Cleaning Plastic Domes
KurtinSA
Nov 24, 2014
5,623
556
San Antonio, TX
Specifically, is there a way to get rid of the scratches in these domes without contributing to more scratches or hazing in the surface?
Thanks...Kurt
MartinM
Jun 24, 2011
3,121
125
El Dorado, CA
I've used Meguiar's Mirror Glaze in the past to decent effect.
I'd think all of these headlight restoration products on the market might be okay, as well, but have never tried them on a dome.
KurtinSA
Nov 24, 2014
5,623
556
San Antonio, TX
Martin -
Good ideas. I'll see about finding something like that and trying it on an area near the bottom of some of my domes.
Kurt
KurtinSA
Nov 24, 2014
5,623
556
San Antonio, TX
Hmmm...and I have some Amazon cash sitting there burning a hole!! Nutjob
Kurt
KurtinSA
Nov 24, 2014
5,623
556
San Antonio, TX
Sure, that's possible, Tinker. I don't have a huge supply of glass domes and am not sure I want to spend the $20-30 it takes to buy something from Timesavers, which I have done before. I just picked up an S. Haller for $5 at the convention...and it runs! I figure if I can spend a little time on the plastic dome, it might be more attractive down the line. I have some domes which are original, thick glass...I'm not using those on this clock!
Kurt
MartinM
Jun 24, 2011
3,121
125
El Dorado, CA
Replace them with glass.
Some day, those plastic domes will be preferred for the clocks that came with them.
That said, all of my plastic domes are on a shelf in the garage or only used while I'm testing a clock for the shop I contract with.
harold bain
40,853
192
74
Finding a quartz clock with a glass dome is a real bonus, if the clock is under $5.00 as they often are at the thrift shops.
KurtinSA
Nov 24, 2014
5,623
556
San Antonio, TX
Yup, Harold, that works. BTDT. Actually I was needing to fix a quartz clock and worked through the electronics on another part of the forum. Not being able to really fix it, I found a quartz clock at the Goodwill store with the same electronics PLUS a glass dome. Win-Win!!
Kurt
BLKBEARD
Nov 15, 2016
759
24
CT
sailorsandsettlersantiques.com
​A new plastic glass dome on fleabay is cheaper than a headlight restoration kit.
AndyDWA
Dec 26, 2013
621
Western Australia
I've used Autosol metal polish to deal with fine, hazy scratches on plastic domes.
flatlander10
Mar 8, 2011
For cleaning, ordinary dish soap and dry with micro fiber cloth.
If you simply want to hide or disguise the scratches, what works for me is Pledge furniture polish.
Work well with old dashboard bezel's in your old car as well.
Doesn't remove the fine scratches but seems to fill the fine scratches to make them barely noticeable.
marylander
Sep 9, 2008
941
72
Maryland
I use tooth paste to take out scratches on the plastic watch glass. I think the same can be used for plastic dome.
Ming
177,601
1,556,519
53,629
nicobirdie
909
3,058
Watch Inspectors by Kent
