Please ID this Clock CJ & Ci. Figurine vintage clock
Discussion in 'General Clock Discussions' started by Sanjay Bajpai, Dec 26, 2018.
  1. Sanjay Bajpai
    Sanjay Bajpai Registered User
    Dec 6, 2018
    52
    Retired, hobby clock repairer
    LUcknow , India
    A figurative clock has come for repair to me. The figurine and base are gold plated. Clock is time only. From the look of the movement it appears circa 1890 - 1920. The movement escapement including some pivots and some parts including main Spring barrel have been abused by various repairers. It was found in and estate in Faizabad in India and repaired by some firm in Calcutta but never worked. No wonder as the suspension Spring was loose and made from some non descript metal leaf. The key arbour is also twisted. Some parts are in a state as to form a 'Hall of shame' pics of what not to do. The gear train seeks to be in good condition. No Crome plating is there so the clock seems to be of that era.
    The back plate is marked CJ & C (CJ & Si). Apparently French. No other marking is available except no 25 which appears on all parts which gives an impression that all parts were crafted to fit this movement. Please zoom in on backplate image.
    I request the esteemed members to identify the manufacturer and the era and suggest repair action or whatever valuable suggestions they can help me with, which will be a great help
    image.png image.png image.png image.png image.png image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg
  2. JTD
    JTD Registered User
    Sep 27, 2005
    7,208
    439
    You are right that your clock has a French movement, and indeed the whole clock probably originated in France. CJ &Co is probably the mark of the finisseur or even perhaps the importer (since it looks rather like CJ & Co, rather than CJ & Cie). Many French movements were either unmarked or only had the finisseur's mark. You might find a mark on the case, either the designer or the metal caster.
    In my opinion the hands are definitely replacements and wrong. The pendulum bob is severely corroded/cracked and should be replaced with a similar one. A nice clock and well worth repairing.
    JTD
  3. Sanjay Bajpai
    Dec 6, 2018
    52
    LUcknow , India
    Dear JTD,
    Thank you for the input. Even the pallet fork and its arbour are not original. Hand made perhaps later to get the clock going. Am starting from one end. Will definitely work on the pendulum and post as it progresses
    Regards
  4. Sanjay Bajpai
    Dec 6, 2018
    52
    LUcknow , India
    escapement pics
    magnifier_20181227_080413.png magnifier_20181227_080444.png magnifier_20181227_080530.png
  5. jmclaugh
    jmclaugh Registered User
    Jun 1, 2006
    4,573
    108
    Devon
    It looks a nicely made case which isn't always true of some of these figural French clocks. Don't recognise CJ & Co but as JTD says it is very likely a finisher. I'd say it is earlier than 1880-1920. With some tlc and restoration it will be a very nice clock.
  6. Sanjay Bajpai
    Dec 6, 2018
    52
    LUcknow , India
    Dear JM Cough
    Thanks for input. Am at it getting it in shape
    Regards
  7. Burkhard Rasch
    Jun 1, 2007
    4,747
    125
    General-and trauma surgeon
    Twistringen
    a classical French pendule , made for the typical pendule de Paris movement,either time and strike or time only.I´d put the case into the second quarter of the 19th century and I´d be interested in the material:scratch it in an unvisible region of the inside and look wether the base metal looks yellow=bronze or whitish=pot metal or spelter.I´d expect bronze.
    Regarding the mvmt. I´d prefer to restore what You have; alternatively one could be tempted to buy a loose movement from evilbay ,even a striker would be possible.But I dislike to support those clock-butcherers that part out intact clocks .
    The hands should either be spade hands or moon hands,both supplied by the trade,all other parts seem to be usable/repairable..This will be a nice and collectable clock when restored.
    Burkhard
  8. Sanjay Bajpai
    Dec 6, 2018
    52
    LUcknow , India
    Dear Burkhard,
    so nice of you for the input.It is time only and belongs to a collector and only came to me because the firm in Calcutta did what job was in the pictures. I am posting pics of suspension also. I have cleaned up the parts and would now polish pinions pivots and gear teeth as well as bush some where required. Hopefully this clock should come out and give a useful life ahead as well as pleasure to its collector. I do not charge for labour so this kind of material sometimes finds way to me where others have taken a shortcut.
    0. KD CJ & Cie disassembly (5).png 0. KD CJ & Cie disassembly (6).png 0. KD CJ & Cie disassembly (7).png 1. KD CJ & Cie cleaning (1).png 1. KD CJ & Cie cleaning (2).png 1. KD CJ & Cie cleaning (3).png 1. KD CJ & Cie cleaning (4).png
  9. Sanjay Bajpai
    Dec 6, 2018
    52
    LUcknow , India
    I presume it had hands with rings.
  10. Sanjay Bajpai
    Dec 6, 2018
    52
    LUcknow , India
    Dear Mr Burkhard
    Would you kindly confirm that the hands in the origional clock was as per image attached
    regards
    Sanjay Bajpai
  11. Burkhard Rasch
    Jun 1, 2007
    4,747
    125
    Twistringen
    Yes,Sir,these are the moon hands correct for this type of clock!
    Best regards
    Burkhard
  12. Sanjay Bajpai
    Dec 6, 2018
    52
    LUcknow , India
    Thank you so much sir
    God bless and wishes for a very happy n prosperous new year ahead to all members
  13. Sanjay Bajpai
    Dec 6, 2018
    52
    LUcknow , India
    Clock on test stand now. Pendulum nut at lower bottom for testing only. Suspension spring too stiff
    Regards
  14. Sanjay Bajpai
    Dec 6, 2018
    52
    LUcknow , India
    Assembled and testing
