Clock Identification Help
BOBJAYR
Mar 12, 2009
455
ARIZONA
See attached photos.
Appreciate if anyone can identify the clock and its movement. Found out that the
wording: Monsterbeskyttet apparently means: Protected by Patent.
Looked up the name: Kunst that is on the back but could not find anything on this.
The small "J" is also on the back.
Also if anyone can assist in identifying the type of Pendulum that would go with this
clock since it was missing.
Thanks, Bob
46,404
1,856
The star and J indicate that the movement was made by Junghans (German manufacturer), sometime prior to 1893 but not far from that date.
That might help you get started on finding the actual clock name.
I'll move this to the clock general discussions forum. There's some pretty knowledgeable people over there ;)
new2clocks
Apr 25, 2005
3,297
504
Pennsylvania
Thanks, Bob
View attachment 552462 View attachment 552463 View attachment 552464 View attachment 552465 View attachment 552466
Bob,
Shutterbug is correct with his identification of the "J in a 5 pointed star" as belonging to Junghans. According to Mikrolisk.de, that mark was used from 1888 to 1890.
"Kunst" means "art" in German.
The Russian / Hungarian / Romanian (?) word that you translated to "Protected by Patent" is interesting and we can only assume that the clock was manufactured for export to that country.
Regards.
Steven Thornberry
User Administrator
Jan 15, 2004
23,345
1,462
Here and there
I believe it's Danish, but stand ready to be corrected.
BOBJAYR
Mar 12, 2009
455
ARIZONA
Thanks to all for your valuable info. I am always amazed with this message board.
Its outstanding.
Thanks, Bob
BOBJAYR
Mar 12, 2009
455
ARIZONA
Can anyone help on length and type of pendulum that will go with this clock.
2nd issue: Got clock cleaned etc and clock works and chimes nicely but when I put the hands on it will not run.
I have run into this before and found sometimes the pin that holds hands is too tight and it pulls the time arbor
up and clock stops.
On this clock I have tried everything but cannot solve problem. Any help would be appreciated.
Attac DSC01076.JPG DSC01074.JPG DSC01075.JPG hed are some photos.
Thanks, Bob
JimmyOz
Feb 21, 2008
808
167
65
Gold Coast Qld
Looking the the photos, on photo 3 it looks like the you have about 3 washers holding the sub/hour wheel, is this able to move/rotate? Also, you said you had it cleaned? :eek:
JimmyOz
Feb 21, 2008
808
167
65
Gold Coast Qld
Rotates freely
Okay so it is not that, take the hands off and just put the tapered pin in set it going and see if the pin is moving.
165,444
1,440,169
86,231
DenisBek
2,873
