Cleaning Gone Bad - Be Aware
Discussion in 'General Clock Discussions' started by claussclocks, Apr 16, 2019.
  1. claussclocks
    claussclocks Registered User
    Mar 14, 2013
    743
    184
    Texas
    The question of what to clean a movement with comes up frequently. There are a number of adequate ways to clean a clock movement and I am not here today to push any one method over another. I have a warning to give the unsuspecting novice as recently found out by someone I know.
    When a movement comes in so dirty you do not want to foul your expensive cleaning solution or one wants to clean a movement without affecting the lacquer many point to a solvent such as lantern fuel, mineral spirits, white gas, VM&P, and others. Any of these will clean dried gunk with a little soaking and scrubbing. However, be aware things are changing. In California, Texas and other states there has been a push to reduce VOC's (volatile organic compound) emissions. In California and Texas industry cleaners are supposed to have 30% VOC or less. VOC's are petroleum bases such as mineral spirits, White gas, etc..
    Recently a newbie asked about cleaning a very grungy movement. He has a sensitivity to strong smelling chemicals so I told him to go to a Big Box store or paint store and get some "Odorless Mineral Spirits", commonly referred to as OMS, it's the same thing charcoal lighter fluid is made of. He called after buying it and putting the movement in and asked if it was supposed to be white. OMS is colorless. He pulled the movement and then put it in a regular ammoniated clock solution. The result is below. What he actually bought was one of these Low VOC products labeled, "Low Odor Mineral Spirits." which only contains 30% mineral spirits. The rest is water and some chemicals that keep the water and oil in suspension. I manufacture such a product for use in a particular industry so I know what is in there. Some of these compound are not friendly to brass or bronze. The point of this post is, be careful what you get. Read the labels if you are buying something you are new to. I believe I can salvage this movement but it will require some time that otherwise was not necessary.
  2. novicetimekeeper
    Jul 26, 2015
    9,294
    489
    Dorset
    How much less toxic is fatal if swallowed? It definitely degreased it
  3. Les harland
    Les harland Registered User
    Apr 10, 2008
    1,410
    120
    Hertfordshire England
    Thank you for the warning
    That is usefull background knowledge for those of use who do not normaly clean clocks
  4. shutterbug
    41,133
    792
    Yikes, that's awful! Good advise about being cautious!
  5. Old Rivers
    Old Rivers Registered User
    Oct 4, 2016
    78
    North Texas
    The "Shake Well" label would make me very leery about this stuff.
    Bill
  6. tracerjack
    tracerjack Registered User
    Jun 6, 2016
    869
    69
    Female
    Lodi, CA
    Actual 30% mineral spirits makes the giant "Mineral Spirits" on the front label of jug pretty darn misleading. I'd be fooled too.
  7. jmclaugh
    jmclaugh Registered User
    Jun 1, 2006
    4,325
    85
    Devon
    Ah VOCs, many products have reduced levels which is all well and good but the problem is with some the product isn't as good, one example that comes to mind is paint for external use.
  8. claussclocks
    Mar 14, 2013
    743
    184
    Texas
    True. Reducing VOC's usually requires using more inert materials. In the case of this product it was a surfactant and water. I manufacture a similar type product for a particular industrial application and mine does not separate and remains colorless. They took a cheap way out. I agree with Tracerjack that the label is misleading. Same principle as the longer piece of cardboard under your shorter candy bar in the wrapper. Used to be a store in this area that advertised on TV with a big sign that danced up as part of the commercial and said, "We sell Brand Name products." Every product has a brand name, but is it "Name Brand". Gotcha there
