Casio Wave Ceptor problem
Kevin W.
23,272
586
64
I have tried to receive a radio signal for quite a while. Today when i manually searched for a signal. This came on my display. It did not change time when the time moved ahead by one hour this Spring. Its about one hour and three minutes behind now. I took a pic of the display today..
Skutt50
Mar 14, 2008
3,943
282
Gothenburg
It appears as if it is in the DST (Daylight Savings Time) mode so one would expect it to switch over.
I am by no means an expert on these but I have been playing around with the Wave Ceptor I have and it took several attempts before i got it to behave properly. Have you checked the manual for how to set up the watch? It requires a number of operations.......
I had to play back and forth with mine in regards to which city I was in and the DST auto/off function before I got mine to behave properly.
From the maps in the guides you should be able to pick up the radio signal in Nepean. Try to leave it in a window facing south or south west over night.
Kevin W.
23,272
586
64
Thanks Skutt.I have a copy of the manual and have ben going through it. I have another Wave Ceptor and its always received the signal fine. The watch is i think maybe three years old but i checked the battery strength, as its solar and its charged well.
Kevin W.
23,272
586
64
Getting back to thinking about this watch. Its at least over 2 years old. I am thinking change the battery and seeif it will seek theradio signal.
Any thoughts about battery life?
Skutt50
Mar 14, 2008
3,943
282
Gothenburg
Sorry no clue anout battery time! Try to measure the existing battery and compare with a new.........
The story of my Wave Ceptor is as follows:
I actually found mine at a recycling station and brought it home just for fun. At first it looked dead but I did something (don't remember now) and it started. Turns out the battery had good voltage so my assumption is that it was recently changed and the "watchmaker" didn't know how to reset the watch after a battery change.
Then I started to play with it and had great difficulties to get it to show correct time. But I found a setting that made it work fine, or so I thought. Only a few days ago, when we changed to winter time, it was off again.......
I read the manual again and found the solution. First I had to set the digital time correctly and then in a special mode I had to "zero" the hands to the same time. Then I had to set it to Berlin time (which is the same as Swedish time) and now it is performing perfectly.........
You should have a function where the radio setting is turned on or off. Try changing it to see what happens.
Kevin W.
23,272
586
64
Thanks Skutt, good information to know. Also since mine is Solar, perhaps charge levels also make a difference in receiving signal.
Skutt50
Mar 14, 2008
3,943
282
Gothenburg
One more thing.......
My watch receives uppdated time during the night..... If I remember correctly it updates e.g. at midnight, 2 and 5 o'clock......
Reactions: Kevin W.
168,746
1,472,316
48,554
daniel migland
2,955
