• Upcoming updates
    Over the next couple of weeks we will be performing software updates on the forum. These will be completed in small steps as we upgrade individual software addons. You might occasionally see a maintenance message that will last a few minutes at most.
    If we anticipate an update will take more than a few minutes, we'll put up a notice with estimated time.
    Thank you!
Clock Parts Terminology •
bangster
Moderator
Staff member
NAWCC Member
Jan 1, 2005
20,022
609
113
utah
Country
Region
Scottie-TX
Deceased
Apr 6, 2004
936
71
0
82
Mesquite, TX
Country
Region
Deadbeat escapement description
THANKS LAB!
JB, you can readily see the sequence here. Escape wheel is moving CW.
1. A tooth lands on ENTrance LOCKing face and continues sliding across it.
This sliding motion and distance is called OVERSWING. During this slide and overswing, wheel freezes - motionless - ergo - deadbeat.
2. As pendulum returns, tooth meets IMPULSE or LIFT face and there, tooth pushes against face providing impulse to pendulum.
3. After a brief moment or gap, called, "DROP", a tooth lands on LOCK face of EXIT pallet. Again it glides across the face during overswing. Pendulum returns again and another impulse provided to pendulum as tooth pushes against EXIT impulse (LIFT) face. Drop precedes next entrance lock.
The terms used in this diagram are the same for a RECOIL escapement altho there are two differences in motion and design.
1. After lock, pallet pushes wheel and entire train backwards - ergo recoil.
It is the energy or potential stored in this recoil that provides impulse to the pendulum therefore;
2. There are no impulse faces on the pallets and the pallet angles will differ from a deadbeat.
  • Like
Reactions: Tom is frustrated
bangster
Moderator
Staff member
NAWCC Member
Jan 1, 2005
20,022
609
113
utah
Country
Region
Hairspring lever escapement
bangster
Moderator
Staff member
NAWCC Member
Jan 1, 2005
20,022
609
113
utah
Country
Region
A generic count-wheel train, with warning
  • Like
Reactions: Times
bangster
Moderator
Staff member
NAWCC Member
Jan 1, 2005
20,022
609
113
utah
Country
Region
Wheels, 1
Big gears are "wheels"
Little gears are "pinions"
"Lantern pinions" have round "trundles" instead of teeth
"Cut Pinions" have teeth, called "leaves"
wheel & lantern pinion ann.jpg center shaft & clutch ann.jpg center shaft + hour pipe ann.jpg center wheel w lantern pinion ann.jpg balance wheel ann.jpg alarm rattle wheels ann.jpg
  • Love
Reactions: Times
bangster
Moderator
Staff member
NAWCC Member
Jan 1, 2005
20,022
609
113
utah
Country
Region
Pronouncing Clock Names (THREAD)
Forum statistics
Threads
180,049
Messages
1,570,696
Members
54,361
Latest member
mickri
Encyclopedia Pages
911
Total wiki contributions
3,090
Last edit
How To Open A Pocket Watch Case by Kent
