Clock Bushing Storage
Discussion in 'Clock Repair' started by sjaffe, Mar 27, 2019.
  1. sjaffe
    sjaffe Registered User
    Dec 25, 2012
    417
    Engineer
    Santa Rosa,CA
    At an estate sale I had the good fortune to purchase a large collection of KWM bushings. Each size was in an original KWM zip lock plastic bag. All the bags were mixed up in a box. I found a box that was about the same width as the bushing bags and arranged them vertically in order so that they could be located similar to a recipe box. It is not a complete set, so there are gaps in the bushing numbers. If I want to see if I have a particular size, I have to flip through to either find it (good!) or the sizes bracketing the one I wanted (bad).
    During a recent trip to San Francisco's Japan Town I found some very nice plastic containers made by a Japanese company called Sikiri. A web search made it appear these are only available in Japan and I could not find any on-line sources. I purchased several that had the most dividers which was 42. Each compartment is about an inch square and arranged 6x7. I was going to transfer the bushings from the envelopes to this container with each compartment labeled with the size so I could easily locate the size I needed. But then I was wondering if it would be better to keep the bushings in the zip lock bags to prevent tarnishing. Any inputs on which would be a better way to store them? Is there any value in them being in the original KWM zip locks?
    Thanks,
    Stan
  2. Willie X
    Willie X Registered User
    11,987
    691
    I prefer to use smaller boxes, with 8 to 12 related sizes in each box. A single row with a sliding top is nice. The main reason is that, sooner or later,
    you will 'spill your bushings' and it's not good to have all your eggs in one basket!
    These little fishing fly boxes are very nice.
    BTW, "spilling your bushings" is a clock repairer's term for: loosing it, going off the reservation, wigging out, etc. :) Willie X
    disciple_dan and NEWOSA65 like this.
  3. bangster
    bangster Moderator
    19,259
    327
    I would keep them in the bags AND label the compartments.
    You might look at Ronell BXP-6. 24 compartments 1-1/8" 5.95.
    NEWOSA65 likes this.
  4. sjaffe
    Dec 25, 2012
    417
    Engineer
    Santa Rosa,CA
    I thought about keeping them in the bags and stuffing a bag in each compartment (the best of both worlds?) but the sizes were incompatible.
    Stan
  5. MartinM
    MartinM Registered User
    Jun 24, 2011
    2,995
    86
    El Dorado, CA
  6. David S
    David S Registered User
    Dec 18, 2011
    7,156
    227
    Brockville, On Canada
    I keep all mine in the small zip lock bags an file like you suggest. At one time I went through them all and put a red dot beside all the ones I had on my KWM bushing chart. So now at a glance I can see my inventory.
    David
  7. sjaffe
    Dec 25, 2012
    417
    Engineer
    Santa Rosa,CA
    All good suggestions, but still would like to hear if the zip lock prevents corrosion/tarnish and if that is anything to be concerned with.
    Stan
  8. wow
    wow Registered User
    Jun 24, 2008
    3,571
    162
    Retired Music Minister
    Pineville, La. (central La.)
    I do not like the small boxes they come in because they are so easy to knock off the bench and the lids at difficult to remove. I opened one upside down once by mistake and....what a mess! I use boxes from Hobby Lobby similar to yours, Stan. I mark each with bore and OD on top using labels cut to size.....by the way, tarnishing does not matter to me.
  9. Willie X
    11,987
    691
    Yes it will delay tarnish and a tarnished bushing will be, in every way, exactly the same as a shiney new one.
    Corosion is a different matter. You may posibably have corrosion if you live by sea, or a very damp environment. I've never seen a corroded bushing that was stored in any kind of reasonably tight container. I just now opened up my big set of Bergeon bushings, still in the original paper box ... after about 40 years, no corrosion and only slightly darker than the new ones. Willie X
  10. R. Croswell
    R. Croswell Registered User
    9,399
    562
    I use a bunch of pill bottles. Paint the numbers on the tops.
  11. R&A
    R&A Registered User
    Oct 21, 2008
    4,169
    98
  12. leeinv66
    leeinv66 Moderator
    Mar 31, 2005
    9,545
    124
    Industry Specialist
    Launceston Tasmania
    I use these Aluminum Jars Storage Trays I got off Ebay. If you type in "bead storage containers", you will be amazed by what else is available.
    CLICK HERE
  13. TEACLOCKS
    TEACLOCKS Registered User
    Mar 22, 2005
    2,164
    55
    Clock service & repair
    Santa Rosa Calif.
  14. MARK A. BUTTERWORTH
    MARK A. BUTTERWORTH Registered User
    NAWCC Life Member
    Jul 4, 2009
    2,245
    67
    Diistributor of movements and movement parts.
    Muscatine, Iowa 52761
    Whatever you choose, make it something that exposes only one size at a time when opening. Also visualize how secure it is against opening when falling on the floor, or just plain fumbling around when opening. Sooner or later it happens to someone.
  15. shutterbug
    40,722
    714
    If you are in business, I think the plastic bags will be a pain to deal with. I have my bushings in their original assortment box and have not as yet dumped them. The only thing I'd like to have different is the compartment size. I can't get my big fingers into the little compartments, so have to use tweezers.
  16. bkerr
    bkerr Registered User
    Nov 29, 2007
    1,280
    Sales & Marketing Manager
    Canal Fulton,OH
    Here is what I came up with several years ago. The bottles are form a company that supplies candy oil. I put the number on front of the bottle and built a walnut rack to organize them.
    NTimken likes this.
  17. sjaffe
    Dec 25, 2012
    417
    Engineer
    Santa Rosa,CA
    What is nice about this is if you have any gaps in the sequence that you later fill, you can just insert the new bottle and still keep everything in order. Most of the other types of storage (like the divided plastic box I have) don't handle this scenario.
    Stan
  18. David S
    Dec 18, 2011
    7,156
    227
    However the recipe box method handles this scenario well.
    David
  19. bangster
    bangster Moderator
    19,259
    327
    I found some little sliding-top boxes, about the same size as the ones the assortments come in. Reduce odds of a total disaster tipover. Don't recall where I got them.
  20. Willie X
    11,987
    691
    I don't think anyone mentioned pill boxes.
    I use a large one with 14 compartments for suspension springs. A small 7 or 14 compartment pill box should be good for bushings. These things have the correct shape and good closures, even after 1000s of openings and closings, they still work fine.
  21. bangster
    bangster Moderator
    19,259
    327
    Don't swallow them by mistake.!:eek:
  22. shutterbug
    40,722
    714
    I guess I'm more of a hands on kind of guy. I want my bushings out so I can try them onto the pivot and select the one I like best. Having them in bottles or boxes would slow me down.
    Karl Thies likes this.
  23. Fitzclan
    Fitzclan Registered User
    Jul 20, 2014
    559
    Long Island, New York
    Does this mean Ronell is back? Thought they went out of business.
  24. MARK A. BUTTERWORTH
    NAWCC Life Member
    Jul 4, 2009
    2,245
    67
    R & M is out of business, not Ronell
  25. Fitzclan
    Jul 20, 2014
    559
    Ah! My mistake. Haven’t used Ronell in a while. Thanks for the clarification.
  26. Rockin Ronnie
    Rockin Ronnie Registered User
    Nov 18, 2012
    1,444
    86
    retired educator
    Greenfield, Nova Scotia
    I bought a 5488 Bergeon box of 450 assorted bushings some time ago and while I don't use many of the smaller ones it is a handy box for bushings. I will add Ronell to my list of suppliers.
    Ron
  27. claussclocks
    claussclocks Registered User
    Mar 14, 2013
    720
    178
    Texas
    If Ronell or Butterworth went away I would just cry!!:eek:
  28. TEACLOCKS
    Mar 22, 2005
    2,164
    55
    Santa Rosa Calif.
    Don't EVEN think that
