Today I picked up a time only Chelsea Ships Clock with a 6" dial. It has two electrical contacts coming out of the case at the 4:30 position, and these are connected to a wire that is in turn connected to the center of the movement. Can anyone tell me what this setup is for? It is a mechanical movement with a sweep second center hand, and the serial numbers on the case and movement match, and seem to date the clock to the late 70's to 1980. I can try to post pics a little later. Thanks. George
