Thank you so much, I will send more photos tomorrow'Cervine' was a name used by Achille Hirsch Co. Can we see the movement?
JTD
First of all I would like to say sorry for my delayed reaction.Is there a stamp under the balance? I can see a 190 next to the pallet cock. These were gents watches, that movement looks like 11.5 or 12 ligne. Ladies watches were all far smaller in the day.
Why yes MrRoundel. THis be correct. I did look at FEF 190 but 190 must have been the number Hirsch put on it.I finally got ahold of one of those handy Paulson's Movement guides that helps ID movements from the bridge side. From what I can see, the movement sure resembles a Fleurier 311. Does that makes sense, roughbarked ? If you separate the 4th/escape wheel bridges it looks very close to me. 11.5 ligne. Pg. 126 of this catalog.
Good eye mate. It does appear to be a variant of FEF 311. On that same page, the set bridge on FEF 222 seems to be identical as 311. Imo, 311 seems to be a variant of 222, which itself is likely a variant of an earlier movement.I finally got ahold of one of those handy Paulson's Movement guides that helps ID movements from the bridge side. From what I can see, the movement sure resembles a Fleurier 311. Does that makes sense, roughbarked ? If you separate the 4th/escape wheel bridges it looks very close to me. 11.5 ligne. Pg. 126 of this catalog.
If you go through the FEF movements, almost all are very similar. Iin fact I don't know wny I didn't pick it up because I was looking at FEF 190.Good eye mate. It does appear to be a variant of FEF 311. On that same page, the set bridge on FEF 222 seems to be identical as 311. Imo, 311 seems to be a variant of 222, which itself is likely a variant of an earlier movement.
Reading what Ranfft says:
differences not known between 310...329
family:
290: 10.5''', sub second
290-1, 330: 10.5''', sweep second
310: 11.5''', sub second
310-1, 340: 11.5''', sweep second
Now if we go to FEF 277-1 or any after 190 with the -1 which = sweep second
Remarks
various bridge shapes (cf. FEF 190)*
differences not known between 210-1...220-1, 222-1, 224-1, 226-1, 227-1
family:
190: 10.5''', sub second
190-1: 10.5''', sweep second
210: 11.5''', sub second
210-1: 11.5''', sweep second
They all look like the above movement.
