Chime rod help
Discussion in 'Clock Repair' started by ClipClock, Apr 18, 2017.
  1. ClipClock
    ClipClock Registered User
    Jun 20, 2013
    1,595
    Run small business manufacturing equestrian sector
    Kent, UK
    Morning all, I've got a clock thats suppoed to strike on 4 chime rods. One of the rods was snapped off at the taper, but still in the case.
    The rods look like they are plugged into steel (maybe?) holders which plass through holes in the chime block and are then peened the other side, not screwed.
    I drilled out the old holder (horrid job) and turned down a piece of steel (a nail actually lol) so that it was a tight friction fit in the block. Then drilled a hole in it and inserted the tapered rod. It was all a very snug fit.
    Anyhow my problem is it sounds awful, just a dull thump.
    I tried drilling a new test hole in a piece of brass in case my old steel nail was the problem, but it sounds rubbish in that too
    Cant think how to test if the rod is the problem and really not sure what to do next. Any suggestions?
  2. chimeclockfan
    chimeclockfan Registered User
    Dec 21, 2006
    3,349
    13
    Chime rod sets for antique clocks - please inquire
    WI
    The taper is probably not the correct shape. It has to be just right or else the rod will not ring out. I would look into finding or making new rods. You can take some steel or copper 3.3 MM straight wire and taper it with a lathe. Use the existing rods as a guide. Once trimmed to length, you peen the rods by flattening the captive end with a pressing tool just before they are tapped into the block. Once tapped, they are not meant to be normally removed.
  3. ClipClock
    Jun 20, 2013
    1,595
    Kent, UK
    Thanks Chimeclockfan, I was kind of hoping you might be around :) Just to check my understanding, there are supposed to be 2 pieces to this, the holder and the rod, its not one piece is it?
  4. chimeclockfan
    Dec 21, 2006
    3,349
    13
    WI
    For rods that are tapped into the block, it is just one piece: the rod itself. You may find a smear of epoxy useful for holding the rod's flattened head in the block but I find that very little was used by the original manufacturers.
  5. wow
    wow Registered User
    Jun 24, 2008
    2,131
    Retired Music Minister
    Pineville, La. (central La.)
    I know it will not be original, but sometimes I find it is better to drill the hole in the block the proper size to tap it and screw in a rod that already has the screw end on it. Be sure it is plenty long so you can gradually grind the end, raising the pitch to the exact frequency in the Westminster tune. I use a Dremel tool with a diamond cutting wheel to do that. Hope that helps.
Similar Threads - Chime help Forum Date
Waterbury Chime clock help please Clock Repair Dec 12, 2016
Please help new Chelsea Ships Clock chime out of sync Clock Repair Nov 12, 2016
Help with New Haven mantle clock chime Clock Repair Jul 26, 2016
New Haven Chime clock #6 Restoration help Clock Repair May 12, 2016
New Haven 380 Chime Movement FRUSTRATION!!!! HELP!!! Clock Repair Jan 4, 2016
