Hello, I have been working on clocks all my adult life. Mostly the vintage ones from the early 1900's. I have a few electric clocks from the 1930's that I have restored.
On to my latest project, I have a clock manufactured by the Electric Time Company, and I'm wanting to replace the motor from a 24vac to a 110v. I need some help in where I can locate one. The reason for my motor switch is the system that the clock movement works with is a controller and acquiring the electronic controller is $900.00. If I can get a 110v motor it would not cost that much.
Motor information:
10 tooth gear
24vac 60Hz 150ma-2.5w
Saia-burgess made it
If I can find out who makes the movement that would give me some place to start.
Thanks for any help.
Motor information:
10 tooth gear
