• Upcoming updates
Chime volume
m151
Jan 12, 2023
41
I got mu clock with the Franz Hermle 451-033 movement running. The chimes aren't as loud as I would like. Is there any way to make them louder?
wingardclocks
Oct 1, 2007
372
21
Visit site
Hermle side hammers are the worst if you're asking me. The object is to get the hammer to hit harder, usually changing the distance from hammer lift to rod will do little effect on the side mount movement.
Adjusting the the damper spring bars is the best way achieve this. Putting a little more tension on the return spring can help also.
Make sure the hammer hits the rod square and just past the taper. Hammer tip material helps also, the harder the better. I believe BFI or maybe Merritts sells the harder brown tips.
Further more the clock case and where the chime block is mounted can matter. Good Luck
18,255
3,654
The short answer would be no, unless the adjustments (just mentioned) are off. It's the price you pay for having a thin case with no sound board ... Willie X
Reactions: roughbarked
wow
Jun 24, 2008
7,109
1,339
77
Pineville, La. (central La.)
Some clocks have holes in the back door with mesh covering them so the sound gets out and the dust can’t get in. I’ve seen some mantle clocks with holes drilled on the bottom below the chime rods to allow the sound to get out.
m151
Jan 12, 2023
41
Thanks everyone
Leo
180,078
1,570,913
54,367
shaimerej
911
3,090
