Hello. I live near Cambridge, England UK, I am new to, and learning clock terminology, I have tools and I am repairing my first clock. It is a Harold clock (UK) and the movement was made in Baden, Germany.
I recently bought a second-hand vintage Westminster chiming mantel clock with chimes not working. I found that the strike train 'governor vane' had slid along its pin and caught in the teeth of a strike train wheel, locking the strike train and two of the chime hammers with it. Now that is fixed, the clock chimes correctly BUT only when I move the minute hand, by-hand, quickly past each quarter. If I leave the minute hand to run at normal speed then the chimes flirt begins to lift at about 5 minutes to each quarter. This begins to lift the strike flirt, on which a 'tab' disengages from a slot in a 'stop wheel' in the chime train and chiming begins early and continues for 5 minutes or so. The end of the chime flirt is lifted each quarter by one of four teeth on a four-toothed-gear behind the minute wheel. As the chime flirt climbs the curved leading edge of each tooth, for about 5 minutes, it holds the tab on the chime flirt above the slots in the chime locking plate and the tab on the strike flirt above the slot in the chime chain 'stop wheel', so the chimes sound continuously for about 5 minutes with the strike sounding every full rotation of the chime locking plate. Eventually, as each quarter-hour is reached, the end of the chime flirt drops down the 'steep' trailing edge of the tooth on the four-toothed-gear behind the minute wheel, the chiming flirt drops and with it the strike flirt such that the tab on the strike flirt drops into the slot in the chime train 'stop-wheel' and the chiming stops.
It is as though the chiming flirt has been bent so as to start the chiming too early but I can't imagine this happening in normal use and because it is flat-sectioned for rigidity, I wouldn't expect it to bend easily.
Can anyone suggest a cause and a fix please?
Also, there is a sprung pin located in the chime locking plate which acts on a tab on the chiming flirt to lift the chiming flirt just before the hour. I can't see what function this has. It does not trigger the strike as this is triggered by the high point on the chiming lock plate, lifting the chiming flirt and hence the striking flirt high so as to unlock the strike train and drop the rack. Can anyone tell me what the sprung pin is for please?
Attached images show 1. general view of the back of the movement, 2. 'Tab' on the strike flirt located in the chime train stop wheel, 3. Strike flirt with tab at the top going through the back plate to the strike train stop wheel and tab at the bottom locating in the chime locking plate, 4. side on view showing the 4 tooth gear behind the minute wheel and the end of the chime flirt riding on one of the four teeth.
