Earl Stedman;881303 said:Looking for motor or movement for early Mastercrafters 551 this one has no plastic parts.
Earl Stedman;881383 said:Jay let me know if it is something you would part with. Tom HTH ?
Still looking for this mainspring barrel and cover. I was asked what are the dimensions between arbors and the minute wheel on another site, here is the info and hope this will help:John Hubby;879194 said:I need a mainspring barrel and cover for a Kienzle time-strike movement made about 1900-1910. Here are the specs:
Barrel diameter: 35 mm OD, 32.5 mm ID
Barrel tooth diameter: 38.8 mm OD (1.525 inches)
Barrel tooth count: 76
Barrel depth, front to back: 22.5 mm
Front arbor pivot diameter: 7 mm
Rear arbor pivot diameter (barrel cover pivot): 6.5 mm
Nominal spring size: 18 mm x 32 mm
Any barrel that meets the barrel OD, barrel depth, and barrel tooth OD and tooth count will work. I have the winding arbor and can bush the barrel and cover if the pivot holes aren't exactly the same size, Main thing is barrel OD, tooth OD and count, and barrel depth.
Please PM me if you have one available. Thanks in advance for your help!!
Hope This HelpsEarl Stedman;881383 said:Tom HTH ?
If you can find the completed auction by doing an advanced search, I would look for the original listing. Then I would go to other sales that the seller might have going, open one of them and send an e-mail to the seller asking if he would mind contacting the buyer of these hands and having him/her contact you.dannyboy;881606 said:
Walt Wallgren;887723 said:Hi,
I am looking for a single, brass chime rod. 11.75 inches long (not including the screw end, 3.2 mm in diameter, I believe it to be a 6.4 mm screw. It is for a GB bracket clock with Westminster chimes.
Thanks,
Walt
