Clock parts wanted Obsolete older posts II
DC George
May 30, 2014
42
near Flint MI
Finding a correct replacement verge
Hello everyone,
I'm trying to find a replacement verge for two movements that are identical. (Brewster&Ingrahams 8 days) I counted the escape wheel teeth to be 46 and in the timesavers catalog it says the number of teeth to be embraced should be 10. Is the teeth embraced the number of teeth between the two pallets of the verge?
Any help you can offer me is greatly appreciated, I don't want to order the wrong part.
cheers, DC
13,666
88
Re: Finding a correct replacement verge
Yes, they mean the teeth between the pallets.
Fitting pallets require more than a tooth count.
It is unlikely that a verge ordered from a catalog will work
without some adjustment.
Are the originals recoil or deadbeat?
tinker Dwight
DC George
May 30, 2014
42
near Flint MI
Thanks. I had figured on them needing some modification to work properly since they don't sell verges for individual movements. They are recoil.
bobclock0
New User
Jul 25, 2012
W & H clock
hi can you help i need the 4th gear from a w &h bracket clock .from the ting tang side thanks bob
shimmystep
Mar 5, 2012
4,110
94
Cambridge, UK
Re: W & H clock
Hi Bob
it is pretty unlikely you will find a straight replacement. And may need to have one made and mounted. What is the damage? have you pictures? is it repairable by fitting a new tooth or two?
bobclock0
New User
Jul 25, 2012
Re: W & H clock
hi the brass gear as melted (to much heat)and the spigot is damaged thanks for the reply .bob
G
gww
Need Seth Thomas 5165-A movement or parts, where?
Hello,
I posted a number of years ago looking for an escapement, back plate, and associated parts. This is one of the old Navy Bakelite cased clocks with a 6" dial. I would really love to get this old clock running again. It needs a 5165-A movement. At the very least I need a new style escapement part no. R-20666, Back Plate no. R20709, and screws R18531.
Thanks for any help.
George
Keith Doster
Mar 31, 2011
399
64
66
Chester SC
Kieninger HTU 9 tube parts needed
Greetings. I am looking for the escape wheel and verge assembly for a Kieninger HTU 9 tube GFC movement. Picture is attached. Since this is a jeweled movement, I don't have high hopes that anyone has one of these sitting around in their parts bin. But hey, stranger things have happened.
I am also open to suggestions as to where I might find these parts. I checked with Butterworth's and they suggested I check with Black Forest Imports. I'm going there next, but thought I'd stop by here first.
Thanks!!
Keith Doster
Mar 31, 2011
399
64
66
Chester SC
Re: Kieninger HTU 9 tube parts needed
PS to the above post: BFI has the verge, but no escape wheel and no access to one. sigh . . .
Dick Feldman
Sep 1, 2000
3,038
447
Colorado, usa
What is the matter with your escape wheel/verge assembly?
David LaBounty could make an escape wheel, if needed.
Dick
Keith Doster
Mar 31, 2011
399
64
66
Chester SC
Hey Dick. Someone (else) tried to adjust the pallets and damaged the escape wheel teeth. Plus the clutch mechanism on the verge is quite loose. I am assuming there is no practical way to repair that clutch, but I can get a new verge reasonably priced from BFI. They don't carry the EW. Looks like I may be giving Mr. LaBounty a call if no one has this lying around.
Dick Feldman
Sep 1, 2000
3,038
447
Colorado, usa
Keith,
I sent you a PM on this
Dick
shimmystep
Mar 5, 2012
4,110
94
Cambridge, UK
Re: W & H clock
Sounds as though you will need to get a new wheel made. Can you post a picture? I don't know what you mean by 'spigot', I understand a spigot to be a valve/tap, not something you normally find on a clock :)
harold bain
40,853
190
73
Re: W & H clock
The damaged spigot could be why he couldn't put the fire out til after the gear melted.:whistle:
shimmystep
Mar 5, 2012
4,110
94
Cambridge, UK
Re: W & H clock
Good detective work harold, it's all become clear :)
bangster
20,024
577
Re: W & H clock
I get it. No water. :Party:
gleber
Jun 15, 2015
1,969
267
Downingtown, Pennsylvania USA
www.myclocks.site
Seth Thomas No 10J Escape Wheel
Oops, sorry, meant to reply to the Parts Wanted thread, but hit "New Post" instead of "Reply."
Hi all,
I just bought a Seth Thomas Engine Lever (Ships Bell) clock with a broken escape wheel tooth. I'm looking for the escape wheel or will consider an entire donor carcass if anyone has one available.
Thanks,
Tom
G
Georgegrl
Replacement Motor needed
I am repairing a clock and need a replacement motor. The original is an ingraham model 17. It has 8 teeth. Thanks.
bangster
20,024
577
Re: Seth Thomas No 10J Escape Wheel
Hi all,
Thanks,
Tom
Let me get back to you on that. I may have a lead. When I know something, I'll shoot you a PM.
Gay Laster
Mar 9, 2015
32
looking for a J Unghans Vienna style movement for parts.
I asked if any one out there had an old movement in my first thread. I was asked to post a picture of the movement I am looking for . I'm still trying to figure out how to do that.Hope it works this time. 260178.jpg 260179.jpg 260184.jpg 260185.jpg 260177.jpg
Dick Feldman
Sep 1, 2000
3,038
447
Colorado, usa
Re: looking for a J Unghans Vienna style movement for parts.
Hello,
I have a similar parts movement. It is complete. The lantern pinion on the second wheel time side is missing two leaves. That is repairable but I am not sure of any secondary damage when that went bad. The one I have is quite worn as well. I am not sure of the pendulum length or BPH on the movement as I have not done a tooth count.
What parts do you need? I can measure the hand shaft length, the winding arbors, etc. if you have an interest.
If you want to buy the entire movement or any parts, please send me a PM on this board.
Best Regards,
Dick Feldman
Gay Laster
Mar 9, 2015
32
Not sure if I can name the parts I need correctly. I need the lifting cam on the center arbor that the clock hands are attached to.Also the rest of the lifting train,lower lever lifting assembly and upper locking lever assembly. I'm thinking that I would be interested in the whole movement if it is in my price range. Thanks for the reply,Hope we can work it out. Gay Laster
Dick Feldman
Sep 1, 2000
3,038
447
Colorado, usa
Here are some photos of the movement I have. The time barrel teeth seem to be OK, although the barrel spins due to the leaves on the second wheel pinion missing. I do not have a hammer arm or hammer, As you can see, the pendulum leader is not complete. Someone has soldered some tabs on the bottom of it. Other than that, I think the movement is complete. The white on the rear plate of this movement is residue from some sort of sticker. This one looks very similar or identical to yours.
From your photos, it looks like there may have been some alteration to your time spring barrel. This one looks to be OK.
Email me at Fourburros@aol.com if you think you can use this one.
Best Regards,
Dick Feldman
time is money
Jun 30, 2013
123
Needed Sessions Dulciana minute hand
I have searched the internet extensively to try to find a set of hands or 1 replacement hand for a Sessions Dulciana mantle clock . i did find a photo of a set of used hands which are identical to the one's that I need but they were already sold. Does anyone have a set available for sale or know where I can locate a set? Any help would be appreciated 260690.jpg
newbee
New User
Jan 16, 2016
need parts for antique quail cuckoo clock
Hello all, I am looking for a movement for a large quail cuckoo clock. The movement I have is marked william f sprague and is a cast plate clock. I am finding no parts on ebay for this clock or anywhere else so any help is greatly appreciated.
Thank you.
Newbee
Randy Beckett
May 23, 2012
2,555
27
Mt. Pleasant, Tx
Re: need parts for antique quail cuckoo clock
Hi Newbee, and welcome to the message board.
The first question that comes to my mind is if the movement you have is complete and/or repairable. Could you post pictures of your old movement? Perhaps someone can offer advice on repairing it, or will recognize it and can offer a suitable replacement option.
Dick Feldman
Sep 1, 2000
3,038
447
Colorado, usa
Re: HAMMOND NEON CLOCK SPIN to START MOTOR
I think this would do better in the electric horology part of the board.
Also---if you want to the clock to keep time, it MUST have the correct RPM. Please supply specs from the motor and how about a few pictures, both inside and outside.
It is unlikely you will find a motor, but someone out there may be able to repair yours.
What is wrong with your clock motor?
Dick
Jeremy Woodoff
Jun 30, 2002
4,242
138
Brooklyn
Waterbury time only cottage movement
I'm looking for a Waterbury time-only cottage clock movement. It winds at 11 and there is 1 inch between the center and winding arbors. It was used in several different models; the one pictured is the case I have.
Jeremy Woodoff
Jun 30, 2002
4,242
138
Brooklyn
Jerome mini-cottage movement needed
I know this is a very long shot, but I need the movement and dial for this Jerome mini cottage clock. The movement and dial pictured are from another clock; I have only the case.
tracysharp
New User
Feb 13, 2016
Someone replaced the motor with a battery movement. Trying to locate a Hammond movement that would work. Thanks Dick
newbee
New User
Jan 16, 2016
Hello, It skips on the quail side and it is missing the cuckoo bird rod. I cant see any thing wrong other than the tension wire is missing from above the lift arm. Sorry if my terminology is not correct, I am, after all, a newbee. Thanks for any help you can give.
Newbee
Rockin Ronnie
Nov 18, 2012
1,781
167
Greenfield, Nova Scotia
antiquevintageclock.com
Hi. I acquired a Gustav Becker 2 weight regulator recently. The movement is a GB Braunau #307810 made in late 1902. I am missing a star / snail gear which is located just below the hour / minute gears. The photo below shows the missing star / snail gear.
It would be nice to have the whole movement so that I could interchange parts but if you have a snail / star gear or know of someone who does please send me a PM. It must be from a Braunau movement as the Selisia ones were designed a little differently.
Ron
xrperry
May 23, 2010
319
post falls idaho
new haven santa clara
Hi everybody, i am looking for a minute hand for a new haven santa clara. I dont have a pic but it is kinda Maltese cross looking and brass color
pjbeville@hotmail.com
Feb 18, 2016
Sessions Run and Calendar Movement
I'm looking for a run and calendar movement for my Sessions Calumet Baking Powder advertising wall clock. It has an 18" drop with 1 3/4" distance between winding pinion and minute hand shaft.
Kevin W.
23,446
648
64
Re: Sessions Run and Calendar Movement
Ebay has many stray clock movements.
Bill_Kearns
Oct 16, 2015
20
Clock Parts Wanted
I recently purchased a Schatz Royal Mariner barometer which I later found out had a broken thermometer. I'm interested in purchasing a used one from anyone who might have one, or a barometer with a broken bellows but which has a good thermometer.
rpm7653@aol.com
Jan 31, 2009
36
Wanted: Vienna Style 4 post mounting bracket for clock movement.
Looking to purchase a mounting bracket for a Vienna Style 3 weight movement. Four pillar type. Let me know if you can help.
Ron
leeinv66
Mar 31, 2005
10,666
452
Launceston Tasmania
Re: Wanted: Vienna Style 4 post mounting bracket for clock movement.
Unfortunately, these are not often interchangeable from one make of movements to another. You will need to provide some measurements otherwise you may well end up with a bracket you cannot use.
f.webster
Dec 18, 2009
966
93
Louisville, KY
I am looking for a winding arbor for a Seth Thomas no. 124 movement. The one I am replacing has the key post broken off (and so is the click). The gear has 60 teeth. Key size 3.
Thanks for looking.
shimmystep
Mar 5, 2012
4,110
94
Cambridge, UK
Abec Platform escapement/ or 'scape wheel from the same.
Would appreciate you folks seeing if you have an escapement wheel from a fairly common platform escapement. It is an Abec platform, commonly found on English Smiths clocks. Happy to pay for the wheel or the whole platform of course. You can see in the pic that some of the EW teeth are shot.
Thanks very much :)
'scape wheel diameter 6.40mm
8 leaf pinion (.25mod)
Total arbour length 8.53mm
Pinion drop engagement range 2.5-4.5mm
Platform 31mm x 23mm (though not crucial)
scaryharry
Nov 15, 2015
29
The Burgh'
Re: Abec Platform escapement/ or 'scape wheel from the same.
If anyone has a topper that would fit a Mauthe free swinger I would like to purchase. The top of the case is 15" from outer corner to outer corner.
Thank you.
shimmystep
Mar 5, 2012
4,110
94
Cambridge, UK
Abec platform parts/or replacement
Apologies mods, know I should only keep this in parts wanted, but need a bit more exposure for a few days.
Would appreciate you folks seeing if you have an escapement wheel from a fairly common platform escapement. It is an Abec platform, commonly found on English Smiths clocks. Happy to pay for the wheel or the whole platform of course would be great. You can see in the pic that some of the EW teeth are shot.
Thanks very much :)
174,423
1,524,150
52,195
Codozalator
1,063
2,971
Last page
