Chime setting on Hermle 1050-20, simple tips?
Uncle Lem
Jul 26, 2013
147
Working on a floating balance Hermle 1050-20, selectable 8-note triple chime. My first one. The chimes are sequencing properly, but 7 minutes early. Oddly, if I flip the minute hand upside down, it's dead on. Do I have to go through the entire chime adjustment process, or is there a simpler way to get it into alignment?
wow
Jun 24, 2008
5,180
528
76
Pineville, La. (central La.)
The minute hand should have a bushing on it that can be turned so it will line up properly. Insert a file tang or anything square into the hand and turn it until it is right.
Will
46,719
1,913
Will is right. But move it at the base of the hand or you'll bend it.
Uncle Lem
Jul 26, 2013
147
Thanks, Will and Shutterbug. Worked like a charm. Am I the only one who overthinks the small problems?
oldlawman
New Member
Mar 14, 2017
This is a much dumber problem. I can't figure out how to turn the chimes on! The chime selector is at three o'clock on my Hamilton mantel clock, seems to have five chimes to select from. It runs perfectly, but I don't know how to turn the chimes on!
djstucker
May 28, 2016
32
Valencia, CA
FYI, this is typical on a lot of German movements, especially Hermle movements. It's probably the easiest type to adjust being it is actually in the hand.
14,106
1,516
All the way up should do it and there are usually only 4 dedents. Counting from the top it is: silent, 8 note chime, 8 note chime, 4 note chime.
When the chime select lever is properly adjusted, the adjustable part that protrudes through the dial will never toutch the dial itself in any position. This part should stand proud of the dial by about
5/16".
166,332
1,449,211
86,818
stacey_AEH
2,910
