Case content and identification marked Goldinum wears like solid gold
Lovewatches101
Feb 14, 2020
31
40
Ive recently come across this watch and im hoping some1 can explain the content of the case,it's marked Goldinum brand trademark wears like solid gold and it has the initials of the makers name under it,it has the name Medana,is it like a fahys permanently gold filled case or is better,some1 please help
Rick Hufnagel
Just Rick!
Oct 25, 2018
2,834
4,381
37
Pittsburgh pa
I've seen "alumigold" and "aluminum gold" but goldinum sounds like it would be the same thing. No gold, but an alloy of aluminum to look like gold. Is the case very lightweight?
I would think its along the lines of silverode, Silveride, silverore, Silverine... None of them contain any silver, just nickel alloy intended to look like silver.
Also, it would help to see pictures.
Lovewatches101
Feb 14, 2020
31
40
It actually test as gold 14k and its soft like solid gold cases,I'm sure it's filled but I've never ever seen a marking such as this 1,ive seen guaranteed permanently,one quarter gold pride of elgin and even g.w. ladd cases with 1/2 gold content but never 1 that says wears like solid gold,it has the initials M.S under it for Meyer & Studeli
Steven Thornberry
User Administrator
Jan 15, 2004
24,133
1,741
Here and there
I've seen goldinum described as a cross between gold and platinum. Don't know whether to believe it or not.
Reactions: Lovewatches101
Lovewatches101
Feb 14, 2020
31
40
Just a surmise ,but it may be gold alloyed with aluminum. In the late 19th century aluminum was as valuable a gold.
Oh wow so now I understand why some cases was made out of aluminum from that time
Lovewatches101
Feb 14, 2020
31
40
After doing a lil research I would agree that its either gold and platinum or gold and aluminum,but i would lean more to gold and aluminum alloy mixed but a solid gold case
Jeff Hess
Gold Business Member
Sep 3, 2000
7,153
407
Florida
www.ballwatchusa.com
Oh wow I never expected a mix of platinum,it definetly contains at least 14k was tested with kee gold tester
Kee testers are great for quick sorting. We have several. But 120% they cannot be trusted for gold filled or heavy PLAQUE. Just DON'T!
mmelvis
Aug 31, 2020
Ran down the rabbit hole looking up Goldinum
If you can locate a copy of Iron & Coal Trades Review - Volume 105 - and look at Page 34 , the watch maker, Meyer & Studeli, is referenced
Book reference that has the registered name of Goldinum
Iron & Coal Trades Review - Volume 105 - Page 34
books.google.com › books
1922 - ‎Snippet view
Web link
Goldinum Brand - Metals - Google Search
Snippet from Google
Found inside – Page 34
The month of May gives the best results since Metals , Limited , Brentford Foundry , 2 , Glenhurst “ GOLDINUM BRAND . ” — Metals . Meyer & Studeli November last , but even with the slight improvement Road , Brentford , Middlesex . Société ...
Lovewatches101
Feb 14, 2020
31
40
Just wanted to add another pic just to show the color of the case,its not trying to look like gold,its actually a bright white yellowish color,it has no tarnish and is very heavy
Reactions: Urban hunter
Dr. Jon
Dec 14, 2001
6,836
1,143
New Hampshire
I have not found any reference to alloys of gold and aluminum but I did find reference to a gold aluminum inter-metallic compound. I have some limited background in this. Usually, inter-metallic means nasty physical properties and the gold aluminum inter metallic is also called white plague when it forms in making semiconductor devices. It is formed when aluminum or gold wires wires get bonded to a surface that has gold or aluminum in it (whether it is gold on aluminum or aluminum on gold, it is bad.) A while brittle material forms and destroys electrical contact.
Reactions: S.Humphrey
Lovewatches101
Feb 14, 2020
31
40
Oh wow,I don't think it's any aluminum in it,I'm pretty sure it's made of gold and platinum mixed,the watch is from the 1920's which is the time platinum exploded on the market
171,031
1,493,248
50,084
Genda
2,967
