Clock parts wanted Obsolete older posts II
Kevin W.
23,599
705
65
Re: Pendulum for a Swedish Mora clock needed
Looking for a dial for a Kienzle westminster clock. Its a mantel clock. Dial needed is about 7 inches in dia. If anyone has something close to it i will take more measurements of what is needed for the dial. Three holes for winding of course and one hole at top foks.r s and f . Also i would need a bezel and glass as well and hands too. Hoping someone may have something. Thanks.
Graybeard
Jan 6, 2014
13
New Jersey
Re: Wanted: TO Movement for New Haven 3043
I saw a New Haven 3043 for sale online, the picture shows the movement marked "19".
Gordon Andersen
Oct 4, 2000
158
Re: Clock Parts Wanted
Hello all,
I have an ITR Time Recorder that needs a winding key. I have checked all of our regular suppliers without success. The largest key they all have available is a Number 23 which is identified as an 8mm. If any of you have any idea where I might locate one
of the correct size, pleases let me know.
Thanks,
Gordon Andersen
West Bend, Wisconsin
2fatcat@charter.net
harold bain
40,853
192
74
Gordon Andersen;932735 said:
Hello all,
Thanks,
Gordon Andersen
2fatcat@charter.net
What is the correct size for your clock, Gordon??
prideofmatchingham
Dec 13, 2011
1,312
7
Kolkata, India
I got this very intriguing single weight movement which is so tiny! Never seen something like that ever in my life. It is mere 94*70*30 H*W*D. any parts seem missing including hour and minute wheels, lever, canon pinion. May also have a side second, I dont know. Photos here
227986.jpg 227997.jpg 227987.jpg 227988.jpg 227989.jpg 227990.jpg 227991.jpg 227998.jpg 227992.jpg 227993.jpg 227999.jpg 227994.jpg
I want to restore this clock. Would appreciate help on parts. members may message me with part and cost.
Gordon Andersen
Oct 4, 2000
158
Hi Harold,
I really don't know what size I need. I tried a 5/16"- 8 point socket and found
that it was too big. And a 1/4" is way too small. I found that in the British key numbering system that their number 23 key is identified as 8mm. I have been unable to locate any 4 or 8 point metric sockets. At this point, I am really at a loss. Thanks for your interest.
Gordon Andersen
harold bain
40,853
192
74
Well, a wind arbor has nothing in common with a hex nut to be useful for measuring. A quick micrometer measurement on a few of my loose movements gives a bit less than 6 mm across the flats of the wind arbor. Timesavers lists two keys for time recorders, a #20, 6.4 mm, and a #23, 7.0 mm. I would go with the first one, part # 29761.
www.timesavers.com
MartinM
Jun 24, 2011
3,121
125
El Dorado, CA
There are metric 8-point sockets out there; But, they're not easy to find. You'd be better off using a set of metric open-end wrenches (spanners) to find the correct size. If you don't have wrenches that small, just take it to a local mechanic who will probably check it out, for you, for free.
Actually... He'd likely just use a caliper or micrometer on it and give you the correct size (which I suspect is 9/32 inch. [.28125"]).
Why we're talking about metric on an American clock is something I'll not ask.
The mechanic may have an 8-point 9/32 inch socket if you want to go that route.
Ralph
Jan 22, 2002
5,534
481
I have a number of master clocks needing dials. I need a couple of Landis/Frick dials I also need pendulums for these two clocks.
Jmurrell
Apr 3, 2011
691
23
Southeastern Ohio
Hi I am working on a Webb C Ball Clock out of Cleveland, Ohio.
It has a round Waltham movement #23282.
The movement is missing the regulator for speed control.
Does anyone know where I can get one of these?
Thanks John
Jmurrell
Apr 3, 2011
691
23
Southeastern Ohio
Hi I posted a request for parts but I am not sure I did it correct as I posted it as a reply to Harold Bains.
I don't know if I should have started it as a new thread.
John
49,125
2,775
John
It's fine, John. This is just one thread, and the older stuff gets deleted when it has been outdated or the part has been found.
One trick that might help you is the square bracket "[" You use that and the closing bracket to "quote" certain parts of the post you are referencing. The format (using parenthesis instead of the square bracket so it doesn't confuse the system) is: (quote) insert the quote you want to appear (/quote) which closes it. So in real mode it looks like this in your post:
It's pretty handy. You could also use the "Reply With Quote" button (like I did at the beginning of this post), hightlight and copy it and then cancel. Move to the other thread, like this one, and paste it. It should have all of the necessary brackets in it already.
M
MickRenee
Seeking a clock part
Looking for a second hand for an old Seth Thomas "Globe" clock. I did take this to a clock repair shop and they tried all sorts of second hands, but none worked. If anyone can help, I would greatly appreciate it. This clock belonged to my husband's grandfather, and the repair shop was able to get it up and running, but it looks funny without the second hand. Thank you all in advance. Mich
MartinM
Jun 24, 2011
3,121
125
El Dorado, CA
Re: Seeking a clock part
Might I suggest one or more pictures of the clock in question be posted?
I didn't know the Globe even had a seconds hand.
bangster
20,028
596
Actually, it doesn't get deleted. It just gets moved to an Older Parts Requests archive.
M
MickRenee
Yes, I will take a picture and post it. Thank you for the input.
MartinM
Jun 24, 2011
3,121
125
El Dorado, CA
I'm not sure if it would be appropriate; But, if the size is similar, I'd say the hand for a Seth Thomas Regulator #2 would work.
It might need to be trimmed a tad.
You could see what they look like on the big auction site.
You should probably wait a bit for responses from folks more familiar with your clock.
EDIT: It appears your clock is the "World" model and not the "Globe".
That may prompt more responses.
http://www.m80.net/db111/SethThomasClock/
Dave Diel
Feb 28, 2014
653
50
Denver, Colorado
[LOOKING FOR URGOS 03XXX MOVEMENT WITH AUTOMATIC NIGHT SHUTOFF]
Will consider any condition, but it has to have auto night shutoff. 12 hammer models are preferable, but tubular movement may be acceptable if the price is right.
scott64a
Jul 31, 2013
355
Harvard, MA
Need Waterbury Mvmt
It's from a customer's clock that wasn't working, and after opening it up, I found the fork and mainspring broken.
It's 2 3/16" diameter on the widest part of the plate, and 1 1/4" deep.
Waterbury.
Where do I find a replacement?
scott64a
Jul 31, 2013
355
Harvard, MA
Re: Need Waterbury Mvmt
The woman said her grandfather built the clock, and she doesn't know where he got the movement from. It winds at 6 in the front, and I'll be damned if I can't find another.
Ralph
Jan 22, 2002
5,534
481
I need a painted dial for a Colonial Clock Co clock. I'm thinking there were a lot of surplus parts floating around from that company. Any chance anyone has a dial like this or know of someone who has ??
The dial measures 15 3/8" tall by 11 3/16" wide.
Thanks, Ralph
Grantsim90
New User
Mar 5, 2015
Looking for a few items,
a clock hand adjuster for a smith sectric Delhi major
a rear cover for a smiths bijoux motor
M
mattsrepairhobby
Looking for a New Haven clock movement #20 for a 8 day banjo clock.
Let me know if you have one or know where to find one
seamore
Jan 27, 2013
104
66
Dover, Ohio
Ingraham Bim Bam mantel clock escapement wheel assembly & verge (48 teeth on wheel)
looking for escapement wheel assembly & verge for a bim bam ingraham mantel clock (48 teeth on wheel) it is stamped 12/28 on the plates can anyone help me please ?? These two parts are the only things i need to get clock running again any help would be great
THANKS
Seamore
MartinM
Jun 24, 2011
3,121
125
El Dorado, CA
Re: Ingraham Bim Bam mantel clock escapement wheel assembly & verge (48 teeth on whee
Looking for paper & carbon discs and station keys for a later model Dent watchclock (41 Pall Mall London address).
49,125
2,775
Need a plastic/acrylic lens for a clock. It is 6 inches and has a small lip on the bottom. Comes from a Boliva combination quartz clock and barometer wall hanger.
Thanks!
Steven Thornberry
User Administrator
Jan 15, 2004
25,102
2,374
Here and there
Thanks!
You mean "Bulova," I presume. Or . . . ?
49,125
2,775
Yes. Sorry :)
harold bain
40,853
192
74
Still not enough info to help. Is it round, square, concave, flat? Pictures may help, SB.
49,125
2,775
Sorry. Its round, 6" at the lip part, convex slightly. This might help :) 231098.jpg
celticprince59
Nov 28, 2007
406
82
Yeovil
www.celticclocks.co.za
Koma Midget
Hi
I need a barrel for a Koma Midget 400 day Torsion clock. It has the smaller spring 12 x 25.internal width of plates is 20mm, Barrel OD of teeth is 29.40 and thickness is 14.78..Please don't ask me to count the teeth...lol:rolleyes:
Andy
MartinM
Jun 24, 2011
3,121
125
El Dorado, CA
Antoine Redier Alarm Clock
Looking for a back cover screw for an Antoine Redier alarm clock. Also any info on the clock would be appreciated if anyone were inclined to share.
This is a model I can't find any additional information about. It winds with a key as opposed to the more common model that winds by rotating the back cover.
The screw I'm in need of, as all of the external screws on this clock, (two in front and two in back) is a flat head as opposed to the other versions of the clock where the three screws on the front are slightly convex.
It has an intriguing wig wag escapement that I can't readily identify, as well. Very simple but also very active with just a little input. I think this is the first time in a movement that I've seen a design actually meant to actively disengage a pinion from a wheel as part of normal operation.
LaBounty
NAWCC Life Member
Aug 29, 2002
3,467
Mitchell, NE
www.abouttime-clockmaking.com
Re: Antoine Redier Alarm Clock
Our friend Bob Reichel is having problems posting and has asked if I'd post this parts request for him...
What he is looking for is an old part or a scan of the part that he can make. AJK "Original Kieninger" 5/70 RK 80cm tall case, movement, Pendulum leader.
Thanks!
celticprince59
Nov 28, 2007
406
82
Yeovil
Hi David
I will have a look at my Kieninger Longcase number and scan it in full size. Will scan it in in any case even if it is not the same number. Maybe they did not change them so often.
Andy
MikeBY
Feb 5, 2015
207
Huntington Beach, CA
Need a case for a Schatz Royal Mariner ships clock.
Have a clock with external open bell, but the case for the clock is cracked.
Ralph
Jan 22, 2002
5,534
481
These might help.
Ralph
LaBounty
NAWCC Life Member
Aug 29, 2002
3,467
Mitchell, NE
celticprince59;942088 said:
Hi David,
Is this the one he is looking for? Sorry about rust as I have not got round to making the gathering pallet locking lever and service yet for mine.
Hey Andy-
Thanks for the photos! I'm not actually the one looking for this information so maybe the person I posted for will let us both know :).
MartinM
Jun 24, 2011
3,121
125
El Dorado, CA
Ralph;942106 said:
These might help.
Ralph
Thank you, so much, sir!
I'll try and make some based on your scans.
Any idea where one might find some originals?
I have a few of these clocks and would like to bring them up to the same level of inclusion as many of my other watchclocks with consumables, keys and stations if there were any.
Danno52661
Jan 29, 2013
50
Seth thomas Office #11 Parts Needed
Seth Thomas Clock Co., Thomaston, Conn., "Office No. 11" wall clock with a 30 day movement (no. 86T) I Need 14 Inch Round painted metal dial and I also Need the Pendulum and the second Hand so if someone could point me in the right direction I would be Very Grateful . Ht 18 3/4"
Thanks Dan
Randy Johnson
Mar 30, 2005
770
Gadsden, AL
Cuckoo Chain
Hello!
I need a 42 links-per-foot chain for a large and very old Herr 8-Day cuckoo clock. Please e-mail (pm) details & cost. Thanks!
- Randy
MartinM
Jun 24, 2011
3,121
125
El Dorado, CA
Re: Cuckoo Chain
Is this chain any different that those that come up in a Google search for "42 links per foot"? All of the usual suspects seem to offer it.
Possibly, you're just needing for the patina?
Randy Johnson
Mar 30, 2005
770
Gadsden, AL
Re: Cuckoo Chain
Thanks Martin. I've seen several of those you're referring to but they're from overseas ...so I'm trying to find something a bit closer for shipping costs and time. Two popped-up on eBay back in November before I needed one. I bought one last week that turned out to be 43 LPF when it arrived. I've got a drawer full of cuckoo chains in about every size I've seen, but no 42s.
I'm willing to do my own tarnish-to-match if I can just find one to fit. ;)
MartinM
Jun 24, 2011
3,121
125
El Dorado, CA
Re: Cuckoo Chain
If you can't use the longcase chain, you might have to go with finding a Schatz parts clock.
MikeBY
Feb 5, 2015
207
Case for Schatz Royal Mariner Open Bell ship's clock
I have a Schatz Royal Mariner brass ship's clock with open bell. It has several cracks in the case, so I'm looking for another brass case to use. 231714.jpg
177,611
1,556,615
53,631
gary0003
909
3,058
Watch Inspectors by Kent
