• Upcoming updates
Mechanical WW Cleaning the green gunk off a case....
fijidad
Feb 28, 2010
326
44
Escondido, CA
Has anyone come up with a non-destructive way to remove the green gunk that collects around the back side of many wrist watches? It seems to collect around the perimeter, as shown in the attached picture. I presume this is a dried solution of sweat and oil from the skin, but other than scraping it off, is there some better way to remove it?
GeneJockey
Mar 2, 2012
1,641
713
San Francisco Peninsula
gjselgins.blogspot.com
I think it's probably verdigris from moisture and sweat reacting with the brass between the gold in gold filled watches. I scrape it off, but I think it actually corrodes back into the brass between the gold plates so it's hard to get rid of - in other words, it's not just on the surface.
I usually rub the edge with pegwood to get rid of as much as possible.
fijidad
Feb 28, 2010
326
44
Escondido, CA
I watched the video on the link and noted the salt/lemon juice/vinegar process. Having become recently enamored with vinegar and it's capabilities, I decided to immerse part of this rolled gold tank case in the vinegar/water solution I've been using for the broken stem removal; after a couple of hours, I removed it and.,...the verdigris was GONE. Rinsed it thoroughly in water, scrubbed it with a toothbrush, and now I feel I've found another use for the wonderfully simple product called vinegar.
5,773
987
Mixed 1:1 with isopropanol you can use it to get rid of athlete's foot and nail fungus.....
180,049
1,570,696
54,361
mickri
911
3,090
