clock identfication
Discussion in 'Wood Movement Clocks' started by Greg B, Jul 26, 2011.
  1. Greg B
    Greg B Registered User
    Jul 26, 2011
    Sslf/ security
    Sausalito Ca USA
    I'm new to clocks and find wood movements interesting. How do I tell a 30 hr movement from an 8 day? I understand that 8 day Wood movements are not common. Greg
  2. laumeg
    laumeg Registered User
    Jan 22, 2011
    568
    Retired, health care
    Houston, Texas
    Hi, Im probably not the most expert on this, but can add some light.
    1. 8 day movements, both wood and brass require heavier weights than do 30 hr. 8 day movements require weights of roughly 8 lbs each, where 30 hr movement weights are about 3 lbs. each.
    2. 8 day movements often require that the weight drope a greater distance than with 30 hr clocks. These clocks have taller cases and often are called tripple deckers, since they have 3 sections and sometimes 3 doors as apposed to 2.
    These 2 probably compose the most easily observed observations outside of looking at the movement itself. Hope this helps. Charles
  3. Greg B
    Jul 26, 2011
    Sslf/ security
    Sausalito Ca USA
    Thanks, that helps. I did see something about converting a 30 hr to 8 day by putting a larger dia spool(?) for the weight cord to warp around. Greg
  4. Jerome collector
    Jerome collector Registered User
    NAWCC Fellow NAWCC Member
    Sep 4, 2005
    841
    69
    Geologist, US Army Corps of Engineers
    Omaha, NE
    8-day wood works movements use compound pulleys. Also, they typically have a smaller (not larger) winding drum than 30-hr movements. The distance between the plates is also larger for 8-day movements, although this is not obvious when the movement is in the case.
    Mike
  5. Watchfixer
    Watchfixer Registered User
    Jun 11, 2011
    1,198
    TV repair tech.
    Could one explain why the 31 day movements only need lighter weight vs the 8 day that needs much heavier weights?
    Cheers, Watchfixer
  6. harold bain
    harold bain Registered User
    NAWCC Member Deceased
    40,850
    165
    deceased
    If you are thinking of the Oriental 31 day movements, the weights are only decoration, and are non-functional. These are spring driven.
  7. Greg B
    Jul 26, 2011
    Sslf/ security
    Sausalito Ca USA
    Thanks again, great site. When you say compound pulley do you mean with pulleys at the top of the case and/or a pulley on the weights. Greg
  8. Jerome collector
    Sep 4, 2005
    841
    69
    Omaha, NE
    That's right: pulley at the top and pulley at the weight.
  9. Uhralt
    Uhralt Registered User
    4,912
    599
    This sounds like a misunderstanding. The 30 HOUR movements need less weight than the 8-day movements. 31 DAY movements were not discussed and as Harold said, are usually spring-driven. Weight-driven ones would need heavier weights than 8-day movements.
