Clock parts wanted Obsolete older posts II
Coolyus5712
Sep 13, 2009
207
89
Need Part For 132-071
274272.jpg Need this part for a Hermle -132-071
Chris
NAWCC Business
Nov 4, 2001
2,499
7
Ellsworth, Maine
clocksbychristopher.com
Re: Vienna regulator pulleys
Looking for 10 inch dial and bezel for a chain drive grandfather movement. I have a fairly newer inlaid bombe tall case that has a crappy battery movement and unappealing dial. I want to install a Kieninger mantel clock movement that I have and a nice dial / bezel. Ideally, the dial should be about 10 inches, but can be a bit bigger. 274862.jpg 274863.jpg
igotsteel
Jul 11, 2016
Chelsea Clock Parts
Hello all. I need to replace the hands on a Chelsea Wythe House Clock. I have looked for parts, movements, how-to's, maintenance, care, setting, diagrams, you name it, and so far I have not been able to find a single spec. on these clocks. Anyone having any info. at nall. all, please let me know.. Thanks in advance for help..
Jim_Miller
Mar 6, 2001
912
17
74
Jackson, Michigan
Re: Looking for regula 34 Cuckoo gong arm
QuietMike;1045382 said:
Does anyone have the arm that strikes the gong / and or the gong for the regula 34 movement?
QuietMike
Jun 14, 2016
19
Orangevale, CA
It is, but I was able to find a shop online that had the set and a couple of other prices I needed
thank you though
Jim_Miller
Mar 6, 2001
912
17
74
Jackson, Michigan
thank you though
Not a problem, I'm glad you found what you needed.
Jim
Jay Fortner
Feb 5, 2011
5,070
41
Chiefland,Fl.
I'm in need of an empty brass weight shell for a modern GF clock to make a faux boiler/ballast tank for a steam engine powered clock that will run off an aquarium compressor. A 40mm shell would be preferred but I'll make a 60mm shell work. I'm trying to keep the size down to where it will all fit under a standard size torsion clock dome.
Don't need end caps or rod, I would prefer a polished finish with no dents and OK if tarnished.
Thanks, J.
igotsteel
Jul 11, 2016
Re: Chelsea Clock Parts
Thanks for your interest and reply. Since my post , I have contacted Chelsea Clocks and they said no can do. The Wythe House clock has been out of production since the 1970's. The hands on clock would need to be repaired to keep it original.
MLSchlot
NAWCC Business
Feb 10, 2001
511
20
Fairhope, Alabama
thesandsoftime.biz
Re: Clock Parts Wanted
I'm looking for a Hermle 791-081 (or *81) movement to cannibalize for parts. Specifically, I need the complete strike hammer arbor. Any help is most appreciated.
Regards -- Mike
sewers0000
Oct 19, 2013
29
e howard #70 original style suspension spring
Looking for e howard #70 original style suspension spring. Thanks
502*cmk
Dec 17, 2009
Louisville, KY
Urgos Clock hands wanted
I have a Urgos G/F clock (including the dial shown) like shown in the picture attached, but do not have the hands. Have some newer hands like shown on 258399.jpg e-bay but that's not what I need. If any one has some hands like in the picture please let me know. Minute hand is 4 3/4" from center, 5" over all.
R&A
Oct 21, 2008
4,218
109
Re: Urgos Clock hands wanted
You should post this in parts wanted. Might have a better chance
kinsler33
Aug 17, 2014
3,922
614
75
Lancaster, Ohio, USA
I am looking for an 18-tooth cuckoo music movement. Nobody seems to sell the things. What I really need is the large gear that lives on the end of the pin drum, but this seems to be integral with the drum itself, so I'll do what I can with the drum/gear combination--I'm not sure that the customer knows what the original tune was, anyway. The gear teeth were worn down through what I assume was massive abuse--it had to have been a child--and I can't think of a way to restore them. Here's a picture of the original:
Mark Kinsler
R&A
Oct 21, 2008
4,218
109
Re: Kieninger HS-020 Hand Shaft Needed
What is wrong with the one you have??
upstateny
Oct 2, 2015
571
The complete end of the hand shaft is broken off and the shaft is bent 30° in two places one next to the front plate and another in between the motion works. More $ to make a new shaft thank the movement is worth.
502*cmk
Dec 17, 2009
Louisville, KY
View attachment 4182 Urgos Clock hands wanted
I have a Urgos G/F clock (including the dial shown) like shown in the picture attached, but do not have the hands. Have some newer hands like shown on 258399.jpg e-bay but that's not what I need. If any one has some hands like in the picture please let me know. Minute hand is 4 3/4" from center, 5" over all.​
WRabbit
Jun 1, 2016
194
Texas
Marti Hand(s) Needed
I'm looking for a minute hand (or set) for a Marti movement.
Minute Hand - arbor center to tip - 41mm/1.61"
(this is as close as I could guesstimate)
Hour hand - arbor center to tip - 36.5mm/1.44"
Any help appreciated.
Jim
Alfred Coombs
New User
Dec 19, 2012
Junghans 103 movement
I am looking for another Junghans 103 (1910-1920?) movement as I need a new music box wheel that drives the hammers on the back.. The extension shaft of the music box wheel protruding through the 2 small brass funky looking plates shaft has snapped off and must be replaced.. If I have to get the entire motor then so be it... Please PM me or call me at 617-504-3687... I do not check this website very much so it would be easier to call or e-mail me at ticktockboston@yahoo.com Thankyou
CJo
Aug 22, 2005
508
11
66
southwest Kansas.
Seth Thomas Lincoln gong
279664.jpg I am looking for a gong for my ST Lincoln. This is a picture from Tran Duy Ly book. Please PM me, if you have one to sell. Thanks
- - - Updated - - -
I thought I was putting this in 'parts wanted' but that is not where it went, could someone move it there please.
Robert Manke
Dec 9, 2015
17
W&H Cottage Clock Pendulum
Any suggestions where to look for a W&H cottage clock pendulum would be appreciated. The pendulum has a side hook. An example of what I'm missing is shown.
Bob Manke
Chris
NAWCC Business
Nov 4, 2001
2,499
7
Ellsworth, Maine
Seth Thomas Roller jewel needed
I need a roller jewel for a Seth Thomas "Regatta" ships clock and barometer set. It has a Seth Thomas 115D movement in it and the platform has three mounting screws. Help appreciated, Chris.
Jim W
Sep 1, 1976
47
89
New Jersey, USA
I have a Chelsea instrument chart driver movement which appears to have the same platform escapement as the Chelsea Radio Room clock (which I also have).
email me at jimsyb@att.net if interested.
Karl Burghart
Jan 30, 2012
219
33
Ballston Spa, NY
Not sure if this would be better in the watch parts section but I'm looking for a balance wheel and hairspring for a Jaeger Le Coulte Rue De La Paix street light clock. Movement is caliber 229.
Ralph
Jan 22, 2002
5,516
463
I need the autocorrect arm for a Seth Thomas 124 movement. The arm is the same on the electric version of the movement. There are more than one version. I have a different one than the image I'm including, but either or any will work. It's the brass on in the center of the image.
Thanks, Ralph
roman16
Mar 4, 2006
128
Clock movement needed for repair. 30 hour weight Boardman Movement.
Hi. Does anyone have this exact movement available needed for a restoration project. It's an early 30 hour Boardman weight movement. Sometimes unsigned which is unimportant. I've attached a picture for reference. Notice the arched cutouts in the front plate, 1st main time gear in front at the top of the movement, 1st main strike gear in front on the bottom of the movement, escape wheel bridge fastened at 3 o'clock position, and two rivets at 4 and 10 hold the bridge on the front plate. If you need better pictures for reference the movement is pictured in Horology Americana page 163, and in Roberts Connecticut Clock Technology book one page 240, revised edition page 284. You can also see examples in the NAWCC Bulletin, # 221, Dec 1982, pages 765 (Fig 78); 767 (Fig 82); 768 (Fig 83)." Please feel free to email me directly with questions/pictures/price at reservistsrcool@yahoo.com. Thanks.
shimmystep
Mar 5, 2012
4,110
102
Cambridge, UK
Re: Clock movement needed for repair. 30 hour weight Boardman Movement.
Prob need to put the pics in the post :)
roman16
Mar 4, 2006
128
Thanks. got the picture up this time.
Steve DCW
New User
Sep 21, 2016
1910-1920 (?) Hamburg-American count wheel assembly
I have what I believe to a Hamburg-American movement dating to 1910-1920 that, according to my horologist, is missing its count wheel counting cam, pinion, all attached to an arbor.
The numbers on the movement are 141/36, with the number 200 underneath.Here are some pictures.
281728.jpg 281729.jpg 281730.jpg 281731.jpg 281732.jpg 281733.jpg 281734.jpg
In the last picture, the number 15 indicates the wheel and some of its associated parts.
Can anybody help me locate these parts - or even a complete movement?
Thanks for any help.
RJSoftware
Apr 15, 2005
8,796
260
Loxahatchee, Florida
Re: 1910-1920 (?) Hamburg-American count wheel assembly
Junghans and HAC often have interchangeable parts. Junghans took over HAC I think they used same equipment. Junghans parts movements are easy to get. Also, they both have the unmistakable large middle wheel between the two mainspring wheels on unmarked movements.
RJ
Walt Wallgren
Aug 16, 2012
1,223
34
Bay Area, California
New Haven Pendulum
HI I am looking for a pendulum for a New Haven Nyanza or Waring banjo clock. The one I am looking for is about 4.5 inches in diameter, has a very short wood pendulum rod that hooks into the steel suspension spring/pendulum rod assembly. Any help would be appreciated.
Walt
Frank Manning
Nov 22, 2005
351
Vernon, CT
E. N. Welch verge and crutch for weight driven wall clock
Hi,
I am in need of a verge assembly for a weight driven E. N. Welch clock. It has two spools that wind up the cables for the weight. I can send a picture of the movement if needed.
Frank Manning
48,936
2,695
Re: E. N. Welch verge and crutch for weight driven wall clock
Frank, it would be helpful to know the number of teeth on the EW, and whether it is a recoil or a deadbeat type. Could you supply that info please?
LeeRex
Feb 17, 2016
Wanted: Urgos escape wheel
I have an old Urgos 7/106 that needs an escape wheel and especially the proper arbor! Finding even a mention of this particular model has been difficult. Anyone know where I can find such a thing?
502*cmk
Dec 17, 2009
Louisville, KY
Model 'Gard"  Waterbury Crystal Regulator
Looking for the "trim" or bead work, that went around the top middle finial of this 1912 Waterbury model "Gard" clock. 284003.png
f.webster
Dec 18, 2009
980
101
Louisville, KY
Re: Need a platform for a Chelsea clock #645991
I have all the parts for this Jahresuhrenfabrik Carriage clock. Some say it is a throw away clock; however, I want to restore it. The movement looks great however, the music box mechanism is in bad shape. I am looking for a complete musical assembly. I can make one good assembly out of two if the comb is in fair shape. This comb has 36 teeth. A similar mechanism (more or less teeth) having a drive gear at the end of the cylinder would (might) work. FYI that gear has 30 teeth. I don't know how critical that is.
Thanks for looking though you stuff.
Chris
NAWCC Business
Nov 4, 2001
2,499
7
Ellsworth, Maine
Jauch 64 mainspring movement needed
I'm looking for a complete, rebuildable Jauch 64 mainspring wound grandfather movement. The one I have in for repair was damaged by the owner. He brought it in and I don't know if he fiddled with the pallets or not, but if I set the lock and release so that it doesn't hang up on a tooth, the depth is too shallow and it stops.
I also need a leader for a PL96 Jauch tube chime movement.
clockdoc01
Feb 1, 2008
65
E Howard 70 Center Shaft Needed
Working on a Howard 70 wall clock and the center shaft was broken off even with the front plate. Looking for another shaft or someone who can make one fairly quickly. I have the brass gear, would just need the shaft and pinion assembly made or a complete replacement gear if a doner is available.
Thanks,
Keith
48,936
2,695
Re: Jauch 64 mainspring movement needed
It's going to be a tough one to find. Your best bet is to post some pictures and inquire about repairing it in the repair forum.
RJSoftware
Apr 15, 2005
8,796
260
Hey Chris. Why not redo the palettes? If they are metal only and you have a propane torch you can wrap the pallet with iron wire and heat it up red hot. The wire wrapping will prevent it from cooling fast and that will enable you to bend the palettes and see if you can improve the lock/drop situation. Bend small increments one way (in) and see if that improves, else spread/bend other (out). Also consider that in some instances people will flip a palette to make a recoil type into half deadbeat or vise-versa. A recoil needs no impulse angle but half dead beat will usually have impulse angled on ends of palette. Deadbeat is more accurate, recoil is more robust to run.
But first establish that your ew teeth are not bent. Use high power loupe. On each ew tooth is a straight side. With tweezers or small needle nose pliers gently pull each tooth tips out straight with the straight side of tooth. No curved (sharks teeth). Also know if one or more of the ew teeth have been shortened even a hair of length the impulse will eventually stop. They all can be brought to same height by removing a gnats hair by turning on lathe with a stone. But you have to be careful not to remove too much. Just enough to see a little effect on ew tips. Then straighten that out with needle nose as mentioned.
RJSoftware
Apr 15, 2005
8,796
260
This clock has a few copy manufactures. Same design for gear engagement too. Check German clocks like Mauthe (FMS) as some go cheap for parts on the bay. You might even be able to land a comb. Looks like 36 teeth. I know repairing a comb is near impossible as the teeth even have lead attached to fine tune. You might be able to adapt a good comb with different screw holes by drilling. Music boxes are cheap at the Goodwill.
RJ
devore
Mar 13, 2010
65
20
French Pendulums Wanted
I am in need two old French clock pendulums like the attached pic (with the bob center adjustment).
I need one 4-1/2" from the hook to the bob center & one 5-1/4" from the hook to the bob center (both w/ some remaining adjustment).
I prefer antique originals vs new replacement ones.
Thx!
176,432
1,544,321
53,306
Boriss_k
1,064
3,031
