Clock parts wanted Obsolete older posts II
R
rpsodapop
Re: PAM Clock repair
I need several Pam square clock faces. I use to purchase from S LaRose who has since closed down - does anyone have a source for these convex glasses?
I also need an 18" glass for a thermometer - any ideas where I can purchase at a reasonable price?
R&A
Oct 21, 2008
4,218
109
Re: Need parts or whole ingraham square mvt (shop regulator)
I used to know a guy that made replica pieces out of plastic plaster. And then stained them. He would heat the plastic with a hair dryer over the piece he wanted to produce. When it would cool, he would lift the plastic and it would create a mold. The plastic was almost like a heat shrink plastic. That is an option. Or search the web for an alternative solution. The guy I knew did this when I was 16 years old when I first started being around clocks. He has since passed and his knowledge too. I learned allot from this guy.
H/C
R&A
Oct 21, 2008
4,218
109
Douglas Ballard;679611 said:
Hello, I am looking for the bottom most ornament, the one below the dial, for a ew Haven "Warwick" model, ca. 1914 cast iron mantle clock. The rest of the clock can be junk, just need this ornament and perhaps the right (facing the clock) leg set. This is the clock pictured below, the right half of the bottom ornament is missing.
H/C
Eugene Volk
Vice Chair
NAWCC Star Fellow
NAWCC Life Member
Apr 2, 2003
638
Schatz Royal Mariner: Need Gathering Pallet
Looking for a gathering pallet for a Schatz Royal Mariner. Would also be happy to get a rough tracing
so I can make one. A friend purchased the clock and now we find the gathering pallet was replaced with
one that is incorrect.
Many thanks,
Gene Volk
jimmymac
Jul 16, 2012
Re: Hair springs
Have a Jauch movement labeled 61 cm P.L. from a Gazo clock. I need the 2nd wheel in the time train. This is my first post. Hope I am doing this correctly. It is also the first time I took apart a clock and of course caused the stripped wheel because I didn't let down the mainspring before I opened the clock up. Help. Thanks.
R&A
Oct 21, 2008
4,218
109
Re: Hair springs
Was it so bad that the wheel can't be repaired??
H/C
jimmymac
Jul 16, 2012
Re: Hair springs
The big gear that connects to the mainspring spins on the shaft. Looks like all the teeth have been stripped away. I think its a goner.
Douglas Ballard
Dec 2, 2011
1,603
14
70
Alma, MI
H/C
The mold sounds like a good idea. I take it you don't recall the type of material that was used? Thanks.
Douglas Ballard
Dec 2, 2011
1,603
14
70
Alma, MI
H/C
Found just the thing for making a rubber mold, then a plastic casting from the mold. www.smooth-on.com
This is not an endorsement of this product nor am I affiliated with the product in any way.
shimmystep
Mar 5, 2012
4,110
102
Cambridge, UK
Re: Hair springs
Hi
Following the escapement wheel and arbor being bent in the post by a loose ornament holding bolt in the clock case I'm looking for a replacement. I can't get rid of the all the wiggle caused by the damage.
From a S.Marti movement however probable other/unmarked French movements will prob have identical component.
Total arbor length 34.3mm
Pivot diameter 0.59mm
Pinion diameter 2.35mm
escapement wheel diameter 19.8mm
teeth x43
Thanks for looking
John.Mc
New User
Jul 18, 2012
Re: Hair springs
I need a suspension spring for the below pictured movement. The movement is stamped Kriegs (mod.) #43037.
It is a courtesy repair for an officer stationed at the United States Army Command and General Staff College Fort Leavenworth KS 66027. The clock was bought by the service members spouse at a flea market in Germany and the packing agent in California broke it during their last move. I am trying to help the service member avoid a long claims process filled with red tape.
Thank you in advance, my cell number is 816-550-9883 or email address of info@kansascitycrates.com.
harold bain
40,853
191
74
Re: Hair springs
Hi, John, welcome to the message board. If you go to Timesavers website, their suspension springs have their dimensions posted so you can find one close to yours for replacement.
www.timesavers.com
A small difference can be compensated for by adjusting the regulator.
R&A
Oct 21, 2008
4,218
109
That is great. I am glad I had an idea that somebody could use.
H/C
R&A
Oct 21, 2008
4,218
109
Re: Clock Parts Wanted
Tarponhuntr;687734 said:
Needed ! 1 Original Brass Eagle Finial for a Seth Thomas , Banjo No. 1
Many Thanks
Do you have a picture of this eagle.
H/C
Dick Feldman
Sep 1, 2000
3,107
484
Colorado, usa
Hello all,
I am in need of a Hermle, #54 or #55 barrel and cap (53.5mm tooth plate OD). The barrel teeth need not be good as I need only the tube and cap. That tube is almost a dead match for a damaged one in a Junghans Vienna I have in for repair. The barrel tube from the Junghans has a half dozen stress cracks and is not practically repairable.
I know these Hermle barrels are available new from the material suppliers, but I am reluctant to pay $16.00+/-, only to cut it apart.
Please send me a PM if you have one or email fourburros@AOL.com
Best Regards,
Dick
Tarponhuntr
Jul 22, 2012
20
Hickory, NC
H/C
I have found an image from a closed auction that shows exactly what I need. Judging from the picture the eagle's wingspan would be in the range of 3 1/2" to 3 5/8". The original is a solid brass piece. Any help you could lend in locatiing one would be greatly appreciated.
Thanks in advance
R&A
Oct 21, 2008
4,218
109
Tarponhuntr;687872 said:
H/C
Thanks in advance
Try looking at the tops on flags that are for sale. Some are very similar.
H/C
BSM
Jun 16, 2012
Re: Hair springs
Becker Pallets Wanted
I would like to buy a pair of pallets for a Gustav Becker 400 Day clock escapement
binman
Nov 16, 2011
794
Chatham England
Needed Bezel and surround for Ansonia wooden Sussex clock
R&A
Oct 21, 2008
4,218
109
Re: Hair springs
Could you use a different model :???:
H/C
inbeat
Nov 10, 2000
1,862
10
76
Portland, Oregon
Bronze clock bun foot
I am missing a foot from a clock that I have owned for a long time. The clock is a "Rex" and is made of bronze, weighing 15 1/2 lbs (different from the wooden Rex). The missing foot measures .738" wide, .372 tall with a .164 center hole. Is appears to be machined from a solid piece of bronze. Of course, I would love to have an original foot, but wonder if there is a place to purchase a set of 4 feet that would not be offensive on the clock? Pictured is the foot I need. The picture of the foot by itself is of the foot off of the clock, on a black table top. The feet are screwed on.
I posted this in the general section and was advised that I should "turn" a new foot. As I replied there, I have no lathe and no later skills if I did have a lathe. Any ideas/help would be appreciated.​
R&A
Oct 21, 2008
4,218
109
Re: Bronze clock bun foot
The material you need is not cheep. But if you buy the bronze I can make these for you. We both live in Az. Give me a call. Or we can make them out of brass.
H/C
Don DeMarcus
Aug 26, 2000
1,818
You can find serveral feet at Timesavers.com type in feet or look on page 19 and see if they will work.
Page 19 I think.
Tarponhuntr
Jul 22, 2012
20
Hickory, NC
Re: BRASS EAGLE FINIAL !
136884.jpg Looking to buy this eagle! This particular one is from a Seth Thomas No. 1 Banjo. However , I know they placed these on many of their clocks.
The one I will buy must be solid brass , as original. As measured from the photos the eagle is approx. 3 5/8" wide and almost as tall. All of the replacements I have seen are way undersized for this clock.
Someone out there is bound to have one !
R&A
Oct 21, 2008
4,218
109
Look at the tops of flags. Have heard that some guys have found them there. Purchase the flag and get the Eagle.
H/C
Bob Vance
Feb 24, 2012
80
Sessions MTV.
I'm in need of a sessions 8 day movement, with half hour bell strike. Needs to be compleat, and in fairly good order. If anyone has one, please send me a PM, with details.Thanks. Bob
lpbp
NAWCC Star Fellow
NAWCC Life Member
Aug 25, 2000
3,020
84
Re: Sessions MTV.
What type of case does it go in, black mantle or what?
Bob Vance
Feb 24, 2012
80
Re: Sessions MTV.
Sorry
its a black mantel. It's about 5.75" from the top of the SS to the center of the bob. It's 3/1/8" between the arbors.
rfyans
Nov 4, 2008
46
Narragansett, RI
Need dial for C & N Jerome
I am still looking for a dial for a C & N Jerome clock with an "A" frame movement with rolling pinions. The original dial was 11" X 11" with Roman numerals. The center to center distance between winding arbors is 3 and 13/16" and 1 and 7/8" from hour shaft to winding arbor.
Thanks,
Rich
RodJB
Dec 13, 2008
376
15
Richmond BC Canada / Kirkintilloch Scotland
Re: Waterbury Bruce Regulator upper gallery Still needed
I am still looking for a top gallery for this clock or one that I could borrow to make a template for making a replacement. The second pic shows what it would look like.
harold bain
40,853
191
74
I'm looking for a time side spring barrel and spring for a Schatz Royal Mariner movement. Anyone have a parts movement?
R&A
Oct 21, 2008
4,218
109
Re: Hair springs
Looking for the verge for a Herschede 9 tube movement. Customer tried to move the pallets and broke the end of the verge off.
H/C
R&A
Oct 21, 2008
4,218
109
Re: Hair springs
LaBounty;694015 said:
Randy at R&M Imports has them: Anchor, part no. HER-2086, $35.
Thanks Dave for responding.
H/C
E
Efim Shargorodsky
Rosenfelder Clock parts
Hi,
I am hoping someone might help me locate a part for a Rosenfelder mechanism. It is the escape wheel arbor/pinion combination for a platform escapement.
Any help would be greatly appreciated!!
R&A
Oct 21, 2008
4,218
109
Re: Rosenfelder Clock parts
Efim Shargorodsky;694225 said:
Hi,
Thank you!!
What is this out of ??
H/C
machineage
Aug 14, 2012
12
Staffordshire, UK
6 1/2" Chrome Plated Bob
Hi everyone
I'm looking for a Chrome plated hollow bob for my longcase. The bob is approximately 6 1/2" in diameter & weighs 300 gms. It takes a 1" rod.
I wondered if anyone out there may have a suitable replacement?
I'm based in the UK.
Thanks!
moe1942
Oct 25, 2010
1,648
Alexandria, La
Re: 6 1/2" Chrome Plated Bob
I need a wing winder for a banjo clock mvt..It appears to be a male #10-20 TPI left hand threads. I have found a lot in my search but all are female.. 138965.jpg 138966.jpg 138967.jpg
moe1942
Oct 25, 2010
1,648
Alexandria, La
Need
a wing tab winder for my newly aquired banjo clock..Never have any luck in the parts wanted section..As close as I can figure the threads are #10-20 tpi left hand. I have found a lot of them but all I see are female. I need one with a male stud..
I just know one of y'all can lead me to it..
Also which way does the hand set knob come off.. Left or right..before I tear it up...Patience is my forte.
Heres a few pics...post #41
https://mb.nawcc.org/showthread.php?66256-Clock-Parts-Wanted/page3
harold bain
40,853
191
74
Re: Need
Moe, without knowing who made it, might be hard to find one. Even then, might be difficult. I've never run into one. You may have to fire up the old lathe and make one. Most hand set knobs are just a friction fit on a square arbor, and pull off.
48,936
2,695
Re: Need
I don't think that would be a challenge for you to make, Moe. Any particular reason you're looking? Originality is my guess :) Again, I'm guessing, but finding a left hand threaded die would be easier than finding the part, I think :)
moe1942
Oct 25, 2010
1,648
Alexandria, La
Re: Need
Right on..and there are zero markings on the movement. It is a well made mvt though..
moe1942
Oct 25, 2010
1,648
Alexandria, La
How about the hand set knob..Left or right hand threads?? I tend to destroy small stuff...:D
harold bain
40,853
191
74
Are you sure it's threaded? With a wind arbor, backing the wind key up against the ratchet click is needed to unwind it. There is nothing similar on the time setting knob to allow unwinding. Any I've seen just pull off.
moe1942
Oct 25, 2010
1,648
Alexandria, La
I 'm not sure Harold..I have limited knowledge of this type movement..The knob is solid or I would agree that it may pull off. Think I'll put some penetrating oil on it and see if it will come off left hand..thanks for the help..
Ck777
Nov 10, 2012
126
Small town in the foothills of NC
K und O T1
I could see that this was out of place before I bought it but, was hoping it was just "out of Place." Of Course it wasn't. The pinion to the front plate is broken, and I'm not equipped to repinion. 153914.jpg 153915.jpg 153916.jpg 153917.jpg
176,432
1,544,319
53,306
Boriss_k
1,064
3,031
