Case construction detail on groaner
Discussion in 'Wood Movement Clocks' started by Jerome collector, Aug 19, 2017.
  1. Jerome collector
    Jerome collector Registered User
    Sep 4, 2005
    692
    Geologist, US Army Corps of Engineers
    Omaha, NE
    I'm hoping someone can take a look at a Boardman-labeled groaner clock and compare a case construction detail with my George Mitchell-labeled groaner. The detail in question is an inset that has been routed out of the lower portion of the door frame. I believe the purpose of this inset is to receive a thin wood board to protect (?) the mirror. A fragment of the board is still present on my clock, and I can see nail holes where the board was attached. I'm curious whether this is a standard feature of Boardman construction on bronzed looking-glass clocks.
    Thanks.
    Mike
  2. James Gardner
    James Gardner Registered User
    Apr 5, 2010
    14
    Mike,
    I have a number of groaners and I checked their doors to see if they had the similar construction.
    The following had the same insert routed out:
    George Mitchell (CT)- complete with wood backing in insert.
    Orrin Hart for William Hill (CT)- complete with wood backing in insert.
    Lawyer Byington (NY) - insert but no wood backing
    B & A Richards for William Hill (CT)- insert but no wood backing.
    Those without the routed insert:
    Austin Chittenden (MA)
    Orrin Hart (interesting some have it and some don't)(CT)
    B & H Twiss (CT)
    It appears it is a feature found in some of the groaners , but not all. I think this sample would be typical if it was bigger. I know this sample is not from Boardman clocks but might help with your question.
  3. George Nelson
    George Nelson Registered User
    Oct 5, 2007
    886
    Tennessee
    Mike,
    The single groaner in my collection happens to be a George Mitchell, and it does exhibit the same groove you are asking about. Hope this helps!
    Best always,
    George Nelson
  4. Jerome collector
    Sep 4, 2005
    692
    Omaha, NE
    James/George,
    Thanks for weighing in. Interestingly enough, there aren't any Boardman-labeled clocks in the group, even though some were probably made by him. Still curious to see what's out there in Boardman-labeled groaners.
    Mike
Similar Threads - Case construction detail Forum Date
Generic New England Tall Case Clock Wood Movement Clocks Nov 7, 2017
Production dates of Pillar and Scroll Case Style Question Wood Movement Clocks Feb 15, 2017
Interesting Details of Asa Hopkins Tall Case Weights Wood Movement Clocks Jan 29, 2017
Riley Whiting "Winchester" tall case movement Wood Movement Clocks Apr 18, 2016
