Clock Help clock faces
Discussion in 'Parts Wanted' started by Don Goss, Dec 30, 2019.
  1. Don Goss
    Don Goss New Member
    Dec 30, 2019
    I'm looking for a clock face for a Seth Thomas mantle clock I recently purchased. It doesn't have to be a Seth Thomas, as there are no markings on the existing face, but the particulars are:
    White with black Roman numerals
    6 3/4" diameter.
    1 1/2" center hole
    Key holes outside outer ring at V and VII.
  2. PatH
    PatH National Program Chair
    NAWCC Fellow NAWCC Member
    Dec 5, 2014
    1,276
    878
    Female
    Texas
    Do you happen to have a picture of the current dial? That might help others identify a possible fit. Thanks and good luck finding an appropriate replacement.
  3. Dick C
    Dick C Registered User
    Oct 14, 2009
    1,545
    41
    Without more information it is almost impossible to help.
    A photo of the dial and/or the clock that you are attempting refit with a dial is helpful.
    Is 6 3/4 the dimensions of the paper/painted dial surface or does it include the outside rim, if there is one?
    What is the distance from the center of the left winding hole to the center of the right winding hole (assuming it has both)?
    What is the distance from the center of the center hole to the center of one of the winding holes?
    Once again, a photo along with the dimensions would help.
    try the auction site?
