Cleaning/polishing my clock
Discussion in '400-Day & Atmos' started by paddy007, Sep 7, 2017.
  1. paddy007
    paddy007 Registered User
    Apr 1, 2017
    I found a schatz 400 day clock in a shed I was cleaning. The base got alot of patina on it from the dirt it was sitting in. What is the best way to clean it without scratching it? I have heard that there is an ammonia solution that can be used. How is it made? Thanks for any help.
  2. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    1,869
    watchmaker
    Western NSW, Australia
    Pictures would be good but you should be aware that if it is a brass finish then not much can be done until all the metal is stripped back to bare metal. The laquer must all be removed before polishing.
  3. Ally
    Ally Registered User
    May 30, 2014
    21
    Hi.......It's now September so you have probably sorted it by now? If it is/was as bad as you suggest my guess is there is no lacquer left. Lacquer can be easily and cheaply removed by soaking in a 50/50 solution of vinegar and water. I used to use Brasso (a UK product) to polish, but it leaves corrosive residue, though waxing removes any residue. I now use the USA, MAAS metal polish which is excellent and has the bonus that you can wash it off your hands with soap and water. Cleaning the polish residue from the brass may be a problem if you intend re-lacquering, but I cheat and polish with Renaissance micro-crystalline wax polish (as used in museums) which both removes residual metal polish and brass particles and resists tarnishing for years. If the base is very badly tarnished then fine 'Scotchbrite' or wire wool may be used with the MAAS to cut back to bare metal, finishing with a soft cloth and MAAS.
  4. paddy007
    Apr 1, 2017
    Thank for the information! I will have to try some of these ideas.
    Paddy
  5. TQ60
    TQ60 Registered User
    Sep 15, 2016
    136
    Madera CA
    Try never dull as it is raw cotton with magic juice and it does wonders for polishing things.
    Consider any brass looking item to be very thin brass plate regardless of actual as this keeps you from getting too aggressive.
    If lacquered try acetone, alcohol or other handy solvents to cut the lacquer or clear coat.
    Do not use and rags or abrasive tools of any kind at first.
    Harbor freight 1 inch wide chip brush cut short allows for good scrubbing without scratching.
    Pour solvent into bowl and dip with brush and scrub the surface.
    When finish is removed then never dull or bon ami can be used to polish but use the mildest possible or even tooth paste as any abrasive will leave scratches matching the grit that need to be polished with finer stuff.
Similar Threads - Cleaning polishing clock Forum Date
Kundo Dial cleaning 400-Day & Atmos Sep 30, 2017
Cleaning Plastic Domes 400-Day & Atmos Jun 28, 2017
Polishing Plates 400-Day & Atmos Apr 25, 2017
Cleaning up Painted Surfaces 400-Day & Atmos Oct 22, 2016
Kienzle project and dial cleaning advise 400-Day & Atmos Oct 11, 2016
