Chelsea timesaver model
Discussion in 'General Clock Discussions' started by Artillero, Apr 15, 2017.
  1. Artillero
    Artillero Registered User
    Feb 22, 2014
    67
    Engineer
    Nevada and California
    Gentlemen,
    I have a couple of questions for the Chelsea aficionados. I am not finding much information about the Chelsea Timesaver model other than that it was manufactured during WW2 and into the early 1950's. What movement was used in this model and was it better worse or the same as the other movements produced by the company? Was this style primarily supplied to the US Government and how common were the nickel plated models compared to the brass cased models? Attached is a picture.
    Thank you,
    Artillero
    [​IMG]
  2. James McDermaid
    James McDermaid Registered User
    Apr 29, 2011
    34
    It appears to be a 12E style movement which is a good clock. You should find a serial number on the back of the movement which will date it.
    Likely 7 jewel movement.
    You remove the screws holding the face to the case and I lift it up by the winding key until I can get my fingers under the edge.
    By WW2 most cases were Bakelite due to the need for metal by the military. So Brass was scarce and nickle plating probably a little more scarce in these years.
    A lot of Chelsea clocks are in a different case than they started life in.
    Seems like a bunch of parts for these on ebay including new faces and Chelsea official winding keys.
    Jim
  3. Artillero
    Feb 22, 2014
    67
    Engineer
    Thank you for the info, Jim.
Similar Threads - Chelsea timesaver model Forum Date
Howard Miller Presidential Series Jackson Model General Clock Discussions Sep 19, 2017
When did Chelsea stop producing ship's clock movements? General Clock Discussions Jul 19, 2017
Chelsea Clock Dial Question General Clock Discussions Mar 15, 2017
Resetting Hands to Coordinate with Strike on Chelsea Banjo Clock - A little help pls General Clock Discussions Feb 7, 2017
My friends Chelsea Ships Clock General Clock Discussions Dec 24, 2016
