• Upcoming updates
Chelsea Parts Clock
Les Sanders
Apr 3, 2010
976
57
Sahuarita Arizona
I bought this Chelsea for a parts clock. It looks like it may have been thru a fire. What type of solution should I use to pre soak it before I put it in my cleaner?
49,720
3,038
Maybe you could just rinse it off. If you want to soak it, try Dawn dish washing liquid and water. Don't go for a prolonged soak though, for fear of rust.
JTD
Sep 27, 2005
11,131
1,625
I agree with Shutterbug, a lot of this would just wash off with warm soapy water and a soft brush. But I would take the platform off first and deal with that separately.
JTD
Les Sanders
Apr 3, 2010
976
57
Sahuarita Arizona
View attachment 484475 View attachment 484476 View attachment 484477
OK so as I continue to work on this Chelsea, the gear assembly I needed it the first place is the # 4 Wheel and arbor, this is a Old Style L movement around 1943. Anyway it has a bent pivot Chelsea arbors a hardened steel and easy to SNAP plus this has been hot enough to turn the arbor Black. Should I heat it to red and it cool before trying to straighten it or :???:?
5,781
993
Just to be safe I would anneal it. You don't know how hot it got in the fire.
Les Sanders
Apr 3, 2010
976
57
Sahuarita Arizona
I would say the strike side looks good, by the time side are warped. The gear I am going to try and fix to day is the #4 time side. Remember this is a Old Style L movement.
Karl Burghart
Jan 30, 2012
222
34
Ballston Spa, NY
Chelsea part number 1213, Fit's both the L and 4L as well as the E and 17E. We have them if you need them plus escapement parts or an overhauled and tested escapement.
Karl Burghart
Jan 30, 2012
222
34
Ballston Spa, NY
Ok, It looked in the photo like the 2nd wheel. We do have the 4th you need. Just send me a PM when you're done inspecting and we'll get you what you need.
Les Sanders
Apr 3, 2010
976
57
Sahuarita Arizona
Karl, I was able to straighten the pivot, after putting the wheel back in it will escape a bit, I am going to check and see if the wheel is out of round, I will let you know1
Les Sanders
Apr 3, 2010
976
57
Sahuarita Arizona
Ok the 4th wheel is OK I put it in and used finger pressure it escapes fine. I am going to add one more gear at a time and see how it works out.
Les Sanders
Apr 3, 2010
976
57
Sahuarita Arizona
Back to my Chelsea Saga, Thanks to Karl Burghart for the 4th wheel assembly it is going to work just right. During final assembly of the platform escapement I ran into what I think is a minor problem, the jeweled pallets are a tad bit loose in the fork It this a normal situation?
49,720
3,038
The tighter they are, the better the clock will run. Loose pallets will absorb power that should be going to the crutch.
49,720
3,038
More than likely, yes.
5,781
993
It is important to re-shellac the pallets (and maybe the roller) or they may become loose and get lost. Happened to me once.
180,087
1,571,001
54,369
wbaNev
911
3,102
