Hello, let me introduce myself. My name is Jaap, I live in the netherlands and I'm servicing clocks as a hobby. At this moment I have a JUF Anniversary clock, and I think it is plate number 1595, no serial number on the plates. During inspection of the mainspring Ifound this problem. Is it best to replace the mainspring with a new 19x36 especially there is no sign of a set mainspring. Thanks for reading and looking.
Jaap
Hello Jaap and welcome to the NAWCC Message Board! Your clock was made between early 1927 and about the end of 1931 based on known dating references. JUF stopped using serial numbers at the end of 1922; after that only a logo stamp (or stamps) was applied:
- From 1923 to 1st quarter 1927 there were two stamps, the JUF "Double Elephant" at lower center and the circular "Jahresuhren-Fabrik G.m.b.H. Germany" up and to the right of the Double Elephant.
- From 2nd quarter 1927 to about the end of 1931 there usually was only the Double Elephant stamp, however on some clocks in this period the words "Germany" or "Made in Germany" may be found at the lower right.
- After 1931 and onward to the end of 1939 when production stopped for WWII, there was no logo or serial number present.
NOTE that in all the above backplate variants, you may find the name of a major trader or retailer provided they were a significant customer. In addition, on many movements there will be a small letter stamped at the lower left corner of the back plate. To date, we have documented the letters D, F, G, H, J, L, O, R, S, and W. The meaning or purpose of these letters is still not known, the best guess seems to be they were used to designate a model or a customer.
The dial design you have was made in a number of colors, and it is very likely that the movement support pillars and the pendulum balls were painted with the same color lacquer when the clock was new.
With regard to the mainspring, have you tried cleaning it with fine steel wool to see if the discoloration can be removed? To clean, vigorously rub both sides of the spring with 0000 grade steel wool and a solvent such as light naphtha. Normally this will remove all deposits such as gelled oil, gum, and light surface rust. The original bluing will disappear and the spring surface will be a grey steel color. You can then inspect the entire length to see if there is any sign of cracking or corrosion pitting that have been mentioned by Sam. If there is no cracking or corrosion pitting the spring can be re-used, otherwise a new spring should be installed.
Please keep us informed of your progress with restoration of your clock, photos will be appreciated!
