Kevin, a group of graduating students made this as part of their thesis project called solar tracker that is motor less. They found a clock diagram in the internet and commissioned a machine shop to build it for them. So everybody has no clockmaking background that's why they found me.
  13. shimmystep
    Mar 5, 2012
    4,085
    75
    Cambridge, UK
    Back to the drawing board then...:)
  14. le arsi
    Jul 7, 2008
    461
    Philippines
    When the project did not work as they expected they were forced to find a clockmaker and found me. After an agreement I started to work. First I discovered that 3 of the ball bearings were damaged that's why there is no free motion when I first test it. 2013-12-03 08.21.26.jpg
    I replaced them with new but decided to use the ID of all the ball bearings as bushings because the bearings has tight friction. So I reshaped all the pivots. Transfer the weight to the first wheel and I got the free wheeling motion of the gear train.
    Made the dial train to drive the solar panel but with teeth combinations calculated for the solar panel face to rotate at 6am to 6pm. 2013-12-25 14.30.35.jpg 2013-12-25 14.30.49.jpg
  15. leeinv66
    leeinv66 Moderator
    Mar 31, 2005
    9,556
    127
    Industry Specialist
    Launceston Tasmania
    How is it regulated and how was its BPM calculated? I assume it has to be manually reset after each cycle?
  16. le arsi
    Jul 7, 2008
    461
    Philippines
    Yes, the important according to them is to make the solar panel rotate in time with the sun. I calculated the wheel teeth and the pinion leaves and came up with 4320BPH that become my target freq using my Microset. From that freq I calculated also the length of the pendulum to be at aprox. 27 inches long.
  17. harold bain
    harold bain Registered User
    NAWCC Member Deceased
    40,850
    143
    deceased
    Interesting project. How will you keep the wiring from getting twisted if the panel makes a 360 degree rotation every day? Might work better using a cam that resets the position daily.
  18. le arsi
    Jul 7, 2008
    461
    Philippines
    Sharp eyes Harold! That's another thing, making a rotating slip contact or that cam you said.
