I have serviced these clocks now for about 45 years, and I have done thousands of them. I have used
L & R 677 over all those years, followed by mineral spirits rinse and compressed air dry. That is, until one that I did, recently. I have long been dissatisfied with the effect the 677 has on the lacquered finish on the plates. With this last one I did, I decided to use mild soap and water on the plates after pegging all the bearing holes from both sides, rinsing in warm water, and compressed air drying. All the other parts were cleaned in 677, as usual. I quite liked the result. The finish on the plates was untouched, yet they were as clean as if they had been cleaned in 677! I have been converted! Oh, and by the way. I hope nobody will try to convince me to use water based cleaning concentrates! THAT is not going to happen!
