Cleaning Pivot Files
Discussion in 'Horological Tools' started by gordon, Aug 29, 2015.
  1. gordon
    gordon Registered User
    Mar 7, 2007
    223
    Retired from GM engineering labs.
    Canton, Michigan 48187
    Hello All
    I am looking for a method to clean pivot files.
    With the fine teeth on a pivot file the file card/brush will not do the job.
    Gordon
  2. Kevin W.
    Kevin W. Registered User
    21,629
    209
    What about putting them in a ultrasonic if you have one. Or Use brake cleaner and then a steel brush on them after.
  3. gordon
    Mar 7, 2007
    223
    Hello Kevin
    Thank you for the reply.
    Yes i do have a ultrasonic cleaner I can put them in. I will give that a try and see what happens.
    Gordon
  4. doug sinclair
    doug sinclair Registered User
    Aug 27, 2000
    14,364
    50
    Calgary, Alberta
    Re: the ultrasonic. It almost goes without saying- DO NOT use water based solution!
  5. gordon
    Mar 7, 2007
    223
    Hello Doug Sinclair
    I kind of figured that water based solutions would be a problem. I will have to look for something else that is cheep.
    I see their are other post on the subject that I will be reading.
    Gordon
  6. dickstorer
    dickstorer Registered User
    Oct 19, 2010
    739
    26
    Retired Military
    Hampton, Georgia
    Mr. Sinclair, what happens if I do use water based cleaner?
  7. doug sinclair
    Aug 27, 2000
    14,364
    50
    Calgary, Alberta
    Just don't! The cutting surface of a pivoting file is so fine, the file would be destroyed in no time, in water based solution! Ultrasonic machines are great, but they aren't magical. The exposure time in the tank required to clean the file would be sufficient to allow for water to rust the surface. My pivoting files are double-ended. Pivoting file on one end, and burnishing tool on the other. Rust would render either tool useless! Beyond that, I have absolutely NO faith whatsoever in the cleaning capabilities of water based solutions.
  8. technitype
    technitype Registered User
    Feb 19, 2012
    543
    Electro-mechanical technician
    Have you tried using compressed air point-blank on the file?
  9. James Foster
    James Foster Registered User
    Dec 13, 2010
    132
    12
    Clockmaker @ Your Time Clock Repair
    East TN
    Gordon
    As I cleaned my pivot file today I remembered reading your post sometime back and thought I'd share what works for me. I took a large caliber rifle cartridge and mashed the small end flat creating a comb with a handle. I keep the file card and the cartridge handy when polishing and burnishing pivots. I use the the flat end of the cartridge perpendicular to the flutes of the file and comb the debris that fills the area between the flutes. Then take the file and brush it on the card file along the flutes clearing the debris. Again, it works for me.
  10. doug sinclair
    Aug 27, 2000
    14,364
    50
    Calgary, Alberta
    A Fiberglas brush such as is used for erasing rust on steel,parts might also come in handy. I've never tried it, but it might be worth a try.
  11. gmorse
    gmorse Registered User
    10,508
    1,213
    Retired from Xerox
    Sounds like a good idea. Far less likely to damage the fine teeth than a steel brush!
  12. Smudgy
    Smudgy Registered User
    May 20, 2003
    2,816
    10
    Actually glass is harder than hardened steel, even in fiber form. It is a good method that I use when needed, but you may want to try a brass scratch brush first. Another much more tedious method is to use an Exacto knife tip, run parallel to the teeth at an angle that runs along the bottom of the space between teeth without hitting the teeth edges. It will remove the small pin blobs that seem to resist all other methods.
  13. R.G.B.
    R.G.B. Registered User
    Feb 27, 2009
    665
    Photographer
    Vancouver B.C.
    I use the old fashioned pick method. Takes a while but does the job. (make a fine point and pick each glob off)
  14. Ralph
    Ralph Registered User
    NAWCC Member Sponsor
    Jan 22, 2002
    4,684
    73
    I'd say get a piece of brass or copper and run it parallel with the teeth. Copper will probably work better... a piece of old plumbing copper will do. Do as one of the previous posts suggested with the shell. File the flattened end straight. After pushing the flattened copper through the teeth, with the grain of the teeth. it will get an edge conforming to the teeth. You should be able to push debris out of the teeth.
    Ralph
  15. piedmontg
    piedmontg Registered User
    Jun 14, 2009
    11
    Hi
    You might want to try what I use. I have mostly large files as I build scale models. There was just a discussion about cleaning files on another site. I have been using a piece of hardwood for over 35 years. Use oak or any other hard wood. I have some pivot files that I use in model building and they keep clean with the oak. All of my files also are "filed" with railroad chalk, also keeps them clean. I am sure you would not want to use railroad caulk in repairing a watch. When using just push on oak edge like you are filing it then run across the oak edge following the file cut and you should push all the junk out.
    Bob
  16. shimmystep
    shimmystep Registered User
    Mar 5, 2012
    4,085
    73
    Cambridge, UK
    just repeat what has been warned against, do not use a steel wire brush.
    Pure acetone and a toothbrush. How this quite works I'm not sure, but it does for me. I periodically put all my needle files in pure acetone, leave to soak for a few mins and then brush dirt and metal off, continuously rinsing in the acetone. Will not damage the teeth in any way.
