Clarke, Gilbert has a weight problem
James Lucas
Aug 25, 2020
10
Hello all, I picked up a Clarke, Gilbert & Co. OG Improved Brass Clock. I disassembled it, clean, re-bushed and reassembled. The weights that came with it are 3lb 2.7oz on the strike and 2lb 5.2oz on the time. Put the movement back into the case and found that the Strike weight is far to heavy. There are no markings on the movement. Appears to be the same as the Seth Thomas. Question, did I leave something out of the reassembly. The strike works with only a 2lb weight. the time side is working fine with the original. Obviously I'm new at this. Any suggestions as to where to find the problem would be appreciated. Thank you.
IMG_0660.JPG IMG_0661.JPG IMG_0662.JPG IMG_0663.JPG IMG_0664.JPG IMG_0665.JPG IMG_0666.JPG
46,968
1,997
Check the fan, to be sure it is not slipping and allowing the strike train to run too fast. If that's not the issue, switch the weights around and see how that works. The time side won't be terribly affected by the increase in weight, although it may wear faster. Alternately, get lighter weights.
James Lucas
Aug 25, 2020
10
Thanks shutterbug, the only thing I see is that the lantern pinion wires are pretty worn. I've tried switching weights with very little difference
James Lucas
Aug 25, 2020
10
After a more testing, using a 1lb 10oz weight and raised to the top, the strike is fast and as the weight drops about 1/4 of the way the strike begins to slow.
14,363
1,603
That is unusual.
Have you actually removed the fly and made sure it's snug on the arbor, as others have mentioned.
The only other culprits I can think of are: Friction at the pulley at the top of the case. Or, at the roller (usually in the strike side board up high), the roller could be stuck/missing, or the cord could be dragging on a notch cut in the roller, or against the cutout in the sideboard.
Notes, A stack of big washers makes a good (and easily adjustable) weight. Also, these clocks strike fast normally. Rarely slower than one hit per second.
James Lucas
Aug 25, 2020
10
That is unusual.
Thanks Willie, I'll check out your suggestions. Much appreciated--
James
James Lucas
Aug 25, 2020
10
James
Willie, I took the clock apart and the only thing that looks strange to me is the fly bushing setup. Photos attached. Haven't done that many clocks. Haven't seen this before. Appreciate your thoughts..Thanks, James
14,363
1,603
Is the plate recessed with a protruding bushing?
Anyhoo, the question at hand ... does the fly have some resistance to turning. If it spins freely on the shaft, it will need to be tightened a bit. There are many ways to do this, some better than others.
James Lucas
Aug 25, 2020
10
Willie, The bushing protrudes .54mm..The fly was free wheeling and now I've tighten it down so it does have resistance. Hope I didn't tighten too much. --James
Mike Phelan
Dec 17, 2003
10,140
79
West Yorkshire, England
If fly spring is too tight it will simply "bounce" when the strike stops. Not too much of a problem as other clocks were made like that.
James Lucas
Aug 25, 2020
10
Willie, The bushing protrudes .54mm..The fly was free wheeling and now I've tighten it down so it dose have resistance. Hope I didn't tighten too much. --James
Willie, you nailed it. By tightening fly all is working well. Thanks to all--James
167,179
1,456,780
87,348
Criseldis
