Electric WW Click repair help
Discussion in 'Watch Repair' started by shutterbug, May 10, 2009.
  1. shutterbug
    41,218
    810
    This is a cheap Chinese made pocket watch. The click spring is missing, and I'd like some help fabricating one. It's quite small, and I'm not sure how it mounts, what it looks like, or where it contacts the click. I'm a clock guy, not a watch guy. Help me out! :)
  2. Cary Hurt
    Cary Hurt Registered User
    Dec 16, 2005
    2,421
    Shutterbug,
    It's likely a half round, or omega-shaped spring that lies around the screw, with one end engaging a stud on the bottom of the click, and the other anchoring against the wall of the well, or in a machined groove. They aren't terribly complex, and I would imagine it would be easier to adapt one than to make a new one, if we can figure out the basic shape. I have a couple of boxes of loose ones, and will happily send you some if we can get close to the needed dimensions.
    If you can remove the click and take a picture of the underside, we may be able to figure it out.
    I'm also moving this post to the watch repair forum for better exposure.
  3. shutterbug
    41,218
    810
    Thanks! I pulled the click out, and turned it over ... smooth like glass. No bumps, divots - nothing. The hole dimension is right at 5mm, and I do note a slot cut into the side of the wall. Any help? The bottom looks pretty much like the top, so I didn't photograph it. :)
  4. Cary Hurt
    Dec 16, 2005
    2,421
    The click spring might then be a simple horseshoe or omega with one end turned up to press against the edge of the click.
    We'll see if anyone else has ideas, and I'll see if I can find something that looks like what they suggest.
