Hi All, Does anyone have any information on a clockmaker from early 18thC by the name of Charles Murray. He was apprenticed to Thomas Tompion and is listed in Baillie as 1702 although Loomes simply says "not 1702". He was obviously working around 1715-20 in London given the one piece of work I have seen but for someone apprenticed to a very famous maker he it is incredibly difficult to find any information on him. Thanks in advance if anyone has anything. Cheers Dean
There is a Murray widow (not a merry widow but who knows) who received income from a charitable fund for clockmakers set up by East, but that is a bit earlier. A father?
Not everyone who was apprenticed would have gone on to make clocks under their own name - to do that you needed to be a businessman as well, and have enough money saved to set up your own place. So many went on to be journeymen. Some might have tried to strike out in business only to fail. It might be worth looking at bankruptcy court records or the like to see if you can find him?
After much searching it turns out Murray was a blacksmith. Thomas Dyde bound Charles Murray through the Blacksmith Company in 1680 and he was turned over to Thomas Tompion in 1686. Thomas Dyde died in 1686 so maybe that is why he was transferred to Tompion. Charles Murray took at least one apprentice of his own. MURRAY. --------- took MIDDLETON. Thomas. tof TAYLOR. John. 7:4:1718 ====== MURRAY. Charles took GRIFFITH. Thomas or George. tof LATHAM. John. 5:6:1712 4:7:1720
It comes up a treat. It would be good to hear those bells chime. Was Thomeas Dyde, or maybe his father a blacksmith, so that once they were in a company ( read union??), they could then legally make clocks having been properly apprenticed? David
Different lighting, different camera, no polishing. First pic is from the auction house. I use a floodlight for infil and now it is autumn I have to use flash.
My understanding is the livery companies only had control in the City of London, but yes you had to be in a company to make a clock, so you had served an apprenticeship to become a member of a company and free to trade in the city. It didn't have to be the clockmakers, broderers and goldsmiths also made clocks and watches.
Hi Zedric, It hasn’t been touched as yet and the case needs a lot of work. The difference is that Nick takes far better photos than the auction house who took the first photo!
Dean, Are you going to replace those ordinary looking movement to case brackets with something closer to what was probably there originally? David
Tompion took on apprentices from the Blacksmiths and Goldsmiths company to avoid the restrictions on the number of apprentices he could maintain at one time. Murray was originally a blacksmith as Tompion may have been himself.
I don't think he will be allowed not to Will do a video this eve if I remember, first day back after half term, may just fall asleep!
Good!! Even though he says he will look into it and I am sure he will apply due diligence, they still don't look right. ß
It's a fairly early clock with some of its own idiosyncrasies, the first think is to look at the straps and see if the are wrought iron, because that would age them. I'll have a look under the microscope at the structure and how they were made. It's Dean's clock, but I know the repairer and he loves a bit of bling. I know he has replaced straps before but the problem then is do you get them engraved? Blank brass even of the correct colour is going to stand out more.
For sure I appreciate he has the final say over his own clock and I know him well enough to know that he will make the right decision and not do anything thaat he feels is historically inappropriate. David
Those brackets are made by a smith. They may be original, they are certainly old. The bells aren't fixed very firmly, I had to fiddle with them to get anything approaching a decent sound, they need an expert.
Interesting observation of the brackets from being there "onthe spot" and thanks for the video of the bells; despite their slightly infirm sound, I can hear that they have a really nice sound - or so they sem to me anyway. David
The bells are just a bit loose. I ran it before when I first took it out and it sounded much better, should have done a vid then. I wrapped it to go to the clock repairer then unwrapped it again for the video but all the bells had moved and it just made dull thuds. I had a play and got them back to working sort of. As you say you can hear their potential rather than how they should be. I suspect that when it comes back from the repairer all perfect it will again go through this stage as I may be advised by the repairer to remove the bells for shipping, Dean will then have to set it up again. There are already two here that will have the bells removed for shipping. Some clocks don't have the strap at both ends of the set of bells leaving them rather vulnerable. I will, though, take another video before that.
