Cellini Marque Deposee Ladies Pocket Watch
SeaWilliam
Jul 17, 2021
81
Conroe Texas
I am restoring a Cellini Marque Deposse Ladies pocket watch and there is on visible attachment for the dial. Any ideas would be greatly appreciated. The dial is shown below:
The edge detail is shown below:
The dial (white) seems to be mounted on a three layer sandwich which does not move when pressure is applied.
I am just starting in watch restoration and need some guidance.
1627674108357.png Cellini Dial L.jpg Dial Detail 7 30 21.jpg Dial Detail 7 30 21.jpg
gmorse
12,774
2,314
Hi SeaWilliam,
Enamel dials are made of three apparent layers; the white vitreous visible layer, (that's actually made of multiple layers, often finished off with a transparent one), is fired onto a thin copper plate and there's a balancing layer of a non-descript coloured enamel fired onto the reverse. Dials usually have a number of posts soldered to the reverse to secure them to the movement, which are held in place by cross pins, screws with cutouts in their heads, screws fitted into the edges of the plate, or occasionally other methods, hence Rick's request to see the whole movement. Swiss movements often have the screws with cutouts to hold the dials in place.
Reactions: Rick Hufnagel
Dr. Jon
Dec 14, 2001
6,606
973
New Hampshire
If you cannot find the screws securing the dial feet, it is very likely that this dial has been glued on.. This is a nasty shortcut when replacing a dial. If this is what you have it is "game over" if it is glued to the plate.
Your photos suggest that the dial is glued to the outer ring, in which case the previous repair was decent. If this is what you have the holes are there to insert a lever and pry up the dial from the side opposite to the setting lever. I have not seen one like this.
Since yo are just getting started this might be a good one to put in the "too hard for now" pile.
SeaWilliam
Jul 17, 2021
81
Conroe Texas
Sorry about the clipped image. This is the lowest magnification on my scope. I can provide a rotated image if that would help.
gmorse
12,774
2,314
Hi SeaWilliam,
The two screws holding the dial are in the red circles. You need to turn each screw clockwise so that the copper post fits in the cutout, then the dial should just lift off, if you've already removed the hands.
SeaWilliam
Jul 17, 2021
81
Conroe Texas
Graham, you hit it on the head! Thanks for the help.
Thanks everyone.
SeaWilliam
SeaWilliam
168,272
1,467,544
48,208
PQuillin
2,955
