Chelsea Clock Company
inbeat
Nov 10, 2000
1,866
13
77
Portland, Oregon
Starting this off with a couple and will add to it a few at a time.
Chelsea "Commander/Base and Ball" with 8 1/2" Special dial and hands. Louis Weule Company. Strikes ships bells. Circa 1915 IMG_7209.jpg
Chelsea Base and Ball 4" dial. Engraved "J.E. Caldwell, Philadelphia" Circa 1906.
claussclocks
Mar 14, 2013
946
337
Texas
I have this 6" Chelsea with the screw front bezel. I found it at an estate sale. They priced it rather low because they couldn't get it to strike the hours 1 - 12 like a clock should.
Based on the serial Number this clock was made between 1965 and 1969.
It does strike at about 3 minutes past the hour but I have been unable to budge the minute hand bushing. Anyone have a suggestion. I do not want to damage the hand
Ralph
Jan 22, 2002
5,660
562
If anyone has a spare brass Chelsea case for a 10" dial engine room clock and will part with it, send me a PM. I also need a Watham movement for an engine room clock. Thanks.
Ralph
rmarkowitz1_cee4a1
Nov 26, 2009
6,856
2,031
I must admit, seeing the wonderful clocks posted here I do feel a bit humbled as I post my latest find.
Over the past few years, I have actually found and yes, sold, some rather nice Chelsea clocks and clock and barometer sets. I may be dating myself, but Garett Morris on SNL used to do a recurring character, Chico Esquela, a fictional shortstop for the NY Mets. To borrow and modify his tag line, "Chelsea has been berry berry good to me".
I've kept some 2/3 sized Chelsea banjo's from the 1920's. They have some wonderful hand painted glasses including one of the Bulfinch designed state house in Boston.
Tonight, I thought I would share a recent Chelsea find.
It's called a yacht wheel model:
I've done some research on line including this wonderful website: Chelsea Clock Museum . Much good info. Furthermore, I've been encountering enough Chelsea's that I ordered the book by Demeter. Need to expand my knowledge base.
The "bronze" finish was most definitely an available option for this this clock. That's what this one has. Untouched and it shall remain so. The mahogany base is in a wonderful crusty finish. Untouched and it shall remain so. Here's some additional views:
The bezel is hinged and has a push button rather than screwing off. Much more convenient.
The silvered dial is 6 inches. I learned that the use of raised applied numerals and the "fancy" hands was an extra cost option.
Based upon the serial number (sorry, forgot to record), I recall that it dates the clock to the 1920"s.
It's a big impressive clock. Here it is with a more typical, IMCO, Chelsea ship's bell:
I found this clock on Charles Street on Beacon Hill in Boston. I had an appointment @ the nearby MEEI and arrived early. I hadn't picked nearby Charles Street in nearly a decade, so I thought, WTF. A very shee-shee area and generally everything is ridiculously overpriced there. But, it is still worthwhile taking a look Never know when you might luck out. The clock wasn't cheap but not crazy and worth a shot.
I thought I would throw in a bit of the superfluous. Sorry, not my personal thread.
Recently, I've been coming across some interesting antique tools which has been a new learning experience for me. Amongst the recent finds is this relatively small portable table top lathe:
IMCO, a wonderfully made object. Solid oak with great giant dovetails:
Note the cast iron handles so it could be picked up and moved. What really piqued my curiosity when I first saw it was the use of whale bone on the tail and head stocks:
The whale bond on top of the head stock is darker. There are oiling ports in the whale bone on the head stock to lubricate the spindle which darkened it. SO, as it should be.
The history from the seller was that it came from New Bedford, MA, a city very involved with whaling.
After consultation with Jim and a few others, I concluded it was a small lathe used to turn whale bone into a variety of small objects, e.g., the tops of canes, finials, etc., etc.
I brought it to an antique show. Caused a bit of a sensation and it sold during set up to an important dealer in maritime antiques. In his hands, I'm sure a zero or 2 will be added to the price. That's fine. I made $$ on a quick flip. I'm also happy with my position low position on the antiques food chain. I've launched quite a few things which, to my great satisfaction, have climbed up.
RM
Douglas Romero
Nov 3, 2001
366
149
New England
Here are a couple of my favorite Chelsea’s.
1st is a rare 1905 Mahogany and Metal or Commander with the wide fluted bezel. It is a 10” orig Special model dial. Case likely redone some years ago. Has a long original key to lock it. This model not often seen.
2nd is an early 8 1/2 inch Special dial art carved number 3. Also not seen too much.
Doug
A7A82292-2AA2-4621-BF60-A49781650D71.jpeg View attachment 463260
Robert J.
Golden Circle
Dec 1, 2008
25
The 10" Mahogany and Metal is also a favorite with me. Mine is Time Only, S/N 22475,
dating the clock to around 1906. Great original dial; case re-polished.
ClockMogul
Oct 1, 2011
824
68
Ohio
Here is my humble addition and only Chelsea I own. This is a 12 Inch Special Grand Tiffany Dial with Brass Ball Feet with matching serial numbers on mechanism and bottom of base to 1909 I think. This was out of the Fisher Body Estate Auction in Detroit, Michigan a few years ago..
rmarkowitz1_cee4a1
Nov 26, 2009
6,856
2,031
View attachment 489916 View attachment 489917 View attachment 489918 View attachment 489919
Is that 1 of the clocks that’s in storage you’re considering putting on Craig’s List because you were bored with clocks & wanted to cycle across S.E. Asia instead ??
RM
brian fisher
Jan 20, 2017
1,821
475
houston, tx
man....the examples in this thread make my 6" clock seem like a mouse in a room full of elephants. I guess I only paid 50 bucks for it tho.....
over the course of years I plan to have a decent collection of ships clocks particularly the larger ones.
that 12".....just fantastic!
ClockMogul
Oct 1, 2011
824
68
Ohio
There is but a handful of 12inch Dials that are SHIPS BELL and SPECIAL GRAND....Extremely scarce to say the least...!
Cliff Smith
Jan 23, 2014
10
Hi all,
Trying to learn what the numbers mean on my 24 hour, bakelite Chelsea.
The ones etched on the back, one of them being DT-0407-1092e4 and the other being in not so great printing 220260. Would'nt mind learning all I can about the number on the face, 364E
Thanks for any help anyone can give.
Cliff
Douglas Romero
Nov 3, 2001
366
149
New England
Hi all,
Cliff
View attachment 494513 View attachment 494514
Cliff, my quick searching does not yield any info as to serial number on the case as 364E. As Chelsea Clock Co. reps have said in the past these serial numbers on the dials were assigned by the US Navy and not tracked by Chelsea. My guess this would be a fairly early one that the US Navy ordered from Chelsea prior to WWII. Since 220260 is printed on the back that is very likely the movement serial number which would make production date between 1935-1939. Easy to remove the movement out to verify that number.
As to the DT-0407-1092e4 maybe an service number marked on the case.
I thought the DT and Navy serial number might lead on the Net to perhaps a decommissioned US Navy vessel. I can’t locate anything yet and the 364 would not be the Hull Number that I can find with a DT destroyer classification. There were DE classifications for Destroyer Escorts. Maybe the DT is for Destroyer Transport?
Maybe some old Navy men can provide better info. Good luck in your search.
Doug
Happychi
Nov 16, 2018
Taken from a reply from the Chelsea Company...."We have checked serial number 186803 and the information is consistent with the clock you have showing it was sold to Norris Al. Ball Bridges Company on November 24, 1928 and it is listed as a # 4 wall clock so this information is consistent with the clock in your photos. Please note this is the exact same information a certificate would contain and the certificate is not intended to be a legally binding document of ownership or valuation but more of a showpiece for all that may see the clock and wonder where it came from."
Also, further research shows the Norris Alister Ball Bridges Company, wholesale jewelers located 58 E Washington St..
In the NAWCC Bulletin, Voluma 39, Page 793 we see: The Norris Alister Ball Bridges Company was absorbed by Webb Ball; the name
Norris Alister Ball Bridges Company, shortened to Ball Company.
Could this possibly be the office clock for the Webb Ball Co.?
Bill Magee
New User
Feb 10, 2020
Hi, I was able to acquire a large 1903 Chelsea ship bell clock. It has a serial number in the low 5000's. Is there much value in the clock. It is in good condition, could use a cleaning. Just trying to figure out the value.
thanks
bruce linde
11,103
2,714
oakland, ca.
clockhappy.com
thanks
bill... welcome! always best to start a new thread for each clock/watch being discussed... but you're going to want to post this... with large/clear photos of all perspectives... in the 'what's it worth?' forum. discussions of value can only happen there, and informed responses only if people can see model, condition, etc. looking forward to seeing it...
oldcat61
Dec 12, 2008
190
15
South Jersey
Good to see this thread revived. Here's a radio room clock from 1943. Chelsea records only show it was sold to US, so no idea if on a ship or a radio room shore.
Jim M.
May 30, 2019
184
33
MA South Shore and FL Cape Haze
Greetings,
I enjoy coastal sailing and have often seen Chelsea Ship Bells and Barometers fitted on sailboat bulkheads. This 1912 era 6” Chelsea Commander Ships Bell was purchased from an estate ~ 15 years ago. Our family particularly likes this antique clock and the way it is displayed. It keeps good time and the ship’s bell chime is pleasantly tonal and crisp. The photo displayed next to the clock is my wife’s father, born in 1912 too. We have always intended to maintain ownership of this clock so --- I wrote up an accompanying description for the clock and the story about its’ attributed provenance from Harvard Law School.
Best regards,
Jim M
Chelsea 1912 Commander Ships Bell Clock, Theodore B. Starr Inc.
H.L.S Engraved Harvard Law School Clock
Chelsea Ship’s Bell Clock
The 6” silver dial Ship’s Bell Mahogany and Metal Base AKA ‘Commander’ clock is in original 1912 condition with same matching factory serial number 86,264 stamped on the bell housing, movement, and mahogany base. The ‘Commander’ clock is a desirable collectable Chelsea since it combines attractive elements of the bronze Ships Bell with bronze and mahogany base elements. The Ships Bell clock can also be removed from its mahogany base for bulkhead mounting on ones yacht during summer and returned to its base for winter mantle shelf use.
The ‘Commander’ first appeared in the1906 Chelsea catalog and was offered in relatively limited numbers over time, especially in 8 ½”, 10”, and 12” dial sizes. Cost of the 6” dial ‘Commander’ clock was relatively high at $62 (1911 catalog pricing), when compared to a typical expected mean annual salary of $700 for that era. Factory production of the ‘Commander’ clock was discontinued due to economic conditions precipitated by the Great Depression (8 ½, 10, 12 inch sizes in 1931 and all other sizes by 1938).
The H.L.S engraved 1912 ‘Commander’ clock is a desirable 118 year-old antique with vintage patina presence. Consensus of purist antique collectors is this clock should not be re-polished or re-finished. Antique preservation experts have recommended light coating treatment with Renaissance museum wax to preserve bronze and mahogany patina appearance. Resellers tend to polish and refinish old Chelsea brass clocks; thus, clocks having untouched patina finish are rarely found.
Theodore B. Starr (inc.) New York
Theodore B. Starr and Sons operated a Fifth Avenue Manhattan NY shop that competed with Tiffany & Company and sold fine items to wealthy families and patrons. Among the retail items offered were diamonds, jewelry, silverware, china, watches, fine accessories and clocks including Chelsea clocks.
Certificate of Origin records are maintained at Chelsea Clock Company date back to 1897 and factory records indicate 6” Commander Clock serial number 86264 was assembled in 1912 and shipped from the Chelsea factory on February 28, 1913 to original retailer, Theodore B. Starr Inc. The original retailer is often a prestigious firm, so a retailers name is typically engraved on the silvered dial of Chelsea clocks during production at the factory.
Theodore B. Starr and Sons Inc. continued as a family operated business from 1862 until acquisition in 1917 by Reed & Barton Silversmiths Inc. (Massachusetts). Mr. William Bradford Homer Dowse, then president of Reed & Barton (Mr.Dowse was also son-in-law to founder, Henry Reed) served as a key player in the acquisition, and became the new president of Theodore B. Starr Inc.
Harvard Law School Provenance and William Bradford Homer Dowse
H.L.S is a commonly used initialism (acronym) for Harvard Law School. When this Commander clock was acquired at an estate sale in Asheville, North Carolina, family relatives indicated the clock was originally from (attributed to) Harvard Law School.
Interestingly, Mr. William Bradford Homer Dowse, president of Theodore B. Starr Inc.was a ‘double’ graduate of Harvard College and Harvard Law School. Dowse became a successful patent lawyer after graduation, licensed in Boston and New York. He moved into industrial manufacturing ventures as founder and president of Boston Fastener Company. Dowse also served on the Board of Directors at Waltham Watch Co. (Massachusetts). Waltham Watch supplied elegant time-side escapement movements in Chelsea Ship’s Bell clocks for the first 60+ years of Chelsea Clock Co. operation.
Dowse’s thread of connections at Harvard and among the companies: Theodore B. Starr Inc., Waltham Watch Co., and Chelsea Clock Co. are strong. Dowse was a loyal alumni and contributing benefactor to Harvard Law School over the years.
Bruce Barnes
Mar 20, 2004
2,045
87
This clock at present is the only Chelsea that I own but maybe it can "squeak" in here as it strikes the ships watch. It has the bronze finish, porcelain dial and raised numerals.
Bruce
Snapper
Nov 30, 2014
313
40
Lincolnshire, UK
This my only Chelsea clock acquired many years ago and one of the first to form my modest collection of clocks. It ran perfectly for many years until it called out for assistance by running somewhat erratically. I stripped, cleaned, reassembled and oiled it then promptly crushed the bare platform base plate beneath another object thus breaking the banking pins. A subsequent call to a fine watchmaker resulted in the platform being despatched for a full service and the manufacture and fitting of new pins. It has now been running for over twelve months and keeping time to with one minute per week and is indeed my relied upon mantle clock for everyday consultation.
The serial number dates it to 1911 and it was reputedly awarded as a prize to the winner of a yacht race. It was retailed by a the renowned instrument suppliers Robert Stewart of Glasgow. This is one timepiece with which I would never part.
Shipsbell
Apr 12, 2010
151
View attachment 458747 View attachment 458748 View attachment 458749 View attachment 458750 View attachment 458751
Did anyone answer your question?
Patrick
ClockMogul
Oct 1, 2011
824
68
Ohio
RM
Yes this is long gone to someone whom will care fir it a lot better then I was able to for sure. Yes the clock thing is history to me as I actually am in "SE ASIA" as Type this message now. Come to find out that was one scarce puppy for sure..:)
MLSchlot
Business Member
Feb 10, 2001
533
31
Fairhope, Alabama
thesandsoftime.biz
Never heard back on that adjustment and haven't had time to experiment. If you have some helpful input I would appreciate it
If I understand correctly, you have a "house strike" Chelsea that is striking about 3 minutes after the hour and half hour? The adjustment is best made on the center shaft of the movement.
The center shaft assembly contains the 64 tooth center gear with a 10 leaf pinion directly behind, followed by a thrust washer, and collar. The collar contains two polished pins which lift the strike warning lever at the hour and half hour. Two set screws secure the collar to the center shaft. You can loosen those screws and nudge the collar in either direction to the point where the warning lever drops off the pin when the minute hand is positioned at the top of the hour.
Take care to ensure the collar doesn't back away from the thrust washer. The collar and washer combine to push against the center gear and pinion, which in turn puts a controlled amount of pressure to the center shaft, This allows the minute hand to be manually turned to set the time, but maintains sufficient pressure so the cannon pinion can drive the motion works. If the washer is too loose, the clock will run, but the hands will never move. I hope this helps.
Regards . . .
Kevin W.
23,756
807
65
Very nice Chelsea clocks, i have three and enjoy them very much.
Bsohne
Sep 1, 2020
65
58
58
hi
Wanted to share an uncommon sized Ship's Bell I have seen two of these both on ebay …..
For size comparison...
6 inch dial SB : back flange : 7 11/16 depth of case : 3 1/2 inches
6 3/4 inch dial SB : back flange : 8 7/16 depth of case : 3 3/4 inches
8 1/2 inch dial SB : back flange : 10 11/16 depth of case : 3 3/4 inches
The 6 3/4 has a lot more presence then a 6 inch SB in my opinion . If you come across across one of these without anything to go on you might miss it .
I will work on getting a group shot of the three cases above..
As you look at the 6 3/4 SB it's just a little different .. the reflector ring is actually cast as opposed to stamped sheet metal … the dial is actually 6 3/4 in diameter . See images attached .
My example was sold to William H. Enhaus & Son Company on March 11, 1920 w a 6 3/4 dial.
I saw a second example on ebay back in 2018 but I can't find my photos of it . That clock was sold to Dr. Joseph Skirball on October 18,1933 and it was listed as 6 ¾" ships bell clock.
Reviewing the posted Chelsea Catalogs on the Chelsea clock Museum ... The 1917 Catalog makes no mention of a 6 3/4 Ship's Bell.. The 1923 catalog offers a model number " 103 1/2" as a 6 3/4 Ship's Bell Hinge bezel configuration only. It is also listed in the Chelsea leaflet "A" dated March 1, 1926. It is also listed in the 1929 catalog as well... By the 1936 catalog , number 19, the 6 3/4 Ship's Bell was not longer offered and the reference to any model numbers of the "103 1/2" format was also removed .
I have to assume that Chelsea was selling the 6 3/4 dial size Ship's Bell model # "103 1/2 " from at least 1920 (year my clock was sold) to 1933 ( last clock I have seen in the wild was sold). …
Has anyone else come across this size ?
Good Hunting
Bill
Bsohne
Sep 1, 2020
65
58
58
Hi
I just wanted to add a post I did for July 4th here...
Happy 4th of July for all the users in the USA and happy belated Canada Day as well !
For your consideration …. I classic pre 1900 4 1/2 inch dial marine clock. What is uncommon about this example … according to the sales ledger at Chelsea Clock company … this clock was sold directly to the USS DIXIE ……in 1899. It really great to have this type of documentation in the Chelsea Clock Company archive ….
From Wikipedia
The first USS Dixie (later AD-1) was a United States Navy auxiliary cruiser and later a destroyer tender. The Dixie was the first ship of the United States Navy to have this name.
"Recommissioned 15 November 1899, Dixie began service as a training ship for recruits. From 17 December 1899 to 8 August 1900, she sailed to the West Indies, the Mediterranean, through the Suez Canal to the Philippines, where she transferred men to the base at Cavite, returning to the United States by the same route. Another training cruise was made from 29 September 1900 to 28 February 1901, during which she visited the Azores, Madeira, Gibraltar, and Mediterranean ports returning by way of the West Indies and La Guaira, Venezuela, to Norfolk. She transferred men and stores to the South Atlantic Station between 7 May and 3 July 1901, then made another training cruise to northern European waters and the Mediterranean between 24 July 1901 and 7 May 1902. From 14 May to 6 June 1902 she was on special duty, transporting provisions and supplies for the relief of victims of the volcanic eruptions of La Soufrière, St. Vincent and Mount Pelée, Martinique in the West Indies. She went out of commission at New York Navy Yard on 21 July 1902."
She was built by Newport News Shipbuilding and Dry Dock Co., Newport News, Virginia . In 1893 and then acquired by the Navy in 1898 …
I have also see a painting of the Great White fleet … with all the large ships but the USS DIXIE was there ! See photos below.
As usual , long after the ships are gone all we have left is a maybe a bell , a photo and or a clock …..
Happy Fourth of July
Bill Sohne
Staff online
183,860
1,605,832
55,918
Haydee
3,190
Watch case by Kent
Top Bottom
