Clock parts wanted Obsolete older posts II
Gregory Cook
Mar 26, 2014
Fashion No. 4 Bezels
I'm looking for a set of bezels for a Fashion No. 4. I checked with the Dial house and they only have the bezels for the 5 & 6. Any ideas or suggestions? Anyone making them?
J
jimlg
looking for white second hand for Chelsea 24hr "missile silo" clock
If anyone can help me find a second hand pointer, or knows of someone with a salvaged clock, please let me know....this is the large case, black face, 24 hr Chelsea US Gov. model...best regards,
James Garrison
J
jimlg
WTB white seconds hand for Chelsea black faced military clock
I'm looking for the white seconds hand, with the crescent on the end. I think it is the same hand used on both the US Navy and the larger US Government "missile silo" black faced clocks. The Chelsea Clock Co offered no help. Any help will be appreciated....
Jim Garrison
SantaFeRoute
Aug 25, 2000
101
Arizona
Need original seth thomas movement 67a, 67-a please.
Hi there. I need a 67a, 67-a movement Seth Thomas like the ones used in a Regulator 19 with the mercury pendulum crutch. Please send me a message if you have one for sale. Thanks for now. John
greengoon3
New User
Jul 25, 2015
WM Gilbert 25 movement needed or parts
I need a Gilbert movement that has 25 on the front plate. I need the gear assembly that goes from the chime main spring assy to the next gear. It is the second gear cluster in the chain. Can anyone help? The assembly has a lot of stripped teeth Also the front plate has a bad pivot point. So if a complete movement I can use for parts is available that would work also.
Can anyone help?
Thanks,
George
gordon
Mar 7, 2007
243
Canton, Michigan 48187
Need a Herschede 9 tube Verge
Hello All
I am working on a Herschede 9 tube that needs a needs a new verge. Where can I get a replacement for the worn verge or is a repair possible?
Attached are several photos that show the ware.
Bob Reichel
NAWCC Star Fellow
Feb 13, 2001
976
Jura pendulum needed
The Jura clock on my bench is missing the full pendulum. My customer wants it authentic. So, I'm looking for a bob. It appears from searches to be an chrome octagonal shape, maybe near 4 x 5 inches. Look in your spare parts bin and let me know if you have one. Examples of Jura box clocks (24" square) can be seen on Google (Jura Clocks) or on Ebay.
tbonjour
Oct 27, 2008
56
Re: Clock Parts Wanted
I need the two weights and the sweep second hand for a Welch & Spring No. 1 Regulator. If you have one of these clocks, basic information about the original weights would help.
Bob Reichel
NAWCC Star Fellow
Feb 13, 2001
976
Resch Bro. "Remember" , Movement part-"Bridge cock"
Part needed. Have a 4" x 4" Resch Bro. "Remember" movement with a broken tube (worn away) on the bridge cock. That's the part that the minute arbor goes thru and supports the hour h and cannon. In the photo the separated part is up in the hour cannon. 247193.jpg
48,785
2,638
Re: Resch Bro. "Remember" , Movement part-"Bridge cock"
So the hour cannon is the problem Bob? I would think you could "borrow" one from just about any movement, and attach it to the wheel?
Bob Reichel
NAWCC Star Fellow
Feb 13, 2001
976
There is no borrowing.. You see(in the picture) the minute hand arbor coming up out of the bridge cock. The guide tube is fixed over that arbor and is part of the bridge cock. "The hour cannon fits over that tube. The tube wore away at the shiney point you see on the bridge cock. So the tube guides the minute arbor and supports the hour cannon. To make a new one=drilling out the bridge cock, make a new tube, tapered for clearance to the inside of the hour cannon.
This is what I will have to make, unless I can find a part from a 'salvage' movement.
48,785
2,638
I see what you're saying, Bob. Did you try David LaBounty? He has a huge inventory of parts.
Bob Reichel
NAWCC Star Fellow
Feb 13, 2001
976
I'm in contact with Phil Johansen-Crafts winner several times for unusual hand made clocks. Anyway, he has agreed to make me a new sleeve and install it. I was already in contact with David and he did now offer a salvage part.
orso
Jun 9, 2013
229
74
Minnesota
Waterbury double deck fly arbor
Hi all.
I'm looking for a Waterbury Double deck fly arbor with shrouds or a suitable replacement. It is has seven trundles lantern pinion. The shroud OD is 5.15 mm.(13/64") and the trundles are 0.54mm (.021").
Thanks,
Andrea
Dave Diel
Feb 28, 2014
647
49
Denver, Colorado
Looking for a Charles R. Sligh 116 cm pendulum
Please send me a PM if you have one.
Edit: Moderators, I screwed up. I meant to put this in the clock parts needed thread. Sorry!!!!
orso
Jun 9, 2013
229
74
Minnesota
Re: Waterbury double deck fly arbor
Thanks all,
after 4 attempts, I was able to make one that works. See pick
Walt Wallgren
Aug 16, 2012
1,223
34
Bay Area, California
Waterbury Regulator 53 Weights
All,
I just purchased a Waterbury Regulator 53 with no weights. Does anyone have a set of weights for this clock that I could acquire? Or at least the dimensions and weight so I can know what to look for.
Thanks,
Walt
bruce linde
10,286
2,056
oakland, ca.
clockhappy.com
need mounting bracket for seth thomas #68 movement
i need a mounting bracket for a seth thomas #68 movement. anyone got one?
thanks,
smike
bruce linde
10,286
2,056
oakland, ca.
clockhappy.com
Re: need mounting bracket for seth thomas #68 movement
photos and info...
jcoyote
Jan 4, 2015
32
56
Gilbert Hollywood Pendulum
Looking for the complete pendulum and cylinder bob in nickle finish for a Gilbert full sized Hollywood. Should be about a 9 inch rod with a regulating nut, a 1 inch leader, and a 3 inch ? long by half inch diameter bob. Not sure if I should leave a phone number to reach me with or an email addy?
gliebisch
Sep 26, 2015
23
Wanted: Hubert Herr dual door reuge music woodchopper cuckoo for parts and repair
Looking for a clock like the one shown in these photos to use for parts. The arrows show the parts I need, but will buy an entire clock if it is in "for parts only" condition. I am after the reuge music movement with extended shaft to drive the water wheel pulley.
48,785
2,638
Re: Wanted: Hubert Herr dual door reuge music woodchopper cuckoo for parts and repair
Those come up on the auction sites from time to time. Keep checking :)
SantaFeRoute
Aug 25, 2000
101
Arizona
Re: Need original seth thomas movement 67a, 67-a please.
Hi again. I also need the dial bezel (silver deep metal) and 2 original glass thumbprint mercury jars used on a seth thomas regulator 19 please. John
orso
Jun 9, 2013
229
74
Minnesota
Not true. It's not working. Please leave the part quest standing.
Thanks,
Andrea
Jay Fortner
Feb 5, 2011
5,070
41
Chiefland,Fl.
Thanks,
Andrea
Give me all the dimensions;
Overall length
Length from pivot shoulder to pivot shoulder
Pivot diameter
Arbor diameter.
I've got several Waterbury fan arbors out of various vintages,I may have one.
orso
Jun 9, 2013
229
74
Minnesota
Hi, Jay; so kind of you. Here you are:
Overall length:1.538"
Length from pivot shoulder to pivot shoulder: 1.34"
Pivot diameter: .048" (but these have been filed)
Arbor diameter: .084".
Trying again tonight but it is so small and I do not have precision instruments.
Thanks a lot,
Andrea
B
Bob Kistler
Look for quarter rack assy for Herchede 9-tube
Part #2661 at R&M is no longer available. Is there another Herchede supplier?
clockmanjoe
Dec 12, 2014
37
Clock Parts Wanted
I need a dial as shown for an open escapement movement.Must have a 3 inch center opening.
This is the movement
Orgelbear
Aug 14, 2006
129
55
Lexington, NC
arbor and governor fly needed
Hello All,
I am in need of an arbor/fly for a British 8-day tall clock movement (a customer's clock.) I cannot make this myself. I have nothing available to copy as the original was lost during a move. The clock apparently was shaken to the extent that the pins worked out of the posts and the plates spread just enough for it, and other parts, to fall out.
The rest of the movement was found in the case and can be completely restored to wonderful working condition.
Can anyone recommend someone to do this work? I contacted a couple of folks of which I am aware, but they need something to duplicate.
Has anyone ever used the replacement available from Timesavers with any success?
Thanks in advance. I need some help with this one!
Kelly Newsome NAWCC #91015
48,785
2,638
Re: Look for quarter rack assy for Herchede 9-tube
Read this post.
Maybe they have a substitute they could offer?
Probox
Oct 27, 2015
281
Halifax Canada
Clock Parts Wanted
Looking to find an escape wheel for a Mauthe Alarm clock. The staff measures 26.3 or 26.2 cms and has a lantern pinion just below the cog teeth. Here is a picture. I will pay to get the right one. Mine has a tooth missing.
[This post is DUPLICATED in the Clock Repair forum. Look there for more input.] 250260.jpg 250261.jpg 250262.jpg
Probox
Oct 27, 2015
281
Halifax Canada
Looking for a movement from a Mauthe Alarm clock.
Looking for a movement from a Mauthe Alarm clock. I need parts from it (mostly the escape wheel) Thanks. 250161.jpg
DanGrayson
May 19, 2012
156
70
Henderson, Nevada
dangrayson.com
Re: WTB Cleveland Clock Parts
The ornaments were sold separately, in numerous styles, according to Tran Duy Ly's
book on Ansonia clocks, so instead of looking for that particular ornament, one could
look for any Ansonia top ornament. That particular ornament seems not to be listed
in the book, so maybe it's not even from Ansonia.
Larry B
New User
Feb 11, 2015
Re: Clock Parts Wanted. new haven 30 day movement
I need a new haven 30 day movement for a banjo clock. this is my first post on the nawcc site. I hope someone can help me in my quest.
Larry
bkerr
Nov 29, 2007
1,391
46
65
Canal Fulton,OH
looking for hands, German Bracket Clock
Does anyone know where I can purchase spade hour and minute hands as well as the indicator hands (strike on - off and time setting) for German bracket clocks? I have a couple of sets that I need to complete these clocks. Thanks in advance for you help.
250636.jpg It was not supposed to be on it's side but hopefully you get the idea. Thanks
13,666
92
Re: looking for hands, German Bracket Clock
Looking for a dial and bezel for a 1914 Gilbert small dome ( beehive? ) clock.
It is 5-1/2 inches across and has the small rate adjust hole at the 12 o'clock.
The dial doesn't have to be in super condition.
Walt Wallgren
Aug 16, 2012
1,223
34
I would try Timesavers.com or Merritts.com
Walt
CJo
Aug 22, 2005
507
11
66
southwest Kansas.
Morbier/Comtoise calendar wheel part
Is there anyone that would have the wheel I am looking for to run the calendar on my clock Morbier clock? I think I read somewhere where it needed to be a 72 tooth wheel but not sure on that. Just from my rough estimates, it looks like it needs to be about 2.24" in diameter. Didn't know if someone might have one for parts they might sell off of. 250953.jpg Everything else seems to be there except the wheel that advances the calendar. Any help would be appreciated.
CJo
Aug 22, 2005
507
11
66
southwest Kansas.
Re: Morbier/Comtoise calendar wheel part
Tinker Dwight;990739 said:
What does the rest look like?
250511.jpg 250515.jpg 250952.jpg 250954.jpg Here are a few pictures. Guess I didn't take a pictue with the pendulum. I'll have to do that. Thanks
13,666
92
Your also missing the detent spring to hold the date
wheel.
As you say, it looks to be a 72 tooth wheel, although
I don't see the arbor it is suppose to ride on.
I suspect this is not the original movement for the dial.
It looks like the minute wheel of your motion works is
exactly what you'd need. It looks to be a 2:1 off the center
shaft.
It could be used as a template to make a new wheel or a similar
parts clock. ( count the teeth on it )
Is it the right size?
CJo
Aug 22, 2005
507
11
66
southwest Kansas.
wheel.
shaft.
There are 36 teeth on the wheel that is in front of the pendulum leader. Yes, I am missing the 'post' that would hold the wheel I'm looking for. Thought I could make that if I had to. Just don't think I could make the wheel. Don't have any experience in that area.🤔
13,666
92
If the 36 tooth center wheel for the motion works is
the same size as the one for the date, the 72 tooth minute wheel
of the motion work will match.
You can the use it to have someone make another wheel for you.
There are several people on the MB that are capable of doing it.
CJo
Aug 22, 2005
507
11
66
southwest Kansas.
Thank you Tinker. I'm a little slow, :whistle:but yes the minute wheel does have 72 teeth. I will see if there is someone close that can copy this, if not, will get with some on the MB. Just curious as to why you think the movement and dial are not original to each other? Thanks again for your assistance.
13,666
92
I don't see a place where the arbor would have been mounted. If you follow
the same distance out of the motion works around the center shaft, I don't
see anything obvious that would have held the arbor for this wheel.
At first I thought it might stack on the motion works but that would
interfere with crutch.
A picture, looking straight into the center shaft but back enough
to see where such an arbor might have been, might change my mind.
The clock face says it had the entire setup once but I just don't
see where it would have been mounted?
I just gave the pictures another look. There is a hole on the right
side that might have been used for this purpose but I can't
tell if the distance is right from the pictures perspective.
CJo
Aug 22, 2005
507
11
66
southwest Kansas.
The hole on the right side, is a screw hole. So I was assuming that a post was screwed into this hole that would hold the wheel, to turn the calendar. The distance seems to work.
48,785
2,638
Looking for a chime select lever for Jauch GF
175,290
1,533,301
52,664
Rodrigo
1,063
2,972
