Here's a photo of Ansonia that was missing it's click spring on the time side. The wheel on the left has an original spring on it. The wheel on the right / time side shows the one that I made. I used click spring wire from Timesavers 10 pack No. 16979. I shaped the wire by hand using the existing wire as a guide. Then cut it to length & crushed the end in a vise until it fit into the slot in the click. I'm sure there are other ways, but this is how I did it.I need to replace a click spring wire (see attached photo) and wanted to get input as I’ve yet to make one of these.
If someone has fabricated such a spring please advise. Thank you.
It broke in two pieces and I don’t think I have enough left short of drilling another hole to compensate for shortage.Why can't you re-bend the wire to the correct configuration?
